    2 Pin Terminal Connector
    • Threephourthsundefined
      Threephourths
      I moved my printers over the weekend and the 2 pin terminal connector for the heater leads broke off. I can remove the broken one and solder in a new one no problem, but I need a part number for it. Do you guys have a part number or a link for a replacement?
        The part we use is KF124-3.5-2P but any 2-pin 3.5mm pitch PCB mounting terminal block should suffice. Alternatively you can fit a 2-pin Molex Microfit 3 socket, then one of E3D's new high precision heater cartridges should plug into it.
          Threephourths
          Great! Thanks DC!
