    DuetRFF Cura plugin - not working/recognizing in cura?
    2663
    • magicmarc
      magicmarc last edited by
      hi, im using cura 3.2.1, and i wanted to install the cura to duetRFF plugin, as listed here in this forum (v0.0.5). i placed the unzipped folder in the %user%\appdata\roaming\cura\3.2\plugins folder, with cura closed, then opened cura, and under 'extensions' i dont see it there.?
      ideas?
      it doesnt seem to be recognizing the files /plugin?
      thanks for the support everyone!
      marc
      • resam
        resam last edited by
        Hi magicmarc!
        I'm the guy behind the Cura-DuetRRF plugin, which is not related to dc42/Think3DPrint3D/Escher3D.
        Feel free to use the issue tracker on the GitHub repo!
        Please make sure the have the latest release - v0.0.9 right now:
        https://github.com/Kriechi/Cura-DuetRRFPlugin/releases
        Does it show up if you go to Cura -> Plugins -> Installed plugins… ?
        How does your folder structure looks like?
        On my macOS system I can find the README file under [c]~/Library/Application Support/cura/3.2/plugins/Cura-DuetRRFPlugin/README.md[/c]
        Maybe you could check your Cura log file: [c]C:\Users<username>\AppData\Roaming\cura\3.2\cura.log[/c]
        Do you see any plugins-related loading errors?</username>
        • magicmarc
          hi,thanks resam, ill try to post in appropriate areas.
          i dloaded the 0.0.5 version. ill try the latest from your link now.
          i dont see it listed when i goto 'plugins' not do i see it under 'extensions' …. (when i ran cura 3.1.0 i had tried this out, and it was there in the extension and the plugins... but when i tried to use it, i got authentication errrors (username, etc...)
          ill try the latest first, then look at the cura.log
          marc
          im using windows 10 pro , and the folders are c:\users\marc\appdata\roaming\cura\3.2\plugins (this is where i placed the unzipped folder)
          hi i just tried the latest version, it didnt show up in extensions or in plugins, as well i dont see any file named cura.log to look at..? maybe i should uninstall all cura's and then reboot, clean temp files, and reinstall the cura 3.2.1 fresh, and try tohe plugin...?
          • magicmarc
            hi, thanks, when i changed the folder name from -0.0.9 to -master, it recognized the plugin… then when i goto upload to duetrrf (after i added the ip address of my artemis) i clicked upload gcoade, and after selecting a filename and clicking, i get 'there was a network error "" 301 protocol is unknown'
            thanks as always
            marc
            • resam
              What did you enter as the URL? A raw IP, or a domain name? Windows UNCs are not supported.
              Please also try to close & reopen Cura after changing the settings.
              Please post the log file (path mentioned above).
              • magicmarc
                i entered the ip address of the duet on my local wifi network: 172.16.31.76, i also tried \172.16.31.76 still the 301 protocol error.
                the cura.log is too large to paste here, i got an 'exceed limit' error, as well as it froze my chrome for a bit…
                ill copy and past the last part of the cura.log that has the error in the next reply.
                • magicmarc
                  so i renamed the cura.log so i can get a fresh , smaller one: here is the log, at the bottom section is the 301 error (while i attempted to 'upload file to duetrrf'
                  2018-03-20 08:19:12,806 - INFO - [(11228)-MainThread] UM.PluginRegistry.loadPlugin [238]: Loaded plugin FileLogger
                  2018-03-20 08:19:12,860 - INFO - [(11228)-MainThread] UM.PluginRegistry.loadPlugin [238]: Loaded plugin FirmwareUpdateChecker
                  2018-03-20 08:19:12,866 - INFO - [(11228)-MainThread] UM.PluginRegistry.loadPlugin [238]: Loaded plugin GCodeProfileReader
                  2018-03-20 08:19:12,883 - INFO - [(11228)-MainThread] UM.PluginRegistry.loadPlugin [238]: Loaded plugin GCodeReader
                  2018-03-20 08:19:12,894 - INFO - [(11228)-MainThread] UM.PluginRegistry.loadPlugin [238]: Loaded plugin GCodeWriter
                  2018-03-20 08:19:12,903 - INFO - [(11228)-MainThread] UM.PluginRegistry.loadPlugin [238]: Loaded plugin ImageReader
                  2018-03-20 08:19:12,910 - INFO - [(11228)-MainThread] UM.PluginRegistry.loadPlugin [238]: Loaded plugin LegacyProfileReader
                  2018-03-20 08:19:12,919 - INFO - [(11228)-MainThread] UM.PluginRegistry.loadPlugin [238]: Loaded plugin LocalContainerProvider
                  2018-03-20 08:19:12,929 - INFO - [(11228)-MainThread] UM.PluginRegistry.loadPlugin [238]: Loaded plugin LocalFileOutputDevice
                  2018-03-20 08:19:12,937 - INFO - [(11228)-MainThread] UM.PluginRegistry.loadPlugin [238]: Loaded plugin MachineSettingsAction
                  2018-03-20 08:19:12,946 - INFO - [(11228)-MainThread] UM.PluginRegistry.loadPlugin [238]: Loaded plugin MonitorStage
                  2018-03-20 08:19:12,961 - INFO - [(11228)-MainThread] UM.PluginRegistry.loadPlugin [238]: Loaded plugin PerObjectSettingsTool
                  2018-03-20 08:19:12,971 - INFO - [(11228)-MainThread] UM.PluginRegistry.loadPlugin [238]: Loaded plugin PluginBrowser
                  2018-03-20 08:19:12,981 - INFO - [(11228)-MainThread] UM.PluginRegistry.loadPlugin [238]: Loaded plugin PostProcessingPlugin
                  2018-03-20 08:19:12,988 - INFO - [(11228)-MainThread] UM.PluginRegistry.loadPlugin [238]: Loaded plugin PrepareStage
                  2018-03-20 08:19:13,000 - INFO - [(11228)-MainThread] UM.PluginRegistry.loadPlugin [238]: Loaded plugin RemovableDriveOutputDevice
                  2018-03-20 08:19:13,020 - INFO - [(11228)-MainThread] UM.PluginRegistry.loadPlugin [238]: Loaded plugin SimulationView
                  2018-03-20 08:19:13,032 - INFO - [(11228)-MainThread] UM.PluginRegistry.loadPlugin [238]: Loaded plugin SliceInfoPlugin
                  2018-03-20 08:19:13,040 - INFO - [(11228)-MainThread] UM.PluginRegistry.loadPlugin [238]: Loaded plugin SolidView
                  2018-03-20 08:19:13,049 - INFO - [(11228)-MainThread] UM.PluginRegistry.loadPlugin [238]: Loaded plugin CameraTool
                  2018-03-20 08:19:13,059 - INFO - [(11228)-MainThread] UM.PluginRegistry.loadPlugin [238]: Loaded plugin MirrorTool
                  2018-03-20 08:19:13,071 - INFO - [(11228)-MainThread] UM.PluginRegistry.loadPlugin [238]: Loaded plugin RotateTool
                  2018-03-20 08:19:13,087 - INFO - [(11228)-MainThread] UM.PluginRegistry.loadPlugin [238]: Loaded plugin ScaleTool
                  2018-03-20 08:19:13,098 - INFO - [(11228)-MainThread] UM.PluginRegistry.loadPlugin [238]: Loaded plugin SelectionTool
                  2018-03-20 08:19:13,108 - INFO - [(11228)-MainThread] UM.PluginRegistry.loadPlugin [238]: Loaded plugin TranslateTool
                  2018-03-20 08:19:13,123 - INFO - [(11228)-MainThread] UM.PluginRegistry.loadPlugin [238]: Loaded plugin UltimakerMachineActions
                  2018-03-20 08:19:13,177 - INFO - [(11228)-MainThread] UM.PluginRegistry.loadPlugin [238]: Loaded plugin UM3NetworkPrinting
                  2018-03-20 08:19:13,188 - INFO - [(11228)-MainThread] UM.PluginRegistry.loadPlugin [238]: Loaded plugin UpdateChecker
                  2018-03-20 08:19:13,190 - INFO - [(14864)-Thread-3] UpdateChecker.UpdateCheckerJob.run [34]: Checking for new version of cura
                  2018-03-20 08:19:13,226 - INFO - [(11228)-MainThread] UM.PluginRegistry.loadPlugin [238]: Loaded plugin USBPrinting
                  2018-03-20 08:19:13,234 - INFO - [(11228)-MainThread] UM.PluginRegistry.loadPlugin [238]: Loaded plugin UserAgreementPlugin
                  2018-03-20 08:19:13,249 - INFO - [(11228)-MainThread] UM.PluginRegistry.loadPlugin [238]: Loaded plugin VersionUpgrade21to22
                  2018-03-20 08:19:13,257 - INFO - [(11228)-MainThread] UM.PluginRegistry.loadPlugin [238]: Loaded plugin VersionUpgrade22to24
                  2018-03-20 08:19:13,266 - INFO - [(11228)-MainThread] UM.PluginRegistry.loadPlugin [238]: Loaded plugin VersionUpgrade25to26
                  2018-03-20 08:19:13,275 - INFO - [(11228)-MainThread] UM.PluginRegistry.loadPlugin [238]: Loaded plugin VersionUpgrade26to27
                  2018-03-20 08:19:13,286 - INFO - [(11228)-MainThread] UM.PluginRegistry.loadPlugin [238]: Loaded plugin VersionUpgrade27to30
                  2018-03-20 08:19:13,298 - INFO - [(11228)-MainThread] UM.PluginRegistry.loadPlugin [238]: Loaded plugin VersionUpgrade30to31
                  2018-03-20 08:19:13,306 - INFO - [(11228)-MainThread] UM.PluginRegistry.loadPlugin [238]: Loaded plugin SimpleView
                  2018-03-20 08:19:13,321 - INFO - [(11228)-MainThread] UM.PluginRegistry.loadPlugin [238]: Loaded plugin X3DReader
                  2018-03-20 08:19:13,337 - INFO - [(11228)-MainThread] UM.PluginRegistry.loadPlugin [238]: Loaded plugin XmlMaterialProfile
                  2018-03-20 08:19:13,350 - INFO - [(11228)-MainThread] UM.PluginRegistry.loadPlugin [238]: Loaded plugin XRayView
                  2018-03-20 08:19:13,365 - ERROR - [(11228)-MainThread] UM.Qt.QtApplication.getTheme [325]: The theme cannot be accessed before the engine is initialised
                  2018-03-20 08:19:13,367 - ERROR - [(11228)-MainThread] UM.Qt.QtApplication.getTheme [325]: The theme cannot be accessed before the engine is initialised
                  2018-03-20 08:19:13,368 - ERROR - [(11228)-MainThread] UM.Qt.QtApplication.getTheme [325]: The theme cannot be accessed before the engine is initialised
                  2018-03-20 08:19:13,369 - INFO - [(11228)-MainThread] UM.PluginRegistry.loadPlugin [238]: Loaded plugin Cura-DuetRRFPlugin-master
                  2018-03-20 08:19:13,380 - INFO - [(11228)-MainThread] UM.PluginRegistry.loadPlugin [238]: Loaded plugin OrientationPlugin
                  2018-03-20 08:19:13,389 - ERROR - [(11228)-MainThread] UM.Qt.QtApplication.getTheme [325]: The theme cannot be accessed before the engine is initialised
                  2018-03-20 08:19:13,393 - INFO - [(11228)-MainThread] UM.VersionUpgradeManager.upgrade [113]: Looking for old configuration files to upgrade.
                  2018-03-20 08:19:13,393 - DEBUG - [(15140)-Thread-9] USBPrinting.USBPrinterOutputDevice._connect [340]: Attempting to connect to COM5
                  2018-03-20 08:19:13,672 - DEBUG - [(11228)-MainThread] UM.Backend.Backend._logSocketState [173]: Socket state changed to Listening
                  2018-03-20 08:19:13,681 - INFO - [(11228)-MainThread] UM.Backend.Backend.startEngine [74]: Started engine process: C:\Program Files\Ultimaker Cura 3.2\CuraEngine.exe
                  2018-03-20 08:19:13,685 - DEBUG - [(11228)-MainThread] UM.Backend.Backend._backendLog [90]: [Backend] Calling engine with: ['C:\Program Files\Ultimaker Cura 3.2\CuraEngine.exe', 'connect', '127.0.0.1:49674', '-j', 'C:\Program Files\Ultimaker Cura 3.2\resources\definitions\fdmprinter.def.json', '']
                  2018-03-20 08:19:13,690 - WARNING - [(11228)-MainThread] UM.OutputDevice.OutputDeviceManager.removeOutputDevice [126]: Could not find output device with id COM5 to remove
                  2018-03-20 08:19:13,761 - DEBUG - [(1964)-Thread-13] UM.Backend.Backend._backendLog [90]: [Backend]
                  2018-03-20 08:19:13,763 - DEBUG - [(1964)-Thread-13] UM.Backend.Backend._backendLog [90]: [Backend] Cura_SteamEngine version DEV
                  2018-03-20 08:19:13,764 - DEBUG - [(1964)-Thread-13] UM.Backend.Backend._backendLog [90]: [Backend] Copyright (C) 2017 Ultimaker
                  2018-03-20 08:19:13,768 - DEBUG - [(1964)-Thread-13] UM.Backend.Backend._backendLog [90]: [Backend]
                  2018-03-20 08:19:13,769 - DEBUG - [(11228)-MainThread] UM.Backend.Backend._logSocketState [177]: Socket state changed to Connected
                  2018-03-20 08:19:13,771 - DEBUG - [(11228)-MainThread] UM.Backend.Backend._onSocketStateChanged [167]: Backend connected on port 49674
                  2018-03-20 08:19:13,771 - DEBUG - [(1964)-Thread-13] UM.Backend.Backend._backendLog [90]: [Backend] This program is free software: you can redistribute it and/or modify
                  2018-03-20 08:19:13,773 - DEBUG - [(1964)-Thread-13] UM.Backend.Backend._backendLog [90]: [Backend] it under the terms of the GNU Affero General Public License as published by
                  2018-03-20 08:19:13,776 - DEBUG - [(1964)-Thread-13] UM.Backend.Backend._backendLog [90]: [Backend] the Free Software Foundation, either version 3 of the License, or
                  2018-03-20 08:19:13,777 - DEBUG - [(1964)-Thread-13] UM.Backend.Backend._backendLog [90]: [Backend] (at your option) any later version.
                  2018-03-20 08:19:13,779 - DEBUG - [(1964)-Thread-13] UM.Backend.Backend._backendLog [90]: [Backend]
                  2018-03-20 08:19:13,780 - DEBUG - [(1964)-Thread-13] UM.Backend.Backend._backendLog [90]: [Backend] This program is distributed in the hope that it will be useful,
                  2018-03-20 08:19:13,781 - DEBUG - [(1964)-Thread-13] UM.Backend.Backend._backendLog [90]: [Backend] but WITHOUT ANY WARRANTY; without even the implied warranty of
                  2018-03-20 08:19:13,783 - DEBUG - [(1964)-Thread-13] UM.Backend.Backend._backendLog [90]: [Backend] MERCHANTABILITY or FITNESS FOR A PARTICULAR PURPOSE. See the
                  2018-03-20 08:19:13,784 - DEBUG - [(1964)-Thread-13] UM.Backend.Backend._backendLog [90]: [Backend] GNU Affero General Public License for more details.
                  2018-03-20 08:19:13,785 - DEBUG - [(1964)-Thread-13] UM.Backend.Backend._backendLog [90]: [Backend]
                  2018-03-20 08:19:13,786 - DEBUG - [(1964)-Thread-13] UM.Backend.Backend._backendLog [90]: [Backend] You should have received a copy of the GNU Affero General Public License
                  2018-03-20 08:19:13,787 - DEBUG - [(1964)-Thread-13] UM.Backend.Backend._backendLog [90]: [Backend] along with this program. If not, see <http://www.gnu.org/licenses/>.
                  2018-03-20 08:19:15,189 - INFO - [(15140)-Thread-9] USBPrinting.USBPrinterOutputDevice._connect [348]: Could not establish connection on COM5: 'Timeout'. Device is not arduino based.
                  2018-03-20 08:19:15,189 - DEBUG - [(15140)-Thread-9] USBPrinting.USBPrinterOutputDevice._connect [356]: Attempting to connect to printer with serial COM5 on baud rate 115200
                  2018-03-20 08:19:15,399 - WARNING - [(11228)-MainThread] UM.Preferences.getValue [81]: Tried to get the value of non-existing setting view/filter_current_build_plate.
