    Sannce AG121 can'nt login
    1.1k
    • Synapsisundefined
      Synapsis
      I got the Sannce AG121 thinking what could go wrong seeing there is a guide to use it.
      Did all the install of the android app set admin password and user name and password
      via andorid app. the installed the pc app setup the network with a fixed ip and port.
      When i put in the setting in DWC (firefox) ask for user name and password (does no ask if I want to remember)
      I put in the user name ansd password and it kust keeps asking for it as if it isn't correct.
      If I try to login via web browser same ip and port it accepts the user name and password.
      What am I missing?
      Thanks
        Did you include any unusual characters in the password?
        • Synapsisundefined
          Synapsis
          No first just letters then letters and numbers and for last only numbers.
          Like I said if I connect via web browser it connects after putting in the user and password.
          Same popup.. very strange. I am using firefox.
          • Synapsisundefined
            Synapsis
            Well why I do not know now it take the password and user name.
            Only thing is is does not updateevery X seconds as set in the setup. I have to refresh the page
            or change tab and then it will update.
            Thanks
              Do you have DWC connected to your Duet? I'm not sure whether DWC refreshes the camera image when it is not connected to a Duet.
              • JohnOCFIIundefined
                JohnOCFII
                @dc42:
                Just tested with my IP camera, and DWC continues to refresh the image every 5 seconds even after I disconnect and power off the Duet/Printer. This is testing with Chrome on a Mac. This is a different IP camera (Foscam C1), but expect they'd operate similarly in this regard.
                John
                • Synapsisundefined
                  Synapsis
                  I,m using the DWC connected to the duet in real time.
                  I just saw thta the update in the graph is not working while current layer etc are updating.
                  If I refresh the page when I go page to Printer Status it updated.
                  I'm using firefox 58
                    Have you pressed control-shift-J to open the developer console, and checked for exception or other error messages?
                    • Synapsisundefined
                      Synapsis
                      No I didn't about that .
                      Here is what I'm getting for example:
                      Sono presenti campi password in una pagina con connessione non sicura (http://). Si tratta di un rischio per la sicurezza in quanto consente il furto delle credenziali di accesso inserite.[Ulteriori informazioni]
                      and
                      MediaKeySystemAccess::GetKeySystemStatus(com.widevine.alpha) result=available msg=''
                      Firefox non può stabilire una connessione con il server wss://lp-push-server-532.lastpass.com/ws/de87f35c8d3e1ed1922716181ce1c52d5dae0bc5a2e915eb8990b777f8289224. push_client.js:1:655
                      TypeError: event.originalTarget.getAttribute is not a function[Ulteriori informazioni] tabbrowser.xml:8175:22
                      TypeError: event.originalTarget.getAttribute is not a function[Ulteriori informazioni] tabbrowser.xml:8182:22
                      • Synapsisundefined
                        Synapsis
                        Nerver mind got the live stream to work which is much better. 🙂
                          How did you get the live stream to work?
                          • Synapsisundefined
                            Synapsis
                            As per guide
                            http://Your IP:PORT/videostream.cgi?loginuse=USER NAME&loginpas=PASSWORD
                            If you try that address in a browser it should open the cam view. if that works it works in DWC.
                            Embed Webcam Stream not selected
                            • Synapsisundefined
                              Synapsis
                              http://www.garlandogioielli.it/images/CAM.mp4
