    Hot end blocked on first use
    • biscuitlad
      biscuitlad last edited by
      Getting close to switching my K8400 over Duet wifi and chimera set up. At least that's what I hope…
      But I'm having some extruder woes. T0 heated to 220 on a chimera. Extruded for the first time, selected 1cm, then another, to check filament flow. It started extruding, but almost immediately blocked up. I can't do anything to clear it. Tried heating to 240 and pushing it through - no go.
      I'm not sure what's gone wrong, I don't understand how it blocked so quickly and why I can't unblock as I normally do. Tried hot pull, cold pull. I guess I'll have to take it apart.
      How do people normally set up their first print to calibrate the extruder and make sure the stepper motors are correct?
      • tjb1
        tjb1 last edited by
        You can calibrate the extruder to some degree without the hotend mounted.
        • biscuitlad
          Can you? I couldn't select it in the DWC unless the temperature was sufficiently hot…
          • deckingman
            deckingman last edited by
            @biscuitlad:
            The usual way is to calibrate the steps per mm for the extruder with the hot end disconnected. IMO this is the best way. You can check it again with the hot end connected but you are likely to get different results depending on variables such as extrusion speed, nozzle diameter, extruder tension, filament diameter, temperature, etc. These differences are best dealt with by then applying an extrusion multiplier but keeping the basic steps per mm setting, as this is the one and only constant.
            • Dougal1957
              Dougal1957 last edited by
              M302 P1 will allow cold extrudes to allow you to do the extruder calibration M302 P0 turns it back on again
              • deckingman
                @Dougal1957:
                Thanks Doug, I forgot to mention that.
                • biscuitlad
                  Many thanks - I'll have a go.