                  2018-03-20 08:19:15,401 - DEBUG - [(11228)-MainThread] cura.Scene.CuraSceneController.setActiveBuildPlate [101]: Select build plate: 0
                  2018-03-20 08:19:15,404 - DEBUG - [(11228)-MainThread] UM.Controller.setActiveStage [155]: Setting active stage to PrepareStage
                  2018-03-20 08:19:15,406 - DEBUG - [(11228)-MainThread] UM.Controller.setActiveView [92]: Setting active view to SolidView
                  2018-03-20 08:19:15,419 - DEBUG - [(11228)-MainThread] LocalContainerProvider.LocalContainerProvider.loadContainer [50]: Loading container ARTEMIS
                  2018-03-20 08:19:15,422 - DEBUG - [(11228)-MainThread] LocalContainerProvider.LocalContainerProvider.loadContainer [50]: Loading container ARTEMIS_user
                  2018-03-20 08:19:15,426 - DEBUG - [(11228)-MainThread] LocalContainerProvider.LocalContainerProvider.loadContainer [50]: Loading container custom_se300_pla_defaut
                  2018-03-20 08:19:15,430 - DEBUG - [(11228)-MainThread] LocalContainerProvider.LocalContainerProvider.loadContainer [50]: Loading container normal
                  2018-03-20 08:19:15,432 - DEBUG - [(11228)-MainThread] LocalContainerProvider.LocalContainerProvider.loadContainer [50]: Loading container ARTEMIS_settings
                  2018-03-20 08:19:15,434 - DEBUG - [(11228)-MainThread] LocalContainerProvider.LocalContainerProvider.loadContainer [50]: Loading container custom
                  2018-03-20 08:19:15,500 - DEBUG - [(11228)-MainThread] LocalContainerProvider.LocalContainerProvider.loadContainer [50]: Loading container custom_extruder_4 #2
                  2018-03-20 08:19:15,503 - DEBUG - [(11228)-MainThread] LocalContainerProvider.LocalContainerProvider.loadContainer [50]: Loading container custom_extruder_4 #2_user
                  2018-03-20 08:19:15,505 - DEBUG - [(11228)-MainThread] LocalContainerProvider.LocalContainerProvider.loadContainer [50]: Loading container polywood_pla
                  2018-03-20 08:19:15,506 - DEBUG - [(11228)-MainThread] LocalContainerProvider.LocalContainerProvider.loadContainer [50]: Loading container custom_extruder_4 #2_settings
                  2018-03-20 08:19:15,509 - DEBUG - [(11228)-MainThread] LocalContainerProvider.LocalContainerProvider.loadContainer [50]: Loading container custom_extruder_4
                  2018-03-20 08:19:15,511 - INFO - [(11228)-MainThread] cura.Settings.GlobalStack.addExtruder [73]: Extruder[custom_extruder_4 #2] added to [ARTEMIS] at position [3]
                  2018-03-20 08:19:15,513 - WARNING - [(11228)-MainThread] UM.Settings.ContainerStack.addMetaDataEntry [166]: Meta data with key machine was already added.
                  2018-03-20 08:19:15,514 - DEBUG - [(11228)-MainThread] LocalContainerProvider.LocalContainerProvider.loadContainer [50]: Loading container custom_extruder_7 #2
                  2018-03-20 08:19:15,516 - DEBUG - [(11228)-MainThread] LocalContainerProvider.LocalContainerProvider.loadContainer [50]: Loading container custom_extruder_7 #2_user
                  2018-03-20 08:19:15,518 - DEBUG - [(11228)-MainThread] LocalContainerProvider.LocalContainerProvider.loadContainer [50]: Loading container custom_extruder_7 #2_settings
                  2018-03-20 08:19:15,520 - DEBUG - [(11228)-MainThread] LocalContainerProvider.LocalContainerProvider.loadContainer [50]: Loading container custom_extruder_7
                  2018-03-20 08:19:15,523 - INFO - [(11228)-MainThread] cura.Settings.GlobalStack.addExtruder [73]: Extruder[custom_extruder_7 #2] added to [ARTEMIS] at position [6]
                  2018-03-20 08:19:15,524 - WARNING - [(11228)-MainThread] UM.Settings.ContainerStack.addMetaDataEntry [166]: Meta data with key machine was already added.
                  2018-03-20 08:19:15,525 - DEBUG - [(11228)-MainThread] LocalContainerProvider.LocalContainerProvider.loadContainer [50]: Loading container custom_extruder_3 #2
                  2018-03-20 08:19:15,528 - DEBUG - [(11228)-MainThread] LocalContainerProvider.LocalContainerProvider.loadContainer [50]: Loading container custom_extruder_3 #2_user
                  2018-03-20 08:19:15,530 - DEBUG - [(11228)-MainThread] LocalContainerProvider.LocalContainerProvider.loadContainer [50]: Loading container custom_extruder_3 #2_settings
                  2018-03-20 08:19:15,533 - DEBUG - [(11228)-MainThread] LocalContainerProvider.LocalContainerProvider.loadContainer [50]: Loading container custom_extruder_3
                  2018-03-20 08:19:15,539 - INFO - [(11228)-MainThread] cura.Settings.GlobalStack.addExtruder [73]: Extruder[custom_extruder_3 #2] added to [ARTEMIS] at position [2]
                  2018-03-20 08:19:15,542 - WARNING - [(11228)-MainThread] UM.Settings.ContainerStack.addMetaDataEntry [166]: Meta data with key machine was already added.
                  2018-03-20 08:19:15,544 - DEBUG - [(11228)-MainThread] LocalContainerProvider.LocalContainerProvider.loadContainer [50]: Loading container custom_extruder_8 #2
                  2018-03-20 08:19:15,546 - DEBUG - [(11228)-MainThread] LocalContainerProvider.LocalContainerProvider.loadContainer [50]: Loading container custom_extruder_8 #2_user
                  2018-03-20 08:19:15,548 - DEBUG - [(11228)-MainThread] LocalContainerProvider.LocalContainerProvider.loadContainer [50]: Loading container custom_extruder_8 #2_settings
                  2018-03-20 08:19:15,550 - DEBUG - [(11228)-MainThread] LocalContainerProvider.LocalContainerProvider.loadContainer [50]: Loading container custom_extruder_8
                  2018-03-20 08:19:15,552 - INFO - [(11228)-MainThread] cura.Settings.GlobalStack.addExtruder [73]: Extruder[custom_extruder_8 #2] added to [ARTEMIS] at position [7]
                  2018-03-20 08:19:15,553 - WARNING - [(11228)-MainThread] UM.Settings.ContainerStack.addMetaDataEntry [166]: Meta data with key machine was already added.
                  2018-03-20 08:19:15,555 - DEBUG - [(11228)-MainThread] LocalContainerProvider.LocalContainerProvider.loadContainer [50]: Loading container custom_extruder_6 #2
                  2018-03-20 08:19:15,558 - DEBUG - [(11228)-MainThread] LocalContainerProvider.LocalContainerProvider.loadContainer [50]: Loading container custom_extruder_6 #2_user
                  2018-03-20 08:19:15,560 - DEBUG - [(11228)-MainThread] LocalContainerProvider.LocalContainerProvider.loadContainer [50]: Loading container custom_extruder_6 #2_settings
                  2018-03-20 08:19:15,562 - DEBUG - [(11228)-MainThread] LocalContainerProvider.LocalContainerProvider.loadContainer [50]: Loading container custom_extruder_6
                  2018-03-20 08:19:15,565 - INFO - [(11228)-MainThread] cura.Settings.GlobalStack.addExtruder [73]: Extruder[custom_extruder_6 #2] added to [ARTEMIS] at position [5]
                  2018-03-20 08:19:15,566 - WARNING - [(11228)-MainThread] UM.Settings.ContainerStack.addMetaDataEntry [166]: Meta data with key machine was already added.
                  2018-03-20 08:19:15,567 - DEBUG - [(11228)-MainThread] LocalContainerProvider.LocalContainerProvider.loadContainer [50]: Loading container custom_extruder_2 #2
                  2018-03-20 08:19:15,569 - DEBUG - [(11228)-MainThread] LocalContainerProvider.LocalContainerProvider.loadContainer [50]: Loading container custom_extruder_2 #2_user
                  2018-03-20 08:19:15,571 - DEBUG - [(11228)-MainThread] LocalContainerProvider.LocalContainerProvider.loadContainer [50]: Loading container custom_extruder_2 #2_settings
                  2018-03-20 08:19:15,573 - DEBUG - [(11228)-MainThread] LocalContainerProvider.LocalContainerProvider.loadContainer [50]: Loading container custom_extruder_2
                  2018-03-20 08:19:15,576 - INFO - [(11228)-MainThread] cura.Settings.GlobalStack.addExtruder [73]: Extruder[custom_extruder_2 #2] added to [ARTEMIS] at position [1]
                  2018-03-20 08:19:15,577 - WARNING - [(11228)-MainThread] UM.Settings.ContainerStack.addMetaDataEntry [166]: Meta data with key machine was already added.
                  2018-03-20 08:19:15,579 - DEBUG - [(11228)-MainThread] LocalContainerProvider.LocalContainerProvider.loadContainer [50]: Loading container custom_extruder_5 #2
                  2018-03-20 08:19:15,581 - DEBUG - [(11228)-MainThread] LocalContainerProvider.LocalContainerProvider.loadContainer [50]: Loading container custom_extruder_5 #2_user
                  2018-03-20 08:19:15,583 - DEBUG - [(11228)-MainThread] LocalContainerProvider.LocalContainerProvider.loadContainer [50]: Loading container custom_extruder_5 #2_settings
                  2018-03-20 08:19:15,585 - DEBUG - [(11228)-MainThread] LocalContainerProvider.LocalContainerProvider.loadContainer [50]: Loading container custom_extruder_5
                  2018-03-20 08:19:15,588 - INFO - [(11228)-MainThread] cura.Settings.GlobalStack.addExtruder [73]: Extruder[custom_extruder_5 #2] added to [ARTEMIS] at position [4]
                  2018-03-20 08:19:15,589 - WARNING - [(11228)-MainThread] UM.Settings.ContainerStack.addMetaDataEntry [166]: Meta data with key machine was already added.
                  2018-03-20 08:19:15,591 - DEBUG - [(11228)-MainThread] LocalContainerProvider.LocalContainerProvider.loadContainer [50]: Loading container custom_extruder_1 #2
                  2018-03-20 08:19:15,594 - DEBUG - [(11228)-MainThread] LocalContainerProvider.LocalContainerProvider.loadContainer [50]: Loading container custom_extruder_1 #2_user
                  2018-03-20 08:19:15,596 - DEBUG - [(11228)-MainThread] LocalContainerProvider.LocalContainerProvider.loadContainer [50]: Loading container custom_extruder_1_se300_pla_defaut
                  2018-03-20 08:19:15,599 - DEBUG - [(11228)-MainThread] LocalContainerProvider.LocalContainerProvider.loadContainer [50]: Loading container generic_pla_175
                  2018-03-20 08:19:15,603 - DEBUG - [(11228)-MainThread] XmlMaterialProfile.XmlMaterialProfile.deserialize [544]: Found definition for machine ID imade3d_jellybox
                  2018-03-20 08:19:15,612 - DEBUG - [(11228)-MainThread] XmlMaterialProfile.XmlMaterialProfile.deserialize [544]: Found definition for machine ID cartesio
                  2018-03-20 08:19:15,621 - DEBUG - [(11228)-MainThread] LocalContainerProvider.LocalContainerProvider.loadContainer [50]: Loading container custom_extruder_1 #2_settings
                  2018-03-20 08:19:15,623 - DEBUG - [(11228)-MainThread] LocalContainerProvider.LocalContainerProvider.loadContainer [50]: Loading container custom_extruder_1
                  2018-03-20 08:19:15,626 - INFO - [(11228)-MainThread] cura.Settings.GlobalStack.addExtruder [73]: Extruder[custom_extruder_1 #2] added to [ARTEMIS] at position [0]
                  2018-03-20 08:19:15,627 - WARNING - [(11228)-MainThread] UM.Settings.ContainerStack.addMetaDataEntry [166]: Meta data with key machine was already added.
                  2018-03-20 08:19:15,629 - WARNING - [(11228)-MainThread] cura.Settings.GlobalStack.addExtruder [69]: Extruder [custom_extruder_4 #2] has already been added to this stack [ARTEMIS]
                  2018-03-20 08:19:15,630 - WARNING - [(11228)-MainThread] UM.Settings.ContainerStack.addMetaDataEntry [166]: Meta data with key machine was already added.
                  2018-03-20 08:19:15,631 - WARNING - [(11228)-MainThread] cura.Settings.ExtruderManager.registerExtruder [223]: Extruder [custom_extruder_4 #2] has already been registered on machine [ARTEMIS], not doing anything
                  2018-03-20 08:19:15,632 - WARNING - [(11228)-MainThread] cura.Settings.GlobalStack.addExtruder [69]: Extruder [custom_extruder_7 #2] has already been added to this stack [ARTEMIS]
                  2018-03-20 08:19:15,633 - WARNING - [(11228)-MainThread] UM.Settings.ContainerStack.addMetaDataEntry [166]: Meta data with key machine was already added.
                  2018-03-20 08:19:15,634 - WARNING - [(11228)-MainThread] cura.Settings.ExtruderManager.registerExtruder [223]: Extruder [custom_extruder_7 #2] has already been registered on machine [ARTEMIS], not doing anything
                  2018-03-20 08:19:15,635 - WARNING - [(11228)-MainThread] cura.Settings.GlobalStack.addExtruder [69]: Extruder [custom_extruder_3 #2] has already been added to this stack [ARTEMIS]
                  2018-03-20 08:19:15,636 - WARNING - [(11228)-MainThread] UM.Settings.ContainerStack.addMetaDataEntry [166]: Meta data with key machine was already added.
                  2018-03-20 08:19:15,637 - WARNING - [(11228)-MainThread] cura.Settings.ExtruderManager.registerExtruder [223]: Extruder [custom_extruder_3 #2] has already been registered on machine [ARTEMIS], not doing anything
                  2018-03-20 08:19:15,639 - WARNING - [(11228)-MainThread] cura.Settings.GlobalStack.addExtruder [69]: Extruder [custom_extruder_8 #2] has already been added to this stack [ARTEMIS]
                  2018-03-20 08:19:15,640 - WARNING - [(11228)-MainThread] UM.Settings.ContainerStack.addMetaDataEntry [166]: Meta data with key machine was already added.
                  2018-03-20 08:19:15,641 - WARNING - [(11228)-MainThread] cura.Settings.ExtruderManager.registerExtruder [223]: Extruder [custom_extruder_8 #2] has already been registered on machine [ARTEMIS], not doing anything
                  2018-03-20 08:19:15,642 - WARNING - [(11228)-MainThread] cura.Settings.GlobalStack.addExtruder [69]: Extruder [custom_extruder_6 #2] has already been added to this stack [ARTEMIS]
                  2018-03-20 08:19:15,643 - WARNING - [(11228)-MainThread] UM.Settings.ContainerStack.addMetaDataEntry [166]: Meta data with key machine was already added.
                  2018-03-20 08:19:15,644 - WARNING - [(11228)-MainThread] cura.Settings.ExtruderManager.registerExtruder [223]: Extruder [custom_extruder_6 #2] has already been registered on machine [ARTEMIS], not doing anything
                  2018-03-20 08:19:15,645 - WARNING - [(11228)-MainThread] cura.Settings.GlobalStack.addExtruder [69]: Extruder [custom_extruder_2 #2] has already been added to this stack [ARTEMIS]
                  2018-03-20 08:19:15,646 - WARNING - [(11228)-MainThread] UM.Settings.ContainerStack.addMetaDataEntry [166]: Meta data with key machine was already added.
                  2018-03-20 08:19:15,647 - WARNING - [(11228)-MainThread] cura.Settings.ExtruderManager.registerExtruder [223]: Extruder [custom_extruder_2 #2] has already been registered on machine [ARTEMIS], not doing anything
                  2018-03-20 08:19:15,648 - WARNING - [(11228)-MainThread] cura.Settings.GlobalStack.addExtruder [69]: Extruder [custom_extruder_5 #2] has already been added to this stack [ARTEMIS]
                  2018-03-20 08:19:15,649 - WARNING - [(11228)-MainThread] UM.Settings.ContainerStack.addMetaDataEntry [166]: Meta data with key machine was already added.
                  2018-03-20 08:19:15,650 - WARNING - [(11228)-MainThread] cura.Settings.ExtruderManager.registerExtruder [223]: Extruder [custom_extruder_5 #2] has already been registered on machine [ARTEMIS], not doing anything
                  2018-03-20 08:19:15,651 - WARNING - [(11228)-MainThread] cura.Settings.GlobalStack.addExtruder [69]: Extruder [custom_extruder_1 #2] has already been added to this stack [ARTEMIS]
                  2018-03-20 08:19:15,652 - WARNING - [(11228)-MainThread] UM.Settings.ContainerStack.addMetaDataEntry [166]: Meta data with key machine was already added.
