    Trouble with adding an extra heat bed
    • jeff516
      jeff516 last edited by
      I have added an extra heat bed (i.e. I have two heat beds) for the large print bed I have. One of them is connected with the heat bed power supply and the other one is actually a larger heater which requires an external power supply (and also a SSR). The heat bed is plugged into E1 Heater.
      The issue I am experiencing right now is that when I tried to switch the bed to active, the temperature increases uncontrollably and the only way I can stop it is by shutting down the whole machine by unplugging.
      ; generated by RepRapFirmware Configuration Tool on Wed Mar 07 2018 17:28:25 GMT-0500 (Eastern Standard Time)
      M555 P1 ; Set firmware compatibility to look like RepRapFirmare
      M667 S1 ; Select CoreXY mode
      M550 PXXXX ; Set machine name
      M551 PXXXX ; Set password
      M552 S1 ; Enable network
      M587 S"Jump24" P"Jump24" ; Configure access point. You can delete this line once connected
      M586 P0 S1 ; Enable HTTP
      M586 P1 S0 ; Disable FTP
      M586 P2 S0 ; Disable Telnet
      M569 P0 S0 ; Drive 0 goes backwards
      M350 X256 Y256 Z16 E256 I0 ; Configure microstepping without interpolation
      M92 X1280 Y1280 Z600 E6660 ; Set steps per mm
      M203 X9000 Y9000 Z180 E3000 ; Set maximum speeds (mm/min)
      M201 X800 Y800 Z50 E5000 ; Set accelerations (mm/s^2)
      M906 X1200 Y1200 Z1500 E650 I30 ; Set motor currents (mA) and motor idle factor in per cent
      M84 S30 ; Set idle timeout
      M208 X800 Y350 Z700 S0 ; Set axis maxima
      M574 X1 Y1 Z1 S1 ; Set active high endstops
      M558 P0 H5 F120 T6000 ; Set Z probe type to switch and the dive height + speeds
      G31 P600 X0 Y0 Z0 ; Set Z probe trigger value, offset and trigger height
      M557 X15:785 Y15:335 S20 ; Define mesh grid
      M141 H2 ; Assign chamber heater to heater 2
      M301 H2 P-1 ; Set heater 2 to bang-bang mode
      M305 P0 T100000 B4072 C0 R4700 ; Set thermistor + ADC parameters for heater 0
      M143 H0 S100 ; Set temperature limit for heater 0 to 100C
      M305 P1 T100000 B4725 C7.060000e-8 R4700 ; Set thermistor + ADC parameters for heater 1
      M305 P2 T100000 B3950 C0 R4700 ; Set thermistor + ADC parameters for heater 2
      M143 H2 S100 ; Set temperature limit for heater 2 to 100C
      M106 P0 S1 I0 F500 H T45 ; Set fan 0 value, PWM signal inversion and frequency. Thermostatic control is turned on
      M106 P1 T45 H1 ; Set fan 1 value, PWM signal inversion and frequency. Thermostatic control is turned off
      M106 P2 S1 I0 F500 H-1 ; Set fan 2 value, PWM signal inversion and frequency. Thermostatic control is turned off
      M563 P1 D0 H1 ; Define tool 1
      G10 P1 X0 Y0 Z0 ; Set tool 1 axis offsets
      G10 P1 R0 S0 ; Set initial tool 1 active and standby temperatures to 0C
        You can't use M301 to force bang-bang mode any more. Use M307 to do that instead.
        Instead of configuring your bed heaters as 1 bed + 1 chamber heater, in RRF 1.20 and later you can configure them as 2 bed heaters:
        M140 H0:2
        • jeff516
          Thanks dc42, so does that mean I should replace the line:
          "M141 H2" with "M140 H0:2"
            Yes, that should do it. Then you need to use the P parameter in M140/M190 commands to specify which bed heater you are referring to, 0 (default) or 1.
            • jeff516
              Do you mind walking me through how to use the P parameter to specify the heaters?
              After I made the change to the M140 and also M307, the only difference I saw was that the 3rd tool has been removed from the browser and I am only left with the Extruder and heat bed.
