    Weird effect while printing
    • CobraMikeundefined
      CobraMike
      Ok thanks to a moderator or admin here. I found out that my z motors was outer sinc. Bit after 2 test prints i am stuck. I dont now how to solve this. Can some one help me.
      Motor / Jerk settings.
      [[language]]
      M569 P0 S1        ; Drive 0 goes forwards
      M569 P1 S0        ; Drive 1 goes backwards
      M569 P2 S1        ; Drive 2 goes forwards
      M569 P3 S0        ; Drive 3 goes backwards
      M350 X16 Y16 Z16 E16 I0                                                              ; Configure microstepping without interpolation
      M92 X80 Y80 Z400 E150        ; Set steps per mm
      M566 X1200 Y1200 Z24 E300                                                          ; Set maximum instantaneous speed changes (mm/min)
      M203 X30000 Y30000 Z600 E3000                                                       ; Set maximum speeds (mm/min)
      M201 X500 Y500 Z100 E5000                                                       ; Set accelerations (mm/s^2)
      M906 X800 Y800 Z800 E800 I30                                                  ; Set motor currents (mA) and motor idle factor in per cent
      M84 S30        ; Set idle timeout
      M208 X0 Y0 Z0 S1        ; Set axis minima
      M208 X250 Y210 Z180 S0                                                               ; Set axis maxima
      And here my printer with bountech ectruder. Love this extruder
        My guess is that those bumps are happening on layer changes. Getting rid of such artefacts completely is not easy, but selecting "External perimeters first" (or "outside-in") and enabling "Retract on layer change" in your slicer may both help.
        • burtoogleundefined
          burtoogle
          If you are using Cura spiralize mode, ensure that retract on layer change is off! (the next release of Cura ignores that setting when spiralize is enabled).
            CobraMike
            Wow thanks guys i am testing some settings. But i must say great support from you guys. I love the duetWifi its nice and much nicer to change settings then Marling with the ramps board.
            Thanks for the help