                  2018-03-20 08:19:15,653 - WARNING - [(11228)-MainThread] cura.Settings.ExtruderManager.registerExtruder [223]: Extruder [custom_extruder_1 #2] has already been registered on machine [ARTEMIS], not doing anything
                  2018-03-20 08:19:15,658 - DEBUG - [(11228)-MainThread] LocalContainerProvider.LocalContainerProvider.loadContainer [50]: Loading container fdmprinter
                  2018-03-20 08:19:16,262 - DEBUG - [(11228)-MainThread] cura.Settings.MachineManager._checkStacksHaveErrors [423]: Checking 2 stacks for errors took 0.33 s
                  2018-03-20 08:19:16,695 - DEBUG - [(11228)-MainThread] cura.Settings.MachineManager._checkStacksHaveErrors [423]: Checking 2 stacks for errors took 0.33 s
                  2018-03-20 08:19:17,134 - DEBUG - [(11228)-MainThread] UM.Qt.Bindings.Theme.load [172]: Loading theme file: C:\Program Files\Ultimaker Cura 3.2\resources\themes\cura-dark\theme.json
                  2018-03-20 08:19:17,136 - DEBUG - [(11228)-MainThread] UM.Qt.Bindings.Theme.load [172]: Loading theme file: C:\Program Files\Ultimaker Cura 3.2\resources\themes\cura-light\theme.json
                  2018-03-20 08:19:17,230 - DEBUG - [(11228)-MainThread] UM.Qt.Bindings.Theme.load [240]: Loaded theme C:\Program Files\Ultimaker Cura 3.2\resources\themes\cura-light
                  2018-03-20 08:19:17,232 - DEBUG - [(11228)-MainThread] UM.Qt.Bindings.Theme.load [240]: Loaded theme C:\Program Files\Ultimaker Cura 3.2\resources\themes\cura-dark
                  2018-03-20 08:19:17,388 - DEBUG - [(11228)-MainThread] UM.Controller.setActiveView [92]: Setting active view to SolidView
                  2018-03-20 08:19:18,656 - DEBUG - [(11228)-MainThread] UM3NetworkPrinting.DiscoverUM3Action._createAdditionalComponentsView [136]: Creating additional ui components for UM3.
                  2018-03-20 08:19:18,681 - DEBUG - [(11228)-MainThread] UM3NetworkPrinting.DiscoverUM3Action.startDiscovery [36]: Starting printer discovery.
                  2018-03-20 08:19:18,694 - DEBUG - [(11228)-MainThread] UM.Mesh.MeshData.calculateNormalsFromIndexedVertices [444]: Calculating normals took 0.0010008811950683594 seconds
                  2018-03-20 08:19:18,715 - DEBUG - [(11228)-MainThread] UM.Controller.setActiveStage [155]: Setting active stage to PrepareStage
                  2018-03-20 08:19:19,271 - DEBUG - [(11228)-MainThread] LocalContainerProvider.LocalContainerProvider.loadContainer [50]: Loading container custom_extruder_1_se300_abs_default
                  2018-03-20 08:19:19,275 - DEBUG - [(11228)-MainThread] cura.Settings.MachineManager._onInstanceContainersChanged [365]: Connecting profiles model…
                  2018-03-20 08:19:19,276 - DEBUG - [(11228)-MainThread] LocalContainerProvider.LocalContainerProvider.loadContainer [50]: Loading container custom_se300_pla_fine
                  2018-03-20 08:19:19,279 - DEBUG - [(11228)-MainThread] LocalContainerProvider.LocalContainerProvider.loadContainer [50]: Loading container custom_he280-pla-default
                  2018-03-20 08:19:19,284 - DEBUG - [(11228)-MainThread] LocalContainerProvider.LocalContainerProvider.loadContainer [50]: Loading container custom_se300_petg_default
                  2018-03-20 08:19:19,288 - DEBUG - [(11228)-MainThread] LocalContainerProvider.LocalContainerProvider.loadContainer [50]: Loading container custom_extruder_1_se300_pla_fast
                  2018-03-20 08:19:19,290 - DEBUG - [(11228)-MainThread] LocalContainerProvider.LocalContainerProvider.loadContainer [50]: Loading container custom_se300_pla_fast
                  2018-03-20 08:19:19,293 - DEBUG - [(11228)-MainThread] LocalContainerProvider.LocalContainerProvider.loadContainer [50]: Loading container custom_se300_abs_default
                  2018-03-20 08:19:19,297 - DEBUG - [(11228)-MainThread] LocalContainerProvider.LocalContainerProvider.loadContainer [50]: Loading container custom_extruder_1_se300_spiral_vase
                  2018-03-20 08:19:19,299 - DEBUG - [(11228)-MainThread] LocalContainerProvider.LocalContainerProvider.loadContainer [50]: Loading container custom_extruder_1_se300_petg_default
                  2018-03-20 08:19:19,301 - DEBUG - [(11228)-MainThread] LocalContainerProvider.LocalContainerProvider.loadContainer [50]: Loading container custom_fdmextruder_he280-pla-default
                  2018-03-20 08:19:19,303 - DEBUG - [(11228)-MainThread] LocalContainerProvider.LocalContainerProvider.loadContainer [50]: Loading container custom_extruder_1_se300_pla_fine
                  2018-03-20 08:19:19,305 - DEBUG - [(11228)-MainThread] LocalContainerProvider.LocalContainerProvider.loadContainer [50]: Loading container custom_se300_spiral_vase
                  2018-03-20 08:19:19,315 - DEBUG - [(11228)-MainThread] LocalContainerProvider.LocalContainerProvider.loadContainer [50]: Loading container low
                  2018-03-20 08:19:19,317 - DEBUG - [(11228)-MainThread] LocalContainerProvider.LocalContainerProvider.loadContainer [50]: Loading container high
                  2018-03-20 08:19:19,319 - DEBUG - [(11228)-MainThread] LocalContainerProvider.LocalContainerProvider.loadContainer [50]: Loading container draft
                  2018-03-20 08:19:19,321 - DEBUG - [(11228)-MainThread] LocalContainerProvider.LocalContainerProvider.loadContainer [50]: Loading container extra_coarse
                  2018-03-20 08:19:19,323 - DEBUG - [(11228)-MainThread] LocalContainerProvider.LocalContainerProvider.loadContainer [50]: Loading container coarse
                  2018-03-20 08:19:19,627 - DEBUG - [(11228)-MainThread] UM.Mesh.MeshData.calculateNormalsFromIndexedVertices [444]: Calculating normals took 0.0020012855529785156 seconds
                  2018-03-20 08:19:19,716 - DEBUG - [(11228)-MainThread] UM.Mesh.MeshData.calculateNormalsFromIndexedVertices [444]: Calculating normals took 0.0010008811950683594 seconds
                  2018-03-20 08:19:20,149 - DEBUG - [(11228)-MainThread] cura.Settings.MachineManager._checkStacksHaveErrors [423]: Checking 2 stacks for errors took 0.32 s
                  2018-03-20 08:19:20,408 - DEBUG - [(11228)-MainThread] UM.Mesh.MeshData.calculateNormalsFromIndexedVertices [444]: Calculating normals took 0.0015015602111816406 seconds
                  2018-03-20 08:19:20,845 - DEBUG - [(11228)-MainThread] cura.Settings.MachineManager._checkStacksHaveErrors [423]: Checking 2 stacks for errors took 0.32 s
                  2018-03-20 08:19:21,373 - DEBUG - [(11228)-MainThread] UM.Mesh.MeshData.calculateNormalsFromIndexedVertices [444]: Calculating normals took 0.0010018348693847656 seconds
                  2018-03-20 08:19:21,602 - DEBUG - [(11228)-MainThread] UM.Qt.QtRenderer._initialize [184]: Support for Vertex Array Objects: True
                  2018-03-20 08:19:21,609 - DEBUG - [(11228)-MainThread] UM.View.GL.OpenGL.init [92]: Initialized OpenGL subsystems.
                  2018-03-20 08:19:21,610 - DEBUG - [(11228)-MainThread] UM.View.GL.OpenGL.init [93]: OpenGL Version: 4.1.0 NVIDIA 390.65
                  2018-03-20 08:19:21,611 - DEBUG - [(11228)-MainThread] UM.View.GL.OpenGL.init [94]: OpenGL Vendor: NVIDIA Corporation
                  2018-03-20 08:19:21,612 - DEBUG - [(11228)-MainThread] UM.View.GL.OpenGL.init [95]: OpenGL Renderer: GeForce GT 610/PCIe/SSE2
                  2018-03-20 08:19:21,613 - DEBUG - [(11228)-MainThread] UM.View.GL.ShaderProgram.load [55]: Loading shader file [C:\Program Files\Ultimaker Cura 3.2\resources\shaders\default.shader]…
                  2018-03-20 08:19:21,615 - DEBUG - [(11228)-MainThread] UM.View.GL.ShaderProgram.load [55]: Loading shader file [C:\Program Files\Ultimaker Cura 3.2\resources\shaders\selection.shader]…
                  2018-03-20 08:19:21,617 - DEBUG - [(11228)-MainThread] UM.View.GL.ShaderProgram.load [55]: Loading shader file [C:\Program Files\Ultimaker Cura 3.2\resources\shaders\default.shader]…
                  2018-03-20 08:19:21,620 - DEBUG - [(11228)-MainThread] UM.View.GL.ShaderProgram.load [55]: Loading shader file [C:\Program Files\Ultimaker Cura 3.2\resources\shaders\composite.shader]…
                  2018-03-20 08:19:21,623 - DEBUG - [(11228)-MainThread] UM.View.GL.ShaderProgram.load [55]: Loading shader file [C:\Program Files\Ultimaker Cura 3.2\resources\shaders\overhang.shader]…
                  2018-03-20 08:19:21,626 - DEBUG - [(11228)-MainThread] UM.View.GL.ShaderProgram.load [55]: Loading shader file [C:\Program Files\Ultimaker Cura 3.2\resources\shaders\striped.shader]…
                  2018-03-20 08:19:21,629 - DEBUG - [(11228)-MainThread] UM.View.GL.ShaderProgram.load [55]: Loading shader file [C:\Program Files\Ultimaker Cura 3.2\resources\shaders\transparent_object.shader]…
                  2018-03-20 08:19:21,631 - DEBUG - [(11228)-MainThread] UM.View.GL.ShaderProgram.load [55]: Loading shader file [C:\Program Files\Ultimaker Cura 3.2\resources\shaders\striped.shader]…
                  2018-03-20 08:19:21,639 - DEBUG - [(11228)-MainThread] UM.View.GL.ShaderProgram.load [55]: Loading shader file [C:\Program Files\Ultimaker Cura 3.2\resources\shaders\default.shader]…
                  2018-03-20 08:19:21,642 - DEBUG - [(11228)-MainThread] UM.View.GL.ShaderProgram.load [55]: Loading shader file [C:\Program Files\Ultimaker Cura 3.2\resources\shaders\grid.shader]…
                  2018-03-20 08:19:21,645 - DEBUG - [(11228)-MainThread] UM.View.GL.ShaderProgram.load [55]: Loading shader file [C:\Program Files\Ultimaker Cura 3.2\resources\shaders\platform.shader]…
                  2018-03-20 08:19:22,000 - DEBUG - [(11228)-MainThread] cura.Settings.MachineManager._checkStacksHaveErrors [423]: Checking 2 stacks for errors took 0.32 s
                  2018-03-20 08:19:22,238 - DEBUG - [(11228)-MainThread] UM.Mesh.MeshData.calculateNormalsFromIndexedVertices [444]: Calculating normals took 0.0020017623901367188 seconds
                  2018-03-20 08:19:22,767 - DEBUG - [(11228)-MainThread] cura.Settings.MachineManager._checkStacksHaveErrors [423]: Checking 2 stacks for errors took 0.32 s
                  2018-03-20 08:19:23,262 - DEBUG - [(11228)-MainThread] CuraEngineBackend.CuraEngineBackend.slice [197]: starting to slice!
                  2018-03-20 08:19:23,262 - DEBUG - [(11228)-MainThread] CuraEngineBackend.CuraEngineBackend.slice [214]: Going to slice build plate [0]!
                  2018-03-20 08:19:23,263 - DEBUG - [(11228)-MainThread] CuraEngineBackend.CuraEngineBackend.slice [218]: Build plate 0 has no objects to be sliced, skipping
                  2018-03-20 08:19:31,705 - DEBUG - [(15140)-Thread-9] USBPrinting.USBPrinterOutputDevice._connect [356]: Attempting to connect to printer with serial COM5 on baud rate 250000
                  2018-03-20 08:19:32,198 - DEBUG - [(11228)-MainThread] AutoSave.AutoSave._onTimeout [71]: Autosaving preferences, instances and profiles
                  2018-03-20 08:19:38,220 - DEBUG - [(15140)-Thread-9] USBPrinting.USBPrinterOutputDevice._connect [356]: Attempting to connect to printer with serial COM5 on baud rate 230400
                  2018-03-20 08:19:44,735 - DEBUG - [(15140)-Thread-9] USBPrinting.USBPrinterOutputDevice._connect [356]: Attempting to connect to printer with serial COM5 on baud rate 57600
                  2018-03-20 08:19:47,727 - INFO - [(11228)-MainThread] UM.OutputDevice.OutputDeviceManager.addOutputDevice [103]: Output Device DuetRRF-print already added
                  2018-03-20 08:19:47,730 - INFO - [(11228)-MainThread] UM.OutputDevice.OutputDeviceManager.addOutputDevice [103]: Output Device DuetRRF-simulate already added
                  2018-03-20 08:19:47,732 - INFO - [(11228)-MainThread] UM.OutputDevice.OutputDeviceManager.addOutputDevice [103]: Output Device DuetRRF-upload already added
                  2018-03-20 08:19:51,251 - DEBUG - [(15140)-Thread-9] USBPrinting.USBPrinterOutputDevice._connect [356]: Attempting to connect to printer with serial COM5 on baud rate 38400
                  2018-03-20 08:19:57,726 - DEBUG - [(11228)-MainThread] AutoSave.AutoSave._onTimeout [71]: Autosaving preferences, instances and profiles
                  2018-03-20 08:19:57,765 - DEBUG - [(15140)-Thread-9] USBPrinting.USBPrinterOutputDevice._connect [356]: Attempting to connect to printer with serial COM5 on baud rate 19200
                  2018-03-20 08:19:59,012 - DEBUG - [(2432)-Thread-5] UM.Mesh.MeshData.calculateNormalsFromVertices [421]: Calculating normals took 0.0010001659393310547 seconds
                  2018-03-20 08:19:59,013 - DEBUG - [(2432)-Thread-5] STLReader.STLReader.read [79]: Loaded a mesh with 924 vertices
                  2018-03-20 08:19:59,032 - DEBUG - [(11228)-MainThread] UM.Mesh.MeshData.approximateConvexHull [388]: approximateConvexHull(target_count=1024) Calculating 3D convex hull took 0.01901841163635254 seconds. 90 input vertices. 90 output vertices.
                  2018-03-20 08:19:59,034 - DEBUG - [(2432)-Thread-5] UM.FileHandler.ReadFileJob.run [68]: Loading file took 0.0 seconds
                  2018-03-20 08:19:59,056 - DEBUG - [(2432)-Thread-5] UM.Mesh.MeshData.approximateConvexHull [388]: approximateConvexHull(target_count=1024) Calculating 3D convex hull took 0.01901984214782715 seconds. 90 input vertices. 90 output vertices.
                  2018-03-20 08:19:59,068 - WARNING - [(11228)-MainThread] UM.Qt.QtApplication.__onQmlWarning [267]: file:///C:/Program Files/Ultimaker Cura 3.2/qml/QtQuick/Controls/TextField.qml:638:5: QML TextInputWithHandles: Binding loop detected for property "text"
                  2018-03-20 08:19:59,137 - DEBUG - [(11228)-MainThread] UM.View.GL.ShaderProgram.load [55]: Loading shader file [C:\Program Files\Ultimaker Cura 3.2\resources\shaders\transparent_object.shader]…
                  2018-03-20 08:19:59,451 - DEBUG - [(11228)-MainThread] UM.Mesh.MeshData.calculateNormalsFromIndexedVertices [444]: Calculating normals took 0.0030028820037841797 seconds
                  2018-03-20 08:19:59,617 - DEBUG - [(11228)-MainThread] CuraEngineBackend.CuraEngineBackend.slice [197]: starting to slice!
                  2018-03-20 08:19:59,618 - DEBUG - [(11228)-MainThread] CuraEngineBackend.CuraEngineBackend.slice [214]: Going to slice build plate [0]!
