    Configuring PT1000 sensors
    • Dougal1957undefined
      Dougal1957
      This is probably for David but please feel free to chip in if you can help.
      I Have some PT1000 sensors from RS pn 100-7530 https://uk.rs-online.com/web/p/platinum-resistance-temperature-sensors/1007530/?sra=pstk and I have put one straight into a molex shell for test.
      when out of the board it measures 1.1 kOhms so I would expect this to give me a sensible reading on DWC (Not the case)
      I have it configured as M305 P0 X500 in my config
      with nothing connected to the E0 Thermistor pins the DWC Reads 493.6 degrees with the pt1000 connected I get the same
      This is the Heater section of my Config.g
      M305 P0 X500 R4700 ; Configure thermocouple for heater 0
      M305 P1 X200 ; Configure thermocouple for heater 1
      I am on the latest FW
      Any ideas what I have done wrong
      Doug
      • DjDemonDundefined
        DjDemonD
        Hi Doug,
        I have some sample pt1000's that we are about to begin stocking. I just measured one and it shows 1.035Kohm at about 14 degrees C.
        I have got 3 connected to my cylinder delta using the following config
        M305 P0 X500 R4700  			; heater 0 uses a PT1000 connected to thermistor channel 0 which has a 4.7K series resistor
        M305 P1 X501 R4700  			; heater 1 uses a PT1000 connected to thermistor channel 1 which has a 4.7K series resistor
        M305 P2 X502 R4700  			; heater 2 uses a PT1000 connected to thermistor channel 1 which has a 4.7K series resistor
        So it might be the heater channel has to be 501,502,503 etc…
        www.precisionpiezo.co.uk
          Your M305 comments don't match the parameters values. Your first M305 command says that the bed heater channel uses a PT1000 connected to the bed thermistor input. The second one says that your E0 heater uses a PT100 sensor connected to a daughter board. Nothing about a PT1000 connected to E0 thermistor input.
            Dougal1957
            no this is for the bed Simon I intend to use a PT100 in the hotend
            I have tried X501 for P1 as well with the same results. also with and without the R4700
              Dougal1957
              Thank you David that was the Clue I needed all now sorted.
              I did indeed put it on the E0 thermistor input instead of the bed one Doh
              Doug
