    Initial moves before printing
    • biscuitlad
      biscuitlad last edited by
      So, finally started to get some prints. Not great, by any means, but at least I have forced a print or two off it.
      However, I have a lot of strange behaviour that I can't track down and stop. So the bed does this weird thing where it goes up and and down several times before printing. That's not in the gcode, so I'm assuming it's something in the firmware?
      Secondly, on finishing the print, it retracts the filament almost down to the extruder (it's a bowden set up). Again, this doesn't appear in the gcode as far as I can see, so I'm puzzled why it does it.
      Start of gcode:
      [[language]]
      ;FLAVOR:Marlin
      ;TIME:543
      ;Filament used: 0.198559m
      ;Layer height: 0.1
      ;Generated with Cura_SteamEngine master
      M104 S210
      M109 S210
      G21 ;metric values
      G90 ;absolute positioning
      M82 ;set extruder to absolute mode
      M107 ;start with the fan off
      G28 X0 Y0 ;move X/Y to min endstops
      G28 Z0 ;move Z to min endstops
      G92 E0 ;zero the extruded length
      G1 F200 E3 ;extrude 3mm of feed stock
      G92 E0 ;zero the extruded length again
      G1 F9000
      ;Put printing message on LCD screen
      M117 Printing...
      ;LAYER_COUNT:48
      ;LAYER:0
      M107
      G0 F3600 X69.254 Y82.176 Z0.3
      G0 X68.827 Y82.546
      ;TYPE:SKIRT
      G1 F1800 X69.254 Y82.176 E0.02396
      G1 X69.837 Y81.813 E0.05308
      End of gcode:
      [[language]]
      G0 F7200 X99.17 Y88.071
      G1 F1800 X98.927 Y88.314 E198.55016
      G0 F7200 X95.116 Y88.468
      G0 X94.702 Y88.579
      G1 F1800 X94.423 Y88.575 E198.55257
      G1 X94.123 Y88.592 E198.55485
      G1 X93.853 Y88.578 E198.55711
      G1 X93.711 Y88.438 E198.55872
      ;TIME_ELAPSED:543.141166
      G1 F1500 E192.05872
      M107
      M104 S0 ;extruder heater off
      G1 Z140
      G91 ;relative positioning
      G1 E-1 F300  ;retract the filament a bit before lifting the nozzle, to release some of the pressure
      G1 Z+0.5 E-5 X-20 Y-20 F9000 ;move Z up a bit and retract filament even more
      G28 X0 Y0 ;move X/Y to min endstops, so the head is out of the way
      M84 ;steppers off
      M104 S0
      ;End of Gcode
      • garyd9
        garyd9 last edited by
        Lots of information not in this post (such as the type of printer.) However, I'll take some guesses…
        The Z moving up and down might be related to G28 (homing the printer.) Take a look in homeall.g to see if there are Z movements in it.
        Retracting the filament: You appear to be using absolute extruder movements (M82) and the ending code has:
        followed by...
        G1 F1500 E192.05872
        ...and then...
        If the extruder is in ABSOLUTE (not relative) mode, then "moving" from E 198 to E 192 is actually a retraction of 6mm. Then a movement to -1 is a retraction of an additional 193mm. In fact, E-1 is probably retracting the filament to the point where the extruder can no longer grip the filament to move it.
        "I'm not saying that you are wrong - I'm just trying to fit it into my real world simulated experience."
          As @garyd9 says, the Z movement is caused by homing X, Y and Z separately. If you replace the two lines G28 X Y and G28 Z by just one G28 line then if you have set up your homing files correctly, it will only move up and down once.
          @garyd9 is also correct in saying that the retraction at the end is caused by using G1 E-1 at the end when in absolute extrusion mode. Recent versions of Cura support relative extrusion, which we recommend you select. But if you must use absolute extrusion, insert either M83 or G92 E0 before that G1 E-1 command.
          • biscuitlad
            Ah, that all makes sense now. Many thanks to you both. I'll get editing!