                  2018-03-20 08:20:02,008 - DEBUG - [(11228)-MainThread] CuraEngineBackend.CuraEngineBackend._onStartSliceCompleted [381]: Sending slice message took 2.388291358947754 seconds
                  2018-03-20 08:20:02,137 - DEBUG - [(1964)-Thread-13] UM.Backend.Backend._backendLog [90]: [Backend] [WARNING] Setting an unregistered setting print_bed_temperature to 75
                  2018-03-20 08:20:02,139 - DEBUG - [(1964)-Thread-13] UM.Backend.Backend._backendLog [90]: [Backend] [WARNING] Setting an unregistered setting initial_extruder_nr to 0
                  2018-03-20 08:20:02,142 - DEBUG - [(1964)-Thread-13] UM.Backend.Backend._backendLog [90]: [Backend] [WARNING] Setting an unregistered setting print_temperature to 205
                  2018-03-20 08:20:02,144 - DEBUG - [(1964)-Thread-13] UM.Backend.Backend._backendLog [90]: [Backend] [WARNING] Setting an unregistered setting time to 08:19:59
                  2018-03-20 08:20:02,145 - DEBUG - [(1964)-Thread-13] UM.Backend.Backend._backendLog [90]: [Backend] [WARNING] Setting an unregistered setting day to Tue
                  2018-03-20 08:20:02,146 - DEBUG - [(1964)-Thread-13] UM.Backend.Backend._backendLog [90]: [Backend] [WARNING] Setting an unregistered setting date to 20-03-2018
                  2018-03-20 08:20:02,147 - DEBUG - [(1964)-Thread-13] UM.Backend.Backend._backendLog [90]: [Backend] [WARNING] -s wireframe_flow="100" -s machine_settings="0" -s date="20-03-2018" -s max_skin_angle_for_expansion="90" -s support_bottom_density="100" -s cooling="0" -s support_tree_wall_thickness="0.4" -s raft_speed="30.0" -s meshfix="0" -s speed="0" -s speed_wall="40.0" -s acceleration_wall="3000" -s wireframe_printspeed="5" -s support_skip_zag_per_mm="20" -s travel_compensate_overlapping_walls_enabled="True" -s experimental="0" -s top_thickness="0.8" -s line_width="0.4" -s bottom_thickness="0.8" -s switch_extruder_retraction_speeds="20" -s command_line_settings="0" -s jerk_print="20" -s machine_head_polygon="[[-1, 1], [-1, -1], [1, -1], [1, 1]]" -s jerk_layer_0="20" -s time="08:19:59" -s wall_extruder_nr="-1" -s speed_support="35" -s brim_width="8.0" -s jerk_wall="20" -s raft_acceleration="3000" -s support_interface_pattern="lines" -s support_interface_line_width="0.4" -s infill_sparse_density="15" -s print_temperature="205" -s resolution="0" -s skin_overlap="5" -s skin_preshrink="1.2000000000000002" -s support_z_distance="0.15" -s support_interface_enable="False" -s shell="0" -s machine_use_extruder_offset_to_offset_coords="True" -s retraction_hop_only_when_collides="False" -s start_layers_at_same_position="False" -s jerk_prime_tower="20" -s travel_avoid_other_parts="True" -s jerk_support_roof="20" -s jerk_print_layer_0="20" -s material_print_temp_prepend="True" -s jerk_travel="30" -s jerk_roofing="20" -s support_bottom_distance="0.15" -s jerk_wall_x="20" -s speed_layer_0="25" -s jerk_wall_0="20" -s machine_max_jerk_e="5.0" -s jerk_enabled="False" -s blackmagic="0" -s acceleration_support_roof="3000" -s prime_tower_enable="False" -s acceleration_wall_x="3000" -s support_bottom_line_width="0.5" -s max_feedrate_z_override="0" -s skirt_brim_minimal_length="200" -s raft_smoothing="5" -s cool_fan_full_at_height="0.3" -s conical_overhang_angle="50" -s skin_no_small_gaps_heuristic="True" -s speed_print="60" -s layer_start_x="0.0" -s speed_wall_x="50.0" -s speed_wall_0="45.0" -s speed_infill="60" -s switch_extruder_retraction_amount="16" -s spaghetti_infill_stepped="True" -s prime_tower_size="20" -s retraction_retract_speed="45" -s machine_nozzle_heat_up_speed="2.0" -s extruder_prime_pos_x="0" -s acceleration_support_interface="3000" -s print_bed_temperature="75" -s material_surface_energy="100" -s travel_avoid_distance="0.625" -s jerk_ironing="20" -s retraction_extra_prime_amount="0" -s cross_infill_pocket_size="8.0" -s material_print_temperature_layer_0="205" -s material_print_temperature="205" -s jerk_topbottom="20" -s draft_shield_height="10" -s min_skin_width_for_expansion="1.2246467991473532e-16" -s flow_rate_extrusion_offset_factor="100" -s speed_travel_layer_0="250" -s wireframe_roof_outer_delay="0.2" -s top_skin_expand_distance="1.2000000000000002" -s bottom_skin_preshrink="1.2000000000000002" -s extruder_prime_pos_abs="False" -s top_skin_preshrink="1.2000000000000002" -s adhesion_extruder_nr="0" -s infill_before_walls="False" -s gradual_infill_steps="0" -s infill_sparse_thickness="0.2" -s retraction_hop_enabled="True" -s layer_start_y="0.0" -s wireframe_flow_connection="100" -s skin_overlap_mm="0.02" -s speed_equalize_flow_enabled="False" -s mold_angle="40" -s acceleration_layer_0="3000" -s machine_start_gcode="G28 ;Home
                  2018-03-20 08:20:02,148 - DEBUG - [(1964)-Thread-13] UM.Backend.Backend._backendLog [90]: [Backend] G1 Z15.0 F6000 ;Move the platform down 15mm
                  2018-03-20 08:20:02,149 - DEBUG - [(1964)-Thread-13] UM.Backend.Backend._backendLog [90]: [Backend] ;Prime the extruder
                  2018-03-20 08:20:02,150 - DEBUG - [(1964)-Thread-13] UM.Backend.Backend._backendLog [90]: [Backend] G92 E0
                  2018-03-20 08:20:02,151 - DEBUG - [(1964)-Thread-13] UM.Backend.Backend._backendLog [90]: [Backend] G1 F200 E3
                  2018-03-20 08:20:02,152 - DEBUG - [(1964)-Thread-13] UM.Backend.Backend._backendLog [90]: [Backend] G92 E0" -s wireframe_up_half_speed="0.3" -s machine_firmware_retract="False" -s infill_overlap_mm="0.04" -s outer_inset_first="False" -s raft_interface_line_spacing="1.0" -s infill_offset_x="0" -s magic_fuzzy_skin_enabled="False" -s infill_angles="[ ]" -s cross_infill_apply_pockets_alternatingly="True" -s zig_zaggify_infill="True" -s acceleration_topbottom="3000" -s material_extrusion_cool_down_speed="0.7" -s infill_pattern="cubic" -s support_tower_roof_angle="65" -s adaptive_layer_height_enabled="False" -s material_adhesion_tendency="10" -s machine_max_feedrate_x="500" -s travel_compensate_overlapping_walls_0_enabled="True" -s support="0" -s material_bed_temp_prepend="True" -s support_bottom_pattern="lines" -s machine_depth="290" -s speed_support_roof="23.333333333333332" -s wireframe_top_delay="0" -s acceleration_skirt_brim="3000" -s optimize_wall_printing_order="False" -s retraction_hop="1" -s machine_max_feedrate_z="5" -s acceleration_travel_layer_0="5000.0" -s layer_height="0.2" -s prime_tower_purge_volume="0" -s sub_div_rad_add="0.4" -s support_roof_line_width="0.5" -s machine_max_feedrate_y="500" -s meshfix_maximum_resolution="0.01" -s machine_max_acceleration_y="9000" -s machine_show_variants="False" -s gradual_support_infill_step_height="1" -s alternate_extra_perimeter="False" -s machine_nozzle_size="0.4" -s speed_prime_tower="60" -s machine_heat_zone_length="16" -s support_zag_skip_count="10" -s cutting_mesh="False" -s roofing_layer_count="0" -s wireframe_drag_along="0.6" -s machine_heated_bed="True" -s roofing_extruder_nr="-1" -s switch_extruder_retraction_speed="20" -s gantry_height="99999999999" -s ironing_inset="0.2" -s layer_0_z_overlap="0.15" -s wireframe_bottom_delay="0" -s acceleration_wall_0="3000" -s mesh_rotation_matrix="[[1,0,0], [0,1,0], [0,0,1]]" -s retraction_prime_speed="45" -s machine_nozzle_temp_enabled="True" -s gradual_infill_step_height="2.0" -s meshfix_keep_open_polygons="False" -s mesh_position_x="0" -s machine_width="290" -s top_layers="10" -s day="Tue" -s material_bed_temperature_layer_0="80" -s machine_max_acceleration_e="10000" -s support_bottom_height="1" -s coasting_speed="90" -s speed_equalize_flow_max="150" -s machine_nozzle_id="unknown" -s layer_height_0="0.3" -s support_conical_min_width="5.0" -s machine_nozzle_cool_down_speed="2.0" -s acceleration_travel="5000" -s raft_surface_jerk="20" -s multiple_mesh_overlap="0.15" -s material_diameter="1.75" -s top_bottom_extruder_nr="-1" -s machine_max_acceleration_z="100" -s acceleration_ironing="3000" -s extruder_prime_pos_z="0" -s infill_wipe_dist="0.1" -s machine_nozzle_tip_outer_diameter="1" -s wall_thickness="0.8" -s min_infill_area="0" -s machine_height="540" -s support_connect_zigzags="True" -s wall_x_extruder_nr="-1" -s brim_outside_only="True" -s infill_line_distance="8.0" -s machine_end_gcode="M104 S0
                  2018-03-20 08:20:02,153 - DEBUG - [(1964)-Thread-13] UM.Backend.Backend._backendLog [90]: [Backend] M140 S0
                  2018-03-20 08:20:02,154 - DEBUG - [(1964)-Thread-13] UM.Backend.Backend._backendLog [90]: [Backend] ;Retract the filament
                  2018-03-20 08:20:02,156 - DEBUG - [(1964)-Thread-13] UM.Backend.Backend._backendLog [90]: [Backend] G92 E1
                  2018-03-20 08:20:02,157 - DEBUG - [(1964)-Thread-13] UM.Backend.Backend._backendLog [90]: [Backend] G1 E-1 F300
                  2018-03-20 08:20:02,158 - DEBUG - [(1964)-Thread-13] UM.Backend.Backend._backendLog [90]: [Backend] G28 X0 Y0
                  2018-03-20 08:20:02,159 - DEBUG - [(1964)-Thread-13] UM.Backend.Backend._backendLog [90]: [Backend] M84" -s skirt_brim_line_width="0.4" -s acceleration_support="3000" -s brim_line_count="3" -s machine_max_acceleration_x="9000" -s slicing_tolerance="middle" -s ooze_shield_dist="2" -s ironing_flow="10.0" -s infill_line_width="0.4" -s fill_outline_gaps="False" -s machine_filament_park_distance="16" -s acceleration_print_layer_0="3000" -s speed_roofing="45.0" -s material_standby_temperature="150" -s infill_extruder_nr="-1" -s skin_angles="[ ]" -s jerk_infill="20" -s acceleration_infill="3000" -s travel_retract_before_outer_wall="False" -s switch_extruder_prime_speed="20" -s raft_base_acceleration="3000" -s jerk_skirt_brim="20" -s z_seam_relative="False" -s machine_shape="elliptic" -s cool_fan_speed="100.0" -s speed_travel="400" -s alternate_carve_order="True" -s spaghetti_inset="0.2" -s cool_fan_full_layer="3" -s retraction_count_max="90" -s magic_fuzzy_skin_point_dist="0.8" -s material_bed_temp_wait="True" -s bottom_layers="10" -s machine_max_jerk_xy="20.0" -s wall_line_width_0="0.4" -s acceleration_enabled="False" -s skin_alternate_rotation="False" -s material_bed_temperature="75" -s prime_tower_line_width="0.4" -s machine_gcode_flavor="RepRap (RepRap)" -s wall_0_extruder_nr="-1" -s retraction_hop_after_extruder_switch="True" -s travel="0" -s material_flow_temp_graph="[[3.5,200],[7.0,240]]" -s material_print_temp_wait="True" -s wall_line_count="3" -s machine_minimum_feedrate="0.0" -s machine_name="Unknown" -s wall_line_width_x="0.4" -s raft_surface_line_width="0.4" -s wall_0_wipe_dist="0.2" -s machine_nozzle_expansion_angle="45" -s top_bottom_pattern="lines" -s support_line_width="0.4" -s machine_acceleration="4000" -s wall_0_inset="0" -s machine_center_is_zero="True" -s smooth_spiralized_contours="True" -s skin_line_width="0.4" -s raft_interface_jerk="20" -s retraction_amount="3.2" -s machine_max_jerk_z="0.4" -s z_seam_corner="z_seam_corner_inner" -s machine_max_feedrate_e="299792458000" -s travel_compensate_overlapping_walls_x_enabled="True" -s raft_base_line_width="0.8" -s support_top_distance="0.15" -s machine_min_cool_heat_time_window="50.0" -s spaghetti_infill_extra_volume="0" -s xy_offset="0" -s carve_multiple_volumes="False" -s jerk_support="20" -s ironing_line_spacing="0.1" -s skirt_brim_speed="25" -s material_flow="97" -s xy_offset_layer_0="0" -s z_seam_y="870" -s support_interface_extruder_nr="0" -s wireframe_fall_down="0.5" -s default_material_print_temperature="205" -s infill_mesh="False" -s retraction_enable="True" -s skin_outline_count="1" -s ironing_only_highest_layer="False" -s retraction_extrusion_window="3.2" -s speed_support_infill="35" -s retract_at_layer_change="False" -s machine_extruder_count="1" -s ironing_enabled="False" -s retraction_min_travel="1.5" -s speed_ironing="30.0" -s ironing_pattern="zigzag" -s cool_fan_enabled="True" -s cool_fan_speed_min="75" -s magic_fuzzy_skin_point_density="1.25" -s wireframe_enabled="False" -s cool_min_layer_time_fan_speed_max="20" -s ooze_shield_angle="60" -s cool_lift_head="False" -s support_enable="False" -s fill_perimeter_gaps="everywhere" -s support_infill_extruder_nr="0" -s speed_support_bottom="23.333333333333332" -s support_extruder_nr_layer_0="0" -s skirt_line_count="3" -s filter_out_tiny_gaps="True" -s support_tree_branch_diameter_angle="5" -s raft_surface_line_spacing="0.4" -s infill_hollow="False" -s top_bottom_pattern_0="lines" -s support_roof_extruder_nr="0" -s jerk_travel_layer_0="30.0" -s support_bottom_extruder_nr="0" -s support_type="everywhere" -s nozzle_disallowed_areas="[]" -s support_angle="40" -s support_pattern="zigzag" -s support_line_distance="2.0" -s cool_min_layer_time="15" -s wireframe_roof_inset="3" -s support_interface_height="1" -s initial_layer_line_width_factor="100.0" -s support_xy_distance="1" -s support_xy_overrides_z="z_overrides_xy" -s support_bottom_stair_step_height="0.3" -s support_bottom_stair_step_width="5.0" -s jerk_support_interface="20" -s machine_disallowed_areas="[]" -s acceleration_prime_tower="3000" -s support_infill_sparse_thickness="0.2" -s dual_pre_wipe="True" -s mold_width="5" -s gradual_support_infill_steps="0" -s support_roof_enable="False" -s support_bottom_enable="False" -s retraction_speed="45" -s support_roof_height="1" -s support_interface_skip_height="0.3" -s support_roof_line_distance="0.5" -s support_tree_branch_diameter="2" -s infill_overlap="10" -s support_bottom_line_distance="0.5" -s material="0" -s support_roof_pattern="lines" -s prime_tower_wipe_enabled="True" -s support_tower_diameter="3.0" -s support_join_distance="2.0" -s remove_empty_first_layers="True" -s support_minimal_diameter="3.0" -s infill_mesh_order="0" -s cool_fan_speed_max="100" -s support_mesh_drop_down="True" -s bottom_skin_expand_distance="1.2000000000000002" -s prime_blob_enable="True" -s extruder_prime_pos_y="0" -s support_infill_rate="20" -s adhesion_type="skirt" -s skirt_gap="3" -s support_interface_density="100" -s prime_tower_position_x="285.3" -s cool_fan_speed_0="0" -s raft_airgap="0.3" -s support_mesh="False" -s support_xy_distance_overhang="1.25" -s raft_surface_thickness="0.2" -s prime_tower_flow="97" -s raft_interface_thickness="0.30000000000000004" -s z_seam_type="shortest" -s raft_interface_line_width="0.8" -s raft_base_thickness="0.36" -s raft_base_line_spacing="1.6" -s raft_interface_speed="22.5" -s support_offset="0.2" -s