    Layer problems Tronxy X5S
    • flippnswitchez
      flippnswitchez last edited by
      I am able to print a BEAUTIFUL first layer but when it begins to start the 2nd layer its almost like the z axis moves to far and throws everything. I think speed maybe one of my issues. Any suggestions would be great. Here is my config.
      [c]; Drives
      M350 X32 Y32 Z32 E32 I1 ; Configure microstepping with interpolation
      M92 X160 Y160 Z4000 E420 ; Set steps per mm
      M566 X9000 Y9000 Z12 E120 ; Set maximum instantaneous speed changes (mm/min)
      M203 X10000 Y10000 Z12 E3600 ; Set maximum speeds (mm/min)
      M201 X2000 Y2000 Z50 E1000 ; Set accelerations (mm/s^2)
      M906 X800 Y800 Z800 E800 I30 ; Set motor currents (mA) and motor idle factor in per cent
      M84 S30 ; Set idle timeout
      M208 X-50 Y-20 Z0 S1 ; Set axis minima
      M208 X290 Y300 Z76 S0 ; Set axis maxima
      M574 X1 Y1 Z1 S0 ; Set active low endstops
      M558 P0 X0 Y0 Z1 H5 F120 T6000 ; Set Z probe type to switch, the axes for which it is used and the dive height + speeds
      G31 P600 X0 Y0 Z2.5 ; Set Z probe trigger value, offset and trigger height
      M557 X15:315 Y15:315 S20 ; Define mesh grid
      M143 H0 S150 ; Set temperature limit for heater 0 to 150C
      M143 H1 S320 ; Set temperature limit for heater 1 to 320C
      M563 P1 D0 H1 ; Define tool 1
      G10 P1 X0 Y0 Z0 ; Set tool 1 axis offsets
      G10 P1 R0 S0 ; Set initial tool 1 active and standby temperatures to 0C [/c]
        Are you sure that your Z steps/mm value (4000) in the M92 command is correct?