raft_base_speed="22.5" -s raft_surface_acceleration="3000" -s platform_adhesion="0" -s speed_print_layer_0="25" -s raft_interface_acceleration="3000" -s raft_base_jerk="20" -s raft_surface_fan_speed="0" -s adaptive_layer_height_variation_step="0.01" -s draft_shield_dist="10" -s raft_interface_fan_speed="0" -s support_skip_some_zags="False" -s support_tree_enable="False" -s support_roof_density="100" -s meshfix_union_all="True" -s acceleration_support_infill="3000" -s meshfix_union_all_remove_holes="False" -s mold_enabled="False" -s mold_roof_height="0.5" -s magic_mesh_surface_mode="normal" -s anti_overhang_mesh="False" -s relative_extrusion="False" -s support_tree_angle="40" -s support_tree_collision_resolution="0.2" -s support_tree_wall_count="1" -s retraction_combing="off" -s raft_jerk="20" -s roofing_line_width="0.4" -s acceleration_support_bottom="3000" -s roofing_pattern="lines" -s infill_offset_y="0" -s roofing_angles="[ ]" -s raft_margin="15" -s infill_enable_travel_optimization="False" -s mesh_position_y="0" -s material_flow_dependent_temperature="False" -s conical_overhang_enabled="False" -s draft_shield_enabled="False" -s draft_shield_height_limitation="full" -s coasting_min_volume="0.8" -s spaghetti_infill_enabled="False" -s spaghetti_max_infill_angle="10" -s speed_topbottom="45.0" -s magic_spiralize="False" -s spaghetti_max_height="2.0" -s spaghetti_flow="20" -s machine_nozzle_head_distance="3" -s support_conical_enabled="False" -s support_conical_angle="30" -s jerk_support_bottom="20" -s magic_fuzzy_skin_thickness="0.3" -s acceleration_roofing="3000" -s flow_rate_max_extrusion_offset="0" -s mesh_position_z="0" -s wireframe_height="3" -s prime_tower_wall_thickness="1.0" -s ooze_shield_enabled="False" -s coasting_enable="True" -s wireframe_printspeed_bottom="5" -s wireframe_printspeed_up="5" -s prime_tower_position_y="265.3" -s z_seam_x="145.0" -s raft_surface_speed="30.0" -s wireframe_printspeed_down="5" -s raft_base_fan_speed="0" -s wireframe_printspeed_flat="5" -s wireframe_flow_flat="100" -s wireframe_flat_delay="0.1" -s wireframe_top_jump="0.6" -s coasting_volume="0.1" -s wireframe_strategy="compensate" -s wireframe_straight_before_down="20" -s print_sequence="all_at_once" -s support_use_towers="True" -s wireframe_roof_fall_down="2" -s speed_slowdown_layers="1" -s material_final_print_temperature="205" -s wireframe_roof_drag_along="0.8" -s wireframe_nozzle_clearance="1" -s meshfix_extensive_stitching="False" -s adaptive_layer_height_variation="0.1" -s speed_support_interface="23.333333333333332" -s adaptive_layer_height_threshold="200.0" -s center_object="False" -s raft_surface_layers="2" -s prime_tower_min_volume="10" -s support_extruder_nr="0" -s support_tree_branch_distance="4" -s expand_skins_expand_distance="1.2000000000000002" -s raft_fan_speed="0" -s acceleration_print="3000" -s jerk_support_infill="20" -s machine_head_with_fans_polygon="[[-20, 10], [-20, -10], [10, 10], [10, -10]]" -s wall_line_width="0.4" -s top_bottom_thickness="0.8" -s infill="0" -s dual="0" -s cool_min_speed="10" -s material_initial_print_temperature="205" -s initial_extruder_nr="0" -g -e0 -s jerk_support_interface="20" -s meshfix_union_all="True" -s coasting_enable="False" -s material_surface_energy="100" -s support_line_width="0.5" -s support_conical_angle="30" -s machine_settings="0" -s support_bottom_stair_step_width="5.0" -s spaghetti_flow="20" -s raft_surface_speed="30.0" -s xy_offset="0" -s raft_surface_acceleration="3000" -s max_skin_angle_for_expansion="90" -s speed_ironing="20.0" -s support_bottom_height="1" -s acceleration_support_bottom="3000" -s support_bottom_density="100" -s infill_line_distance="6.666666666666667" -s optimize_wall_printing_order="False" -s raft_base_jerk="20" -s z_seam_y="870" -s meshfix_union_all_remove_holes="False" -s support_roof_enable="False" -s travel="0" -s retraction_extrusion_window="3.2" -s blackmagic="0" -s xy_offset_layer_0="0" -s jerk_wall_x="20" -s support_tree_wall_thickness="0.5" -s jerk_support_bottom="20" -s raft_speed="30.0" -s center_object="False" -s cool_fan_speed_0="0" -s speed="0" -s layer_start_x="0.0" -s roofing_angles="[ ]" -s acceleration_travel_layer_0="5000.0" -s material_flow="100" -s retraction_prime_speed="45" -s roofing_layer_count="0" -s machine_nozzle_head_distance="3" -s prime_tower_line_width="0.5" -s acceleration_wall="3000" -s support_tower_diameter="3.0" -s z_seam_corner="z_seam_corner_inner" -s cool_fan_speed_min="75" -s infill_offset_y="0" -s material_print_temperature_layer_0="215" -s extruder_prime_pos_abs="False" -s material="0" -s default_material_print_temperature="210" -s acceleration_print_layer_0="3000" -s dual_pre_wipe="True" -s support_line_distance="2.5" -s retraction_min_travel="1.0" -s support="0" -s support_bottom_stair_step_height="0.3" -s support_bottom_enable="False" -s speed_infill="60" -s retraction_speed="45" -s retraction_amount="3.2" -s speed_prime_tower="60" -s top_thickness="0.8" -s skirt_gap="3" -s jerk_support_infill="20" -s bottom_skin_preshrink="1.0" -s support_xy_distance_overhang="1.25" -s travel_compensate_overlapping_walls_x_enabled="True" -s raft_interface_acceleration="3000" -s raft_surface_layers="2" -s fill_outline_gaps="True" -s ironing_flow="10.0" -s top_layers="4" -s machine_nozzle_temp_enabled="True" -s alternate_extra_perimeter="False" -s skirt_brim_speed="30.0" -s retraction_hop="1" -s prime_blob_enable="True" -s material_extrusion_cool_down_speed="0.7" -s roofing_line_width="0.5" -s line_width="0.5" -s ironing_pattern="zigzag" -s conical_overhang_enabled="False" -s bottom_thickness="0.8" -s support_infill_rate="20" -s jerk_support="20" -s speed_support_roof="23.333333333333332" -s infill_enable_travel_optimization="False" -s mold_roof_height="0.5" -s acceleration_topbottom="3000" -s raft_interface_speed="22.5" -s speed_equalize_flow_max="150" -s raft_base_line_spacing="2.0" -s switch_extruder_retraction_amount="16" -s switch_extruder_retraction_speeds="20" -s acceleration_support_infill="3000" -s support_skip_zag_per_mm="20" -s filter_out_tiny_gaps="True" -s raft_surface_fan_speed="0" -s cross_infill_apply_pockets_alternatingly="True" -s infill_angles="[ ]" -s meshfix_maximum_resolution="0.01" -s support_roof_line_width="0.5" -s material_standby_temperature="175" -s support_tower_roof_angle="65" -s gradual_infill_steps="0" -s acceleration_infill="3000" -s skin_outline_count="1" -s cool_fan_full_at_height="0.3" -s cool_lift_head="False" -s infill_overlap="10" -s skin_preshrink="1.0" -s retraction_hop_enabled="True" -s acceleration_support="3000" -s meshfix="0" -s ironing_only_highest_layer="False" -s cool_min_speed="5" -s support_bottom_pattern="lines" -s support_bottom_line_width="0.5" -s cool_fan_full_layer="3" -s speed_travel="120" -s support_xy_overrides_z="z_overrides_xy" -s speed_travel_layer_0="60.0" -s speed_support="35" -s experimental="0" -s top_skin_expand_distance="1.0" -s raft_interface_thickness="0.30000000000000004" -s machine_nozzle_cool_down_speed="2.0" -s raft_interface_line_width="1.0" -s support_z_distance="0.15" -s bottom_layers="4" -s cool_fan_enabled="True" -s magic_fuzzy_skin_point_dist="0.8" -s retraction_count_max="90" -s travel_avoid_other_parts="True" -s slicing_tolerance="middle" -s travel_avoid_distance="0.625" -s cross_infill_pocket_size="6.666666666666667" -s material_final_print_temperature="215" -s layer_0_z_overlap="0.15" -s support_conical_enabled="False" -s brim_width="8.0" -s acceleration_wall_x="3000" -s dual="0" -s machine_filament_park_distance="16" -s skin_overlap="5" -s jerk_support_roof="20" -s support_roof_pattern="lines" -s zig_zaggify_infill="True" -s expand_skins_expand_distance="1.0" -s bottom_skin_expand_distance="1.0" -s brim_outside_only="True" -s support_bottom_line_distance="0.5" -s wall_line_width_0="0.5" -s skin_alternate_rotation="False" -s acceleration_ironing="3000" -s extruder_prime_pos_z="0" -s infill="0" -s wall_0_wipe_dist="0.25" -s wall_line_width="0.5" -s coasting_volume="0.1" -s machine_nozzle_tip_outer_diameter="1" -s ironing_line_spacing="0.1" -s infill_wipe_dist="0.125" -s jerk_travel="30" -s speed_layer_0="30.0" -s prime_tower_min_volume="10" -s support_zag_skip_count="8" -s jerk_topbottom="20" -s magic_fuzzy_skin_point_density="1.25" -s material_print_temperature="210" -s top_bottom_pattern="lines" -s cool_fan_speed_max="100" -s gradual_support_infill_steps="0" -s extruder_prime_pos_y="0" -s machine_extruder_end_pos_x="0" -s roofing_pattern="lines" -s raft_surface_thickness="0.2" -s travel_compensate_overlapping_walls_enabled="True" -s infill_before_walls="False" -s support_minimal_diameter="3.0" -s speed_topbottom="30.0" -s machine_nozzle_offset_x="0" -s top_skin_preshrink="1.0" -s machine_heat_zone_length="16" -s shell="0" -s prime_tower_flow="100" -s sub_div_rad_add="0.5" -s gradual_support_infill_step_height="1" -s ironing_inset="0.25" -s acceleration_roofing="3000" -s top_bottom_pattern_0="lines" -s spaghetti_max_height="2.0" -s machine_extruder_end_pos_y="0" -s support_interface_skip_height="0.3" -s wall_line_width_x="0.5" -s raft_surface_line_width="0.5" -s layer_start_y="0.0" -s material_initial_print_temperature="215" -s raft_fan_speed="0" -s raft_base_fan_speed="0" -s support_roof_density="100" -s magic_mesh_surface_mode="normal" -s machine_nozzle_size="0.5" -s wall_thickness="0.8" -s switch_extruder_retraction_speed="20" -s extruder_nr="0" -s support_xy_distance="1" -s raft_interface_line_spacing="1.2" -s outer_inset_first="False" -s infill_overlap_mm="0.05" -s acceleration_prime_tower="3000" -s mold_enabled="False" -s material_flow_dependent_temperature="False" -s machine_extruder_start_pos_abs="False" -s support_top_distance="0.15" -s fill_perimeter_gaps="everywhere" -s raft_base_line_width="1.0" -s z_seam_x="145.0" -s support_tree_collision_resolution="0.25" -s support_join_distance="2.0" -s material_diameter="1.75" -s top_bottom_thickness="0.8" -s acceleration_print="3000" -s infill_sparse_thickness="0.2" -s raft_surface_line_spacing="0.5" -s skirt_line_count="3" -s infill_hollow="False" -s machine_nozzle_offset_y="0" -s raft_margin="15" -s cool_min_layer_time="15" -s wall_line_count="2" -s support_tree_wall_count="1" -s raft_jerk="20" -s speed_wall="30.0" -s speed_wall_0="30.0" -s jerk_prime_tower="20" -s travel_compensate_overlapping_walls_0_enabled="True" -s acceleration_skirt_brim="3000" -s support_tree_branch_distance="4" -s multiple_mesh_overlap="0.15" -s raft_surface_jerk="20" -s acceleration_travel="5000" -s raft_base_thickness="0.36" -s jerk_print_layer_0="20" -s speed_support_interface="23.333333333333332" -s acceleration_layer_0="3000" -s min_skin_width_for_expansion="4.898587196589413e-17" -s z_seam_relative="False" -s jerk_skirt_brim="20" -s machine_extruder_start_pos_y="0" -s support_interface_enable="False" -s support_pattern="zigzag" -s machine_extruder_start_pos_x="0" -s cool_min_layer_time_fan_speed_max="20" -s initial_layer_line_width_factor="100.0" -s jerk_travel_layer_0="30.0" -s min_infill_area="0" -s cool_fan_speed="100.0" -s infill_pattern="grid" -s coasting_speed="90" -s resolution="0" -s skin_line_width="0.5" -s raft_interface_jerk="20" -s raft_base_speed="22.5" -s speed_support_bottom="23.333333333333332" -s machine_nozzle_heat_up_speed="2.0" -s acceleration_support_interface="3000" -s extruder_prime_pos_x="0" -s retraction_retract_speed="45" -s material_guid="0ff92885-617b-4144-a03c-9989872454bc" -s spaghetti_max_infill_angle="10" -s ironing_enabled="False" -s raft_acceleration="3000" -s magic_fuzzy_skin_enabled="False" -s infill_offset_x="0" -s gradual_infill_step_height="2.0" -s meshfix_keep_open_polygons="False" -s mesh_position_x="0" -s spaghetti_infill_stepped="True" -s support_offset="0.2" -s jerk_roofing="20" -s support_bottom_distance="0.15" -s support_tree_branch_diameter="2" -s support_roof_line_distance="0.5" -s mold_width="5" -s support_infill_sparse_thickness="0.2" -s magic_fuzzy_skin_thickness="0.3" -s mold_angle="40" -s skin_overlap_mm="0.025" -s speed_equalize_flow_enabled="False" -s support_roof_height="1" -s support_interface_pattern="lines" -s infill_sparse_density="15" -s acceleration_support_roof="3000" -s machine_extruder_end_pos_abs="False" -s z_seam_type="sharpest_corner" -s wall_0_inset="0" -s cooling="0" -s raft_interface_fan_speed="0" -s support_skip_some_zags="False" -s prime_tower_purge_volume="0" -s raft_airgap="0.3" -s speed_wall_x="60.0" -s material_flow_temp_graph="[[3.5,200],[7.0,240]]" -s retraction_hop_after_extruder_switch="True" -s spaghetti_infill_enabled="False" -s skin_angles="[ ]" -s jerk_infill="20" -s jerk_print="20" -s support_interface_height="1" -s spaghetti_inset="0.2" -s support_connect_zigzags="True" -s retraction_hop_only_when_collides="False" -s support_interface_density="100" -s prime_tower_wipe_enabled="True" -s support_use_towers="True" -s conical_overhang_angle="50" -s raft_smoothing="5" -s jerk_wall="20" -s speed_support_infill="35" -s skirt_brim_minimal_length="200" -s platform_adhesion="0" -s jerk_wall_0="20" -s skirt_brim_line_width="0.5" -s support_interface_line_width="0.5" -s brim_line_count="3" -s material_adhesion_tendency="10" -s support_tree_branch_diameter_angle="5" -s support_conical_min_width="5.0" -s machine_nozzle_id="unknown" -s jerk_layer_0="20" -s retract_at_layer_change="False" -s speed_print="60" -s speed_roofing="30.0" -s skin_no_small_gaps_heuristic="True" -s mesh_rotation_matrix="[[1,0,0], [0,1,0], [0,0,1]]" -s acceleration_wall_0="3000" -s jerk_ironing="20" -s retraction_enable="True" -s max_feedrate_z_override="500" -s mesh_position_z="0" -s retraction_extra_prime_amount="0" -s mesh_position_y="0" -s support_tree_angle="40" -s spaghetti_infill_extra_volume="0" -s machine_min_cool_heat_time_window="50.0" -s speed_print_layer_0="30.0" -s infill_line_width="0.5" -s meshfix_extensive_stitching="False" -s coasting_min_volume="0.8" -s support_angle="40" -s switch_extruder_prime_speed="20" -s raft_base_acceleration="3000" -s command_line_settings="0" -e0 -l "0"
                  2018-03-20 08:20:02,170 - DEBUG - [(1964)-Thread-13] UM.Backend.Backend._backendLog [90]: [Backend] [WARNING] There are empty layers (or layers with empty extruder plans) in the print! Temperature control and cross layer travel moves might suffer.
                  2018-03-20 08:20:02,561 - DEBUG - [(11228)-MainThread] CuraEngineBackend.CuraEngineBackend._onSlicingFinishedMessage [582]: Slicing took 2.9428465366363525 seconds
                  2018-03-20 08:20:02,562 - DEBUG - [(11228)-MainThread] CuraEngineBackend.CuraEngineBackend._onSlicingFinishedMessage [591]: See if there is more to slice…
                  2018-03-20 08:20:02,564 - DEBUG - [(11228)-MainThread] UM.Backend.Backend._logSocketState [181]: Socket state changed to Closing
                  2018-03-20 08:20:02,565 - DEBUG - [(11228)-MainThread] UM.Backend.Backend._onSocketError [203]: Socket debug: Arcus Error (13): Closing socket because other side requested close.
                  2018-03-20 08:20:02,566 - DEBUG - [(11228)-MainThread] UM.Backend.Backend._logSocketState [183]: Socket state changed to Closed
                  2018-03-20 08:20:02,567 - DEBUG - [(11228)-MainThread] CuraEngineBackend.CuraEngineBackend._onBackendQuit [722]: Backend quit with return code 0. Resetting process and socket.
                  2018-03-20 08:20:04,283 - DEBUG - [(15140)-Thread-9] USBPrinting.USBPrinterOutputDevice._connect [356]: Attempting to connect to printer with serial COM5 on baud rate 9600
                  2018-03-20 08:20:04,610 - INFO - [(11228)-MainThread] cura.CuraApplication.deleteAll [1052]: Clearing scene
                  2018-03-20 08:20:04,616 - WARNING - [(11228)-MainThread] UM.Qt.QtApplication.__onQmlWarning [267]: file:///C:/Program Files/Ultimaker Cura 3.2/qml/QtQuick/Controls/TextField.qml:638:5: QML TextInputWithHandles: Binding loop detected for property "text"
                  2018-03-20 08:20:05,144 - DEBUG - [(11228)-MainThread] UM.Mesh.MeshData.calculateNormalsFromIndexedVertices [444]: Calculating normals took 0.0020020008087158203 seconds
                  2018-03-20 08:20:05,558 - DEBUG - [(11228)-MainThread] cura.Settings.MachineManager._checkStacksHaveErrors [423]: Checking 2 stacks for errors took 0.31 s
                  2018-03-20 08:20:06,137 - DEBUG - [(11228)-MainThread] CuraEngineBackend.CuraEngineBackend.slice [197]: starting to slice!
                  2018-03-20 08:20:06,137 - DEBUG - [(11228)-MainThread] CuraEngineBackend.CuraEngineBackend.slice [214]: Going to slice build plate [0]!
                  2018-03-20 08:20:06,137 - DEBUG - [(11228)-MainThread] CuraEngineBackend.CuraEngineBackend.slice [218]: Build plate 0 has no objects to be sliced, skipping
                  2018-03-20 08:20:08,744 - DEBUG - [(14864)-Thread-3] UM.Mesh.MeshData.calculateNormalsFromVertices [421]: Calculating normals took 0.0 seconds
                  2018-03-20 08:20:08,745 - DEBUG - [(14864)-Thread-3] STLReader.STLReader.read [79]: Loaded a mesh with 3018 vertices
                  2018-03-20 08:20:08,759 - DEBUG - [(11228)-MainThread] UM.Mesh.MeshData.approximateConvexHull [388]: approximateConvexHull(target_count=1024) Calculating 3D convex hull took 0.012011051177978516 seconds. 27 input vertices. 27 output vertices.
                  2018-03-20 08:20:08,762 - DEBUG - [(14864)-Thread-3] UM.FileHandler.ReadFileJob.run [68]: Loading file took 0.0 seconds
                  2018-03-20 08:20:08,781 - DEBUG - [(14864)-Thread-3] UM.Mesh.MeshData.approximateConvexHull [388]: approximateConvexHull(target_count=1024) Calculating 3D convex hull took 0.018017292022705078 seconds. 27 input vertices. 27 output vertices.
                  2018-03-20 08:20:08,794 - WARNING - [(11228)-MainThread] UM.Qt.QtApplication.__onQmlWarning [267]: file:///C:/Program Files/Ultimaker Cura 3.2/qml/QtQuick/Controls/TextField.qml:638:5: QML TextInputWithHandles: Binding loop detected for property "text"
                  2018-03-20 08:20:09,215 - DEBUG - [(11228)-MainThread] UM.Mesh.MeshData.calculateNormalsFromIndexedVertices [444]: Calculating normals took 0.003002643585205078 seconds
                  2018-03-20 08:20:09,353 - DEBUG - [(11228)-MainThread] CuraEngineBackend.CuraEngineBackend.slice [197]: starting to slice!
                  2018-03-20 08:20:09,354 - DEBUG - [(11228)-MainThread] CuraEngineBackend.CuraEngineBackend.slice [214]: Going to slice build plate [0]!
                  2018-03-20 08:20:09,356 - DEBUG - [(11228)-MainThread] UM.Backend.Backend._createSocket [213]: Previous socket existed. Closing that first.
                  2018-03-20 08:20:09,366 - DEBUG - [(11228)-MainThread] UM.Backend.Backend._logSocketState [173]: Socket state changed to Listening
                  2018-03-20 08:20:09,421 - INFO - [(11228)-MainThread] UM.Backend.Backend.startEngine [74]: Started engine process: C:\Program Files\Ultimaker Cura 3.2\CuraEngine.exe
                  2018-03-20 08:20:09,425 - DEBUG - [(11228)-MainThread] UM.Backend.Backend._backendLog [90]: [Backend] Calling engine with: ['C:\Program Files\Ultimaker Cura 3.2\CuraEngine.exe', 'connect', '127.0.0.1:49674', '-j', 'C:\Program Files\Ultimaker Cura 3.2\resources\definitions\fdmprinter.def.json', '']
                  2018-03-20 08:20:09,478 - DEBUG - [(14640)-Thread-16] UM.Backend.Backend._backendLog [90]: [Backend]
                  2018-03-20 08:20:09,481 - DEBUG - [(14640)-Thread-16] UM.Backend.Backend._backendLog [90]: [Backend] Cura_SteamEngine version DEV
                  2018-03-20 08:20:09,495 - DEBUG - [(11228)-MainThread] UM.Backend.Backend._logSocketState [177]: Socket state changed to Connected
                  2018-03-20 08:20:09,497 - DEBUG - [(14640)-Thread-16] UM.Backend.Backend._backendLog [90]: [Backend] Copyright (C) 2017 Ultimaker
                  2018-03-20 08:20:09,639 - DEBUG - [(14640)-Thread-16] UM.Backend.Backend._backendLog [90]: [Backend]
                  2018-03-20 08:20:09,642 - DEBUG - [(11228)-MainThread] UM.Backend.Backend._onSocketStateChanged [167]: Backend connected on port 49674
                  2018-03-20 08:20:09,666 - DEBUG - [(14640)-Thread-16] UM.Backend.Backend._backendLog [90]: [Backend] This program is free software: you can redistribute it and/or modify
                  2018-03-20 08:20:09,752 - DEBUG - [(14640)-Thread-16] UM.Backend.Backend._backendLog [90]: [Backend] it under the terms of the GNU Affero General Public License as published by
                  2018-03-20 08:20:09,768 - DEBUG - [(14640)-Thread-16] UM.Backend.Backend._backendLog [90]: [Backend] the Free Software Foundation, either version 3 of the License, or
                  2018-03-20 08:20:09,777 - DEBUG - [(14640)-Thread-16] UM.Backend.Backend._backendLog [90]: [Backend] (at your option) any later version.
                  2018-03-20 08:20:09,805 - DEBUG - [(14640)-Thread-16] UM.Backend.Backend._backendLog [90]: [Backend]
                  2018-03-20 08:20:09,823 - DEBUG - [(14640)-Thread-16] UM.Backend.Backend._backendLog [90]: [Backend] This program is distributed in the hope that it will be useful,
                  2018-03-20 08:20:09,871 - DEBUG - [(14640)-Thread-16] UM.Backend.Backend._backendLog [90]: [Backend] but WITHOUT ANY WARRANTY; without even the implied warranty of
                  2018-03-20 08:20:09,930 - DEBUG - [(14640)-Thread-16] UM.Backend.Backend._backendLog [90]: [Backend] MERCHANTABILITY or FITNESS FOR A PARTICULAR PURPOSE. See the
                  2018-03-20 08:20:10,020 - DEBUG - [(14640)-Thread-16] UM.Backend.Backend._backendLog [90]: [Backend] GNU Affero General Public License for more details.
                  2018-03-20 08:20:10,089 - DEBUG - [(14640)-Thread-16] UM.Backend.Backend._backendLog [90]: [Backend]
                  2018-03-20 08:20:10,120 - DEBUG - [(14640)-Thread-16] UM.Backend.Backend._backendLog [90]: [Backend] You should have received a copy of the GNU Affero General Public License
                  2018-03-20 08:20:10,171 - DEBUG - [(14640)-Thread-16] UM.Backend.Backend._backendLog [90]: [Backend] along with this program. If not, see <http://www.gnu.org/licenses/>.
                  2018-03-20 08:20:10,843 - ERROR - [(15140)-Thread-9] USBPrinting.USBPrinterOutputDevice._connect [394]: Baud rate detection for COM5 failed
                  2018-03-20 08:20:10,844 - DEBUG - [(15140)-Thread-9] USBPrinting.USBPrinterOutputDevice.close [408]: Closing the USB printer connection.
                  2018-03-20 08:20:10,846 - DEBUG - [(15140)-Thread-9] USBPrinting.USBPrinterOutputDevice.close [413]: PrinterConnection.close: cannot join current thread (expected)
                  2018-03-20 08:20:10,849 - WARNING - [(11228)-MainThread] UM.OutputDevice.OutputDeviceManager.removeOutputDevice [126]: Could not find output device with id COM5 to remove
                  2018-03-20 08:20:11,647 - DEBUG - [(11228)-MainThread] CuraEngineBackend.CuraEngineBackend._onStartSliceCompleted [381]: Sending slice message took 2.2932746410369873 seconds
                  2018-03-20 08:20:11,834 - DEBUG - [(14640)-Thread-16] UM.Backend.Backend._backendLog [90]: [Backend] [WARNING] Setting an unregistered setting print_bed_temperature to 60.0
                  2018-03-20 08:20:11,836 - DEBUG - [(14640)-Thread-16] UM.Backend.Backend._backendLog [90]: [Backend] [WARNING] Setting an unregistered setting initial_extruder_nr to 0
                  2018-03-20 08:20:11,838 - DEBUG - [(14640)-Thread-16] UM.Backend.Backend._backendLog [90]: [Backend] [WARNING] Setting an unregistered setting print_temperature to 205
                  2018-03-20 08:20:11,842 - DEBUG - [(14640)-Thread-16] UM.Backend.Backend._backendLog [90]: [Backend] [WARNING] Setting an unregistered setting time to 08:20:09
                  2018-03-20 08:20:11,843 - DEBUG - [(14640)-Thread-16] UM.Backend.Backend._backendLog [90]: [Backend] [WARNING] Setting an unregistered setting day to Tue
                  2018-03-20 08:20:11,844 - DEBUG - [(14640)-Thread-16] UM.Backend.Backend._backendLog [90]: [Backend] [WARNING] Setting an unregistered setting date to 20-03-2018
                  2018-03-20 08:20:11,845 - DEBUG - [(14640)-Thread-16] UM.Backend.Backend._backendLog [90]: [Backend] [WARNING] -s wireframe_flow="100" -s machine_settings="0" -s date="20-03-2018" -s max_skin_angle_for_expansion="90" -s support_bottom_density="100" -s cooling="0" -s support_tree_wall_thickness="0.4" -s raft_speed="30.0" -s meshfix="0" -s speed="0" -s speed_wall="40.0" -s acceleration_wall="3000" -s wireframe_printspeed="5" -s support_skip_zag_per_mm="20" -s travel_compensate_overlapping_walls_enabled="True" -s experimental="0" -s top_thickness="0.8" -s line_width="0.4" -s bottom_thickness="0.8" -s switch_extruder_retraction_speeds="20" -s command_line_settings="0" -s jerk_print="20" -s machine_head_polygon="[[-1, 1], [-1, -1], [1, -1], [1, 1]]" -s jerk_layer_0="20" -s time="08:20:09" -s wall_extruder_nr="-1" -s speed_support="35" -s brim_width="8.0" -s jerk_wall="20" -s raft_acceleration="3000" -s support_interface_pattern="lines" -s support_interface_line_width="0.4" -s infill_sparse_density="15" -s print_temperature="205" -s resolution="0" -s skin_overlap="5" -s skin_preshrink="1.2000000000000002" -s support_z_distance="0.15" -s support_interface_enable="False" -s shell="0" -s machine_use_extruder_offset_to_offset_coords="True" -s retraction_hop_only_when_collides="False" -s start_layers_at_same_position="False" -s jerk_prime_tower="20" -s travel_avoid_other_parts="True" -s jerk_support_roof="20" -s jerk_print_layer_0="20" -s material_print_temp_prepend="True" -s jerk_travel="30" -s jerk_roofing="20" -s support_bottom_distance="0.15" -s jerk_wall_x="20" -s speed_layer_0="25" -s jerk_wall_0="20" -s machine_max_jerk_e="5.0" -s jerk_enabled="False" -s blackmagic="0" -s acceleration_support_roof="3000" -s prime_tower_enable="False" -s acceleration_wall_x="3000" -s support_bottom_line_width="0.5" -s max_feedrate_z_override="0" -s skirt_brim_minimal_length="200" -s raft_smoothing="5" -s cool_fan_full_at_height="0.3" -s conical_overhang_angle="50" -s skin_no_small_gaps_heuristic="True" -s speed_print="60" -s layer_start_x="0.0" -s speed_wall_x="50.0" -s speed_wall_0="45.0" -s speed_infill="60" -s switch_extruder_retraction_amount="16" -s spaghetti_infill_stepped="True" -s prime_tower_size="20" -s retraction_retract_speed="45" -s machine_nozzle_heat_up_speed="2.0" -s extruder_prime_pos_x="0" -s acceleration_support_interface="3000" -s print_bed_temperature="60.0" -s material_surface_energy="100" -s travel_avoid_distance="0.625" -s jerk_ironing="20" -s retraction_extra_prime_amount="0" -s cross_infill_pocket_size="8.0" -s material_print_temperature_layer_0="205" -s material_print_temperature="205" -s jerk_topbottom="20" -s draft_shield_height="10" -s min_skin_width_for_expansion="1.2246467991473532e-16" -s flow_rate_extrusion_offset_factor="100" -s speed_travel_layer_0="250" -s wireframe_roof_outer_delay="0.2" -s top_skin_expand_distance="1.2000000000000002" -s bottom_skin_preshrink="1.2000000000000002" -s extruder_prime_pos_abs="False" -s top_skin_preshrink="1.2000000000000002" -s adhesion_extruder_nr="0" -s infill_before_walls="False" -s gradual_infill_steps="0" -s infill_sparse_thickness="0.2" -s retraction_hop_enabled="True" -s layer_start_y="0.0" -s wireframe_flow_connection="100" -s skin_overlap_mm="0.02" -s speed_equalize_flow_enabled="False" -s mold_angle="40" -s acceleration_layer_0="3000" -s machine_start_gcode="G28 ;Home
                  2018-03-20 08:20:11,846 - DEBUG - [(14640)-Thread-16] UM.Backend.Backend._backendLog [90]: [Backend] G1 Z15.0 F6000 ;Move the platform down 15mm
                  2018-03-20 08:20:11,847 - DEBUG - [(14640)-Thread-16] UM.Backend.Backend._backendLog [90]: [Backend] ;Prime the extruder
                  2018-03-20 08:20:11,849 - DEBUG - [(14640)-Thread-16] UM.Backend.Backend._backendLog [90]: [Backend] G92 E0
                  2018-03-20 08:20:11,850 - DEBUG - [(14640)-Thread-16] UM.Backend.Backend._backendLog [90]: [Backend] G1 F200 E3
                  2018-03-20 08:20:11,851 - DEBUG - [(14640)-Thread-16] UM.Backend.Backend._backendLog [90]: [Backend] G92 E0" -s wireframe_up_half_speed="0.3" -s machine_firmware_retract="False" -s infill_overlap_mm="0.04" -s outer_inset_first="False" -s raft_interface_line_spacing="1.0" -s infill_offset_x="0" -s magic_fuzzy_skin_enabled="False" -s infill_angles="[ ]" -s cross_infill_apply_pockets_alternatingly="True" -s zig_zaggify_infill="True" -s acceleration_topbottom="3000" -s material_extrusion_cool_down_speed="0.7" -s infill_pattern="cubic" -s support_tower_roof_angle="65" -s adaptive_layer_height_enabled="False" -s material_adhesion_tendency="10" -s machine_max_feedrate_x="500" -s travel_compensate_overlapping_walls_0_enabled="True" -s support="0" -s material_bed_temp_prepend="True" -s support_bottom_pattern="lines" -s machine_depth="290" -s speed_support_roof="23.333333333333332" -s wireframe_top_delay="0" -s acceleration_skirt_brim="3000" -s optimize_wall_printing_order="False" -s retraction_hop="1" -s machine_max_feedrate_z="5" -s acceleration_travel_layer_0="5000.0" -s layer_height="0.2" -s prime_tower_purge_volume="0" -s sub_div_rad_add="0.4" -s support_roof_line_width="0.5" -s machine_max_feedrate_y="500" -s meshfix_maximum_resolution="0.01" -s machine_max_acceleration_y="9000" -s machine_show_variants="False" -s gradual_support_infill_step_height="1" -s alternate_extra_perimeter="False" -s machine_nozzle_size="0.4" -s speed_prime_tower="60" -s machine_heat_zone_length="16" -s support_zag_skip_count="10" -s cutting_mesh="False" -s roofing_layer_count="0" -s wireframe_drag_along="0.6" -s machine_heated_bed="True" -s roofing_extruder_nr="-1" -s switch_extruder_retraction_speed="20" -s gantry_height="99999999999" -s ironing_inset="0.2" -s layer_0_z_overlap="0.15" -s wireframe_bottom_delay="0" -s acceleration_wall_0="3000" -s mesh_rotation_matrix="[[1,0,0], [0,1,0], [0,0,1]]" -s retraction_prime_speed="45" -s machine_nozzle_temp_enabled="True" -s gradual_infill_step_height="2.0" -s meshfix_keep_open_polygons="False" -s mesh_position_x="0" -s machine_width="290" -s top_layers="10" -s day="Tue" -s material_bed_temperature_layer_0="60.0" -s machine_max_acceleration_e="10000" -s support_bottom_height="1" -s coasting_speed="90" -s speed_equalize_flow_max="150" -s machine_nozzle_id="unknown" -s layer_height_0="0.3" -s support_conical_min_width="5.0" -s machine_nozzle_cool_down_speed="2.0" -s acceleration_travel="5000" -s raft_surface_jerk="20" -s multiple_mesh_overlap="0.15" -s material_diameter="1.75" -s top_bottom_extruder_nr="-1" -s machine_max_acceleration_z="100" -s acceleration_ironing="3000" -s extruder_prime_pos_z="0" -s infill_wipe_dist="0.1" -s machine_nozzle_tip_outer_diameter="1" -s wall_thickness="0.8" -s min_infill_area="0" -s machine_height="540" -s support_connect_zigzags="True" -s wall_x_extruder_nr="-1" -s brim_outside_only="True" -s infill_line_distance="8.0" -s machine_end_gcode="M104 S0
                  2018-03-20 08:20:11,852 - DEBUG - [(14640)-Thread-16] UM.Backend.Backend._backendLog [90]: [Backend] M140 S0
                  2018-03-20 08:20:11,853 - DEBUG - [(14640)-Thread-16] UM.Backend.Backend._backendLog [90]: [Backend] ;Retract the filament
                  2018-03-20 08:20:11,854 - DEBUG - [(14640)-Thread-16] UM.Backend.Backend._backendLog [90]: [Backend] G92 E1
                  2018-03-20 08:20:11,855 - DEBUG - [(14640)-Thread-16] UM.Backend.Backend._backendLog [90]: [Backend] G1 E-1 F300
                  2018-03-20 08:20:11,856 - DEBUG - [(14640)-Thread-16] UM.Backend.Backend._backendLog [90]: [Backend] G28 X0 Y0
                  2018-03-20 08:20:11,857 - DEBUG - [(14640)-Thread-16] UM.Backend.Backend._backendLog [90]: [Backend] M84" -s skirt_brim_line_width="0.4" -s acceleration_support="3000" -s brim_line_count="3" -s machine_max_acceleration_x="9000" -s slicing_tolerance="middle" -s ooze_shield_dist="2" -s ironing_flow="10.0" -s infill_line_width="0.4" -s fill_outline_gaps="False" -s machine_filament_park_distance="16" -s acceleration_print_layer_0="3000" -s speed_roofing="45.0" -s material_standby_temperature="150" -s infill_extruder_nr="-1" -s skin_angles="[ ]" -s jerk_infill="20" -s acceleration_infill="3000" -s travel_retract_before_outer_wall="False" -s switch_extruder_prime_speed="20" -s raft_base_acceleration="3000" -s jerk_skirt_brim="20" -s z_seam_relative="False" -s machine_shape="elliptic" -s cool_fan_speed="100.0" -s speed_travel="400" -s alternate_carve_order="True" -s spaghetti_inset="0.2" -s cool_fan_full_layer="3" -s retraction_count_max="90" -s magic_fuzzy_skin_point_dist="0.8" -s material_bed_temp_wait="True" -s bottom_layers="10" -s machine_max_jerk_xy="20.0" -s wall_line_width_0="0.4" -s acceleration_enabled="False" -s skin_alternate_rotation="False" -s material_bed_temperature="60.0" -s prime_tower_line_width="0.4" -s machine_gcode_flavor="RepRap (RepRap)" -s wall_0_extruder_nr="-1" -s retraction_hop_after_extruder_switch="True" -s travel="0" -s material_flow_temp_graph="[[3.5,200],[7.0,240]]" -s material_print_temp_wait="True" -s wall_line_count="3" -s machine_minimum_feedrate="0.0" -s machine_name="Unknown" -s wall_line_width_x="0.4" -s raft_surface_line_width="0.4" -s wall_0_wipe_dist="0.2" -s machine_nozzle_expansion_angle="45" -s top_bottom_pattern="lines" -s support_line_width="0.4" -s machine_acceleration="4000" -s wall_0_inset="0" -s machine_center_is_zero="True" -s smooth_spiralized_contours="True" -s skin_line_width="0.4" -s raft_interface_jerk="20" -s retraction_amount="3.2" -s machine_max_jerk_z="0.4" -s z_seam_corner="z_seam_corner_inner" -s machine_max_feedrate_e="299792458000" -s travel_compensate_overlapping_walls_x_enabled="True" -s raft_base_line_width="0.8" -s support_top_distance="0.15" -s machine_min_cool_heat_time_window="50.0" -s spaghetti_infill_extra_volume="0" -s xy_offset="0" -s carve_multiple_volumes="False" -s jerk_support="20" -s ironing_line_spacing="0.1" -s skirt_brim_speed="25" -s material_flow="97" -s xy_offset_layer_0="0" -s z_seam_y="870" -s support_interface_extruder_nr="0" -s wireframe_fall_down="0.5" -s default_material_print_temperature="205" -s infill_mesh="False" -s retraction_enable="True" -s skin_outline_count="1" -s ironing_only_highest_layer="False" -s retraction_extrusion_window="3.2" -s speed_support_infill="35" -s retract_at_layer_change="False" -s machine_extruder_count="1" -s ironing_enabled="False" -s retraction_min_travel="1.5" -s speed_ironing="30.0" -s ironing_pattern="zigzag" -s cool_fan_enabled="True" -s cool_fan_speed_min="75" -s magic_fuzzy_skin_point_density="1.25" -s wireframe_enabled="False" -s cool_min_layer_time_fan_speed_max="20" -s ooze_shield_angle="60" -s cool_lift_head="False" -s support_enable="False" -s fill_perimeter_gaps="everywhere" -s support_infill_extruder_nr="0" -s speed_support_bottom="23.333333333333332" -s support_extruder_nr_layer_0="0" -s skirt_line_count="3" -s filter_out_tiny_gaps="True" -s support_tree_branch_diameter_angle="5" -s raft_surface_line_spacing="0.4" -s infill_hollow="False" -s top_bottom_pattern_0="lines" -s support_roof_extruder_nr="0" -s jerk_travel_layer_0="30.0" -s support_bottom_extruder_nr="0" -s support_type="everywhere" -s nozzle_disallowed_areas="[]" -s support_angle="40" -s support_pattern="zigzag" -s support_line_distance="2.0" -s cool_min_layer_time="15" -s wireframe_roof_inset="3" -s support_interface_height="1" -s initial_layer_line_width_factor="100.0" -s support_xy_distance="1" -s support_xy_overrides_z="z_overrides_xy" -s support_bottom_stair_step_height="0.3" -s support_bottom_stair_step_width="5.0" -s jerk_support_interface="20" -s machine_disallowed_areas="[]" -s acceleration_prime_tower="3000" -s support_infill_sparse_thickness="0.2" -s dual_pre_wipe="True" -s mold_width="5" -s gradual_support_infill_steps="0" -s support_roof_enable="False" -s support_bottom_enable="False" -s retraction_speed="45" -s support_roof_height="1" -s support_interface_skip_height="0.3" -s support_roof_line_distance="0.5" -s support_tree_branch_diameter="2" -s infill_overlap="10" -s support_bottom_line_distance="0.5" -s material="0" -s support_roof_pattern="lines" -s prime_tower_wipe_enabled="True" -s support_tower_diameter="3.0" -s support_join_distance="2.0" -s remove_empty_first_layers="True" -s support_minimal_diameter="3.0" -s infill_mesh_order="0" -s cool_fan_speed_max="100" -s support_mesh_drop_down="True" -s bottom_skin_expand_distance="1.2000000000000002" -s prime_blob_enable="True" -s extruder_prime_pos_y="0" -s support_infill_rate="20" -s adhesion_type="skirt" -s skirt_gap="3" -s support_interface_density="100" -s prime_tower_position_x="285.3" -s cool_fan_speed_0="0" -s raft_airgap="0.3" -s support_mesh="False" -s support_xy_distance_overhang="1.25" -s raft_surface_thickness="0.2" -s prime_tower_flow="97" -s raft_interface_thickness="0.30000000000000004" -s z_seam_type="shortest" -s raft_interface_line_width="0.8" -s raft_base_thickness="0.36" -s raft_base_line_spacing="1.6" -s raft_interface_speed="22.5" -s support_offset="0.2" -s raft_base_speed="22.5" -s raft_surface_acceleration="3000" -s platform_adhesion="0" -s speed_print_layer_0="25" -s raft_interface_acceleration="3000" -s raft_base_jerk="20" -s raft_surface_fan_speed="0" -s adaptive_layer_height_variation_step="0.01" -s draft_shield_dist="10" -s raft_interface_fan_speed="0" -s support_skip_some_zags="False" -s support_tree_enable="False" -s support_roof_density="100" -s meshfix_union_all="True" -s acceleration_support_infill="3000" -s meshfix_union_all_remove_holes="False" -s mold_enabled="False" -s mold_roof_height="0.5" -s magic_mesh_surface_mode="normal" -s anti_overhang_mesh="False" -s relative_extrusion="False" -s support_tree_angle="40" -s support_tree_collision_resolution="0.2" -s support_tree_wall_count="1" -s retraction_combing="off" -s raft_jerk="20" -s roofing_line_width="0.4" -s acceleration_support_bottom="3000" -s roofing_pattern="lines" -s infill_offset_y="0" -s roofing_angles="[ ]" -s raft_margin="15" -s infill_enable_travel_optimization="False" -s mesh_position_y="0" -s material_flow_dependent_temperature="False" -s conical_overhang_enabled="False" -s draft_shield_enabled="False" -s draft_shield_height_limitation="full" -s coasting_min_volume="0.8" -s spaghetti_infill_enabled="False" -s spaghetti_max_infill_angle="10" -s speed_topbottom="45.0" -s magic_spiralize="False" -s spaghetti_max_height="2.0" -s spaghetti_flow="20" -s machine_nozzle_head_distance="3" -s support_conical_enabled="False" -s support_conical_angle="30" -s jerk_support_bottom="20" -s magic_fuzzy_skin_thickness="0.3" -s acceleration_roofing="3000" -s flow_rate_max_extrusion_offset="0" -s mesh_position_z="0" -s wireframe_height="3" -s prime_tower_wall_thickness="1.0" -s ooze_shield_enabled="False" -s coasting_enable="True" -s wireframe_printspeed_bottom="5" -s wireframe_printspeed_up="5" -s prime_tower_position_y="265.3" -s z_seam_x="145.0" -s raft_surface_speed="30.0" -s wireframe_printspeed_down="5" -s raft_base_fan_speed="0" -s wireframe_printspeed_flat="5" -s wireframe_flow_flat="100" -s wireframe_flat_delay="0.1" -s wireframe_top_jump="0.6" -s coasting_volume="0.1" -s wireframe_strategy="compensate" -s wireframe_straight_before_down="20" -s print_sequence="all_at_once" -s support_use_towers="True" -s wireframe_roof_fall_down="2" -s speed_slowdown_layers="1" -s material_final_print_temperature="205" -s wireframe_roof_drag_along="0.8" -s wireframe_nozzle_clearance="1" -s meshfix_extensive_stitching="False" -s adaptive_layer_height_variation="0.1" -s speed_support_interface="23.333333333333332" -s adaptive_layer_height_threshold="200.0" -s center_object="False" -s raft_surface_layers="2" -s prime_tower_min_volume="10" -s support_extruder_nr="0" -s support_tree_branch_distance="4" -s expand_skins_expand_distance="1.2000000000000002" -s raft_fan_speed="0" -s acceleration_print="3000" -s jerk_support_infill="20" -s machine_head_with_fans_polygon="[[-20, 10], [-20, -10], [10, 10], [10, -10]]" -s wall_line_width="0.4" -s top_bottom_thickness="0.8" -s infill="0" -s dual="0" -s cool_min_speed="10" -s material_initial_print_temperature="205" -s initial_extruder_nr="0" -g -e0 -s jerk_support_interface="20" -s meshfix_union_all="True" -s coasting_enable="False" -s material_surface_energy="100" -s support_line_width="0.5" -s support_conical_angle="30" -s machine_settings="0" -s support_bottom_stair_step_width="5.0" -s spaghetti_flow="20" -s raft_surface_speed="30.0" -s xy_offset="0" -s raft_surface_acceleration="3000" -s max_skin_angle_for_expansion="90" -s speed_ironing="30.0" -s support_bottom_height="1" -s acceleration_support_bottom="3000" -s support_bottom_density="100" -s infill_line_distance="10.0" -s optimize_wall_printing_order="False" -s raft_base_jerk="20" -s z_seam_y="870" -s meshfix_union_all_remove_holes="False" -s support_roof_enable="False" -s travel="0" -s retraction_extrusion_window="3.2" -s blackmagic="0" -s xy_offset_layer_0="0" -s jerk_wall_x="20" -s support_tree_wall_thickness="0.5" -s jerk_support_bottom="20" -s raft_speed="30.0" -s center_object="False" -s cool_fan_speed_0="0" -s speed="0" -s layer_start_x="0.0" -s roofing_angles="[ ]" -s acceleration_travel_layer_0="5000.0" -s material_flow="100" -s retraction_prime_speed="45" -s roofing_layer_count="0" -s machine_nozzle_head_distance="3" -s prime_tower_line_width="0.5" -s acceleration_wall="3000" -s support_tower_diameter="3.0" -s z_seam_corner="z_seam_corner_inner" -s cool_fan_speed_min="75" -s infill_offset_y="0" -s material_print_temperature_layer_0="205" -s extruder_prime_pos_abs="False" -s material="0" -s default_material_print_temperature="205" -s acceleration_print_layer_0="3000" -s dual_pre_wipe="True" -s support_line_distance="2.5" -s retraction_min_travel="1.5" -s support="0" -s support_bottom_stair_step_height="0.3" -s support_bottom_enable="False" -s speed_infill="60" -s retraction_speed="45" -s retraction_amount="3.2" -s speed_prime_tower="60" -s top_thickness="0.8" -s skirt_gap="3" -s jerk_support_infill="20" -s bottom_skin_preshrink="1.5" -s support_xy_distance_overhang="1.25" -s travel_compensate_overlapping_walls_x_enabled="True" -s raft_interface_acceleration="3000" -s raft_surface_layers="2" -s fill_outline_gaps="True" -s ironing_flow="10.0" -s top_layers="5" -s machine_nozzle_temp_enabled="True" -s alternate_extra_perimeter="False" -s skirt_brim_speed="25" -s retraction_hop="1" -s prime_blob_enable="True" -s material_extrusion_cool_down_speed="0.7" -s roofing_line_width="0.5" -s line_width="0.5" -s ironing_pattern="zigzag" -s conical_overhang_enabled="False" -s bottom_thickness="0.8" -s support_infill_rate="20" -s jerk_support="20" -s speed_support_roof="23.333333333333332" -s infill_enable_travel_optimization="False" -s mold_roof_height="0.5" -s acceleration_topbottom="3000" -s raft_interface_speed="22.5" -s speed_equalize_flow_max="150" -s raft_base_line_spacing="2.0" -s switch_extruder_retraction_amount="16" -s switch_extruder_retraction_speeds="20" -s acceleration_support_infill="3000" -s support_skip_zag_per_mm="20" -s filter_out_tiny_gaps="True" -s raft_surface_fan_speed="0" -s cross_infill_apply_pockets_alternatingly="True" -s infill_angles="[ ]" -s meshfix_maximum_resolution="0.01" -s support_roof_line_width="0.5" -s material_standby_temperature="175" -s support_tower_roof_angle="65" -s gradual_infill_steps="0" -s acceleration_infill="3000" -s skin_outline_count="1" -s cool_fan_full_at_height="0.3" -s cool_lift_head="False" -s infill_overlap="10" -s skin_preshrink="1.5" -s retraction_hop_enabled="True" -s acceleration_support="3000" -s meshfix="0" -s ironing_only_highest_layer="False" -s cool_min_speed="5" -s support_bottom_pattern="lines" -s support_bottom_line_width="0.5" -s cool_fan_full_layer="3" -s speed_travel="400" -s support_xy_overrides_z="z_overrides_xy" -s speed_travel_layer_0="250" -s speed_support="35" -s experimental="0" -s top_skin_expand_distance="1.5" -s raft_interface_thickness="0.30000000000000004" -s machine_nozzle_cool_down_speed="2.0" -s raft_interface_line_width="1.0" -s support_z_distance="0.15" -s bottom_layers="5" -s cool_fan_enabled="True" -s magic_fuzzy_skin_point_dist="0.8" -s retraction_count_max="90" -s travel_avoid_other_parts="True" -s slicing_tolerance="middle" -s travel_avoid_distance="0.625" -s cross_infill_pocket_size="10.0" -s material_final_print_temperature="205" -s layer_0_z_overlap="0.15" -s support_conical_enabled="False" -s brim_width="8.0" -s acceleration_wall_x="3000" -s dual="0" -s machine_filament_park_distance="16" -s skin_overlap="5" -s jerk_support_roof="20" -s support_roof_pattern="lines" -s zig_zaggify_infill="True" -s expand_skins_expand_distance="1.5" -s bottom_skin_expand_distance="1.5" -s brim_outside_only="True" -s support_bottom_line_distance="0.5" -s wall_line_width_0="0.5" -s skin_alternate_rotation="False" -s acceleration_ironing="3000" -s extruder_prime_pos_z="0" -s infill="0" -s wall_0_wipe_dist="0.1" -s wall_line_width="0.5" -s coasting_volume="0.1" -s machine_nozzle_tip_outer_diameter="1" -s ironing_line_spacing="0.1" -s infill_wipe_dist="0.125" -s jerk_travel="30" -s speed_layer_0="25" -s prime_tower_min_volume="10" -s support_zag_skip_count="8" -s jerk_topbottom="20" -s magic_fuzzy_skin_point_density="1.25" -s material_print_temperature="205" -s top_bottom_pattern="lines" -s cool_fan_speed_max="100" -s gradual_support_infill_steps="0" -s extruder_prime_pos_y="0" -s machine_extruder_end_pos_x="0" -s roofing_pattern="lines" -s raft_surface_thickness="0.2" -s travel_compensate_overlapping_walls_enabled="True" -s infill_before_walls="False" -s support_minimal_diameter="3.0" -s speed_topbottom="45.0" -s machine_nozzle_offset_x="0" -s top_skin_preshrink="1.5" -s machine_heat_zone_length="16" -s shell="0" -s prime_tower_flow="100" -s sub_div_rad_add="0.5" -s gradual_support_infill_step_height="1" -s ironing_inset="0.25" -s acceleration_roofing="3000" -s top_bottom_pattern_0="lines" -s spaghetti_max_height="2.0" -s machine_extruder_end_pos_y="0" -s support_interface_skip_height="0.3" -s wall_line_width_x="0.5" -s raft_surface_line_width="0.5" -s layer_start_y="0.0" -s material_initial_print_temperature="205" -s raft_fan_speed="0" -s raft_base_fan_speed="0" -s support_roof_density="100" -s magic_mesh_surface_mode="normal" -s machine_nozzle_size="0.5" -s wall_thickness="0.8" -s switch_extruder_retraction_speed="20" -s extruder_nr="0" -s support_xy_distance="1" -s raft_interface_line_spacing="1.2" -s outer_inset_first="False" -s infill_overlap_mm="0.05" -s acceleration_prime_tower="3000" -s mold_enabled="False" -s material_flow_dependent_temperature="False" -s machine_extruder_start_pos_abs="False" -s support_top_distance="0.15" -s fill_perimeter_gaps="everywhere" -s raft_base_line_width="1.0" -s z_seam_x="145.0" -s support_tree_collision_resolution="0.25" -s support_join_distance="2.0" -s material_diameter="1.75" -s top_bottom_thickness="0.8" -s acceleration_print="3000" -s infill_sparse_thickness="0.2" -s raft_surface_line_spacing="0.5" -s skirt_line_count="3" -s infill_hollow="False" -s machine_nozzle_offset_y="0" -s raft_margin="15" -s cool_min_layer_time="15" -s wall_line_count="3" -s support_tree_wall_count="1" -s raft_jerk="20" -s speed_wall="40.0" -s speed_wall_0="45.0" -s jerk_prime_tower="20" -s travel_compensate_overlapping_walls_0_enabled="True" -s acceleration_skirt_brim="3000" -s support_tree_branch_distance="4" -s multiple_mesh_overlap="0.15" -s raft_surface_jerk="20" -s acceleration_travel="5000" -s raft_base_thickness="0.36" -s jerk_print_layer_0="20" -s speed_support_interface="23.333333333333332" -s acceleration_layer_0="3000" -s min_skin_width_for_expansion="6.123233995736766e-17" -s z_seam_relative="False" -s jerk_skirt_brim="20" -s machine_extruder_start_pos_y="0" -s support_interface_enable="False" -s support_pattern="zigzag" -s machine_extruder_start_pos_x="0" -s cool_min_layer_time_fan_speed_max="20" -s initial_layer_line_width_factor="100.0" -s jerk_travel_layer_0="30.0" -s min_infill_area="0" -s cool_fan_speed="100.0" -s infill_pattern="cubic" -s coasting_speed="90" -s resolution="0" -s skin_line_width="0.5" -s raft_interface_jerk="20" -s raft_base_speed="22.5" -s speed_support_bottom="23.333333333333332" -s machine_nozzle_heat_up_speed="2.0" -s acceleration_support_interface="3000" -s extruder_prime_pos_x="0" -s retraction_retract_speed="45" -s material_guid="0ff92885-617b-4144-a03c-9989872454bc" -s spaghetti_max_infill_angle="10" -s ironing_enabled="False" -s raft_acceleration="3000" -s magic_fuzzy_skin_enabled="False" -s infill_offset_x="0" -s gradual_infill_step_height="2.0" -s meshfix_keep_open_polygons="False" -s mesh_position_x="0" -s spaghetti_infill_stepped="True" -s support_offset="0.2" -s jerk_roofing="20" -s support_bottom_distance="0.15" -s support_tree_branch_diameter="2" -s support_roof_line_distance="0.5" -s mold_width="5" -s support_infill_sparse_thickness="0.2" -s magic_fuzzy_skin_thickness="0.3" -s mold_angle="40" -s skin_overlap_mm="0.025" -s speed_equalize_flow_enabled="False" -s support_roof_height="1" -s support_interface_pattern="lines" -s infill_sparse_density="15" -s acceleration_support_roof="3000" -s machine_extruder_end_pos_abs="False" -s z_seam_type="sharpest_corner" -s wall_0_inset="0" -s cooling="0" -s raft_interface_fan_speed="0" -s support_skip_some_zags="False" -s prime_tower_purge_volume="0" -s raft_airgap="0.3" -s speed_wall_x="50.0" -s material_flow_temp_graph="[[3.5,200],[7.0,240]]" -s retraction_hop_after_extruder_switch="True" -s spaghetti_infill_enabled="False" -s skin_angles="[ ]" -s jerk_infill="20" -s jerk_print="20" -s support_interface_height="1" -s spaghetti_inset="0.2" -s support_connect_zigzags="True" -s retraction_hop_only_when_collides="False" -s support_interface_density="100" -s prime_tower_wipe_enabled="True" -s support_use_towers="True" -s conical_overhang_angle="50" -s raft_smoothing="5" -s jerk_wall="20" -s speed_support_infill="35" -s skirt_brim_minimal_length="200" -s platform_adhesion="0" -s jerk_wall_0="20" -s skirt_brim_line_width="0.5" -s support_interface_line_width="0.5" -s brim_line_count="3" -s material_adhesion_tendency="10" -s support_tree_branch_diameter_angle="5" -s support_conical_min_width="5.0" -s machine_nozzle_id="unknown" -s jerk_layer_0="20" -s retract_at_layer_change="False" -s speed_print="60" -s speed_roofing="45.0" -s skin_no_small_gaps_heuristic="True" -s mesh_rotation_matrix="[[1,0,0], [0,1,0], [0,0,1]]" -s acceleration_wall_0="3000" -s jerk_ironing="20" -s retraction_enable="True" -s max_feedrate_z_override="500" -s mesh_position_z="0" -s retraction_extra_prime_amount="0" -s mesh_position_y="0" -s support_tree_angle="40" -s spaghetti_infill_extra_volume="0" -s machine_min_cool_heat_time_window="50.0" -s speed_print_layer_0="25" -s infill_line_width="0.5" -s meshfix_extensive_stitching="False" -s coasting_min_volume="0.8" -s support_angle="40" -s switch_extruder_prime_speed="20" -s raft_base_acceleration="3000" -s command_line_settings="0" -e0 -l "0"
                  2018-03-20 08:20:12,134 - DEBUG - [(14640)-Thread-16] UM.Backend.Backend._backendLog [90]: [Backend] [WARNING] There are empty layers (or layers with empty extruder plans) in the print! Temperature control and cross layer travel moves might suffer.
                  2018-03-20 08:20:13,049 - DEBUG - [(11228)-MainThread] CuraEngineBackend.CuraEngineBackend._onSlicingFinishedMessage [582]: Slicing took 3.695173978805542 seconds
                  2018-03-20 08:20:13,050 - DEBUG - [(11228)-MainThread] CuraEngineBackend.CuraEngineBackend._onSlicingFinishedMessage [591]: See if there is more to slice…
                  2018-03-20 08:20:13,052 - DEBUG - [(11228)-MainThread] UM.Backend.Backend._logSocketState [181]: Socket state changed to Closing
                  2018-03-20 08:20:13,053 - DEBUG - [(11228)-MainThread] UM.Backend.Backend._onSocketError [203]: Socket debug: Arcus Error (13): Closing socket because other side requested close.
                  2018-03-20 08:20:13,055 - DEBUG - [(11228)-MainThread] UM.Backend.Backend._logSocketState [183]: Socket state changed to Closed
                  2018-03-20 08:20:13,067 - DEBUG - [(11228)-MainThread] CuraEngineBackend.CuraEngineBackend._onBackendQuit [722]: Backend quit with return code 0. Resetting process and socket.
                  2018-03-20 08:20:18,853 - DEBUG - [(11228)-MainThread] AutoSave.AutoSave._onTimeout [71]: Autosaving preferences, instances and profiles
                  2018-03-20 08:20:22,291 - DEBUG - [(11228)-MainThread] Cura-DuetRRFPlugin-master.DuetRRFOutputDevice.onFilenameAccepted [144]: Filename set to: A_Semi.gcode
                  2018-03-20 08:20:22,293 - DEBUG - [(11228)-MainThread] SliceInfoPlugin.SliceInfo._onWriteStarted [66]: 'info/send_slice_info' is turned off.
                  2018-03-20 08:20:22,294 - DEBUG - [(11228)-MainThread] Cura-DuetRRFPlugin-master.DuetRRFOutputDevice.onFilenameAccepted [157]: Loading gcode…
                  2018-03-20 08:20:22,294 - DEBUG - [(11228)-MainThread] Cura-DuetRRFPlugin-master.DuetRRFOutputDevice.onFilenameAccepted [177]: Connecting…
                  2018-03-20 08:20:23,526 - ERROR - [(11228)-MainThread] Cura-DuetRRFPlugin-master.DuetRRFOutputDevice._onNetworkError [353]: _onNetworkError: 301
                  2018-03-20 08:20:29,240 - DEBUG - [(11228)-MainThread] UM.Qt.QtApplication.windowClosed [345]: Shutting down cura
                  2018-03-20 08:20:29,320 - DEBUG - [(11228)-MainThread] CuraEngineBackend.CuraEngineBackend._terminate [262]: Attempting to kill the engine process
                  • resam
                    resam last edited by
                    Thanks for the log file!
                    I made a few fixes and changes to the settings dialog.
                    Please try v0.0.10 from https://github.com/Kriechi/Cura-DuetRRFPlugin/releases/tag/v0.0.10
                    Then delete & recreate the DuetRRF settings entry and try to print something.
                    Finally please paste your log file again, I'm only interested in lines which contain "Cura-DuetRRFPlugin".
                    • magicmarc
                      magicmarc last edited by
                      y'all are the best! ill d/load the v0.0.10 this afternoon, and install it, re-create the duetrrf config, and test it out!
                      also, what do i enter for the passwords:
                      duet password: reprap ?
                      http basic user: ?
                      http auth basic password: ?
                      • magicmarc
                        so i just tried this out (im at work so im doing remotely on my home pc…)
                        however, i used the v0.0.10 and recreated the printer in the extension, gave the password 'reprap', and left the otehr 2 user / password boxes blank.
                        i tried to upload to the duet-artemis (since im not there and i have something else currently printing... i tested with the 'upload' only for now...
                        got the following error attmepting to upload:
                        there was a network error: 3 host 173.16.31.76rr connect_not_found,
                        and heres the lines from the cura.log
                        2018-03-20 10:45:58,695 - DEBUG - [(13308)-Thread-9] USBPrinting.USBPrinterOutputDevice.close [413]: PrinterConnection.close: cannot join current thread (expected)
                        2018-03-20 10:45:58,699 - WARNING - [(6976)-MainThread] UM.OutputDevice.OutputDeviceManager.removeOutputDevice [126]: Could not find output device with id COM5 to remove
                        2018-03-20 10:48:05,492 - DEBUG - [(6976)-MainThread] Cura-DuetRRFPlugin-master.DuetRRFOutputDevice.onFilenameAccepted [143]: Filename set to: A_Semi.gcode
                        2018-03-20 10:48:05,492 - DEBUG - [(6976)-MainThread] SliceInfoPlugin.SliceInfo._onWriteStarted [66]: 'info/send_slice_info' is turned off.
                        2018-03-20 10:48:05,493 - DEBUG - [(6976)-MainThread] Cura-DuetRRFPlugin-master.DuetRRFOutputDevice.onFilenameAccepted [156]: Loading gcode…
                        2018-03-20 10:48:05,493 - DEBUG - [(6976)-MainThread] Cura-DuetRRFPlugin-master.DuetRRFOutputDevice.onFilenameAccepted [176]: Connecting…
                        2018-03-20 10:48:05,530 - ERROR - [(6976)-MainThread] Cura-DuetRRFPlugin-master.DuetRRFOutputDevice._onNetworkError [352]: _onNetworkError: 3
                        • resam
                          Please add a '/' at the end of your URL and try again.
                          There should be a log messing like "URL set to: …"
                          If you did not use M551 in your config.g, then the password should be 'reprap' or blank.
                          If you don't know what HTTP basic auth is, then leave those fields empty. If you run a reverse proxy to access DWC which adds HTTP basic auth, then you could specify your credentials here.
                          • magicmarc
                            PRESTO, i restarted after adding the '/' and it uploaded to the duet! you are the best. i love support forums with experts and creators!
                            ill follow up when i get home to the actual system/printer and try to 'print to the duet/artemis'!!!
                            • resam
                              Great! I'll try to make it a bit smarter and add the final '/' automatically.
                              Just as a small follow up, since I don't have a Windows machine myself:
                              Do the two dialog windows look good? Too small or too big? Are all the labels/headers legible?
                              • magicmarc
                                they look / seem great! i've attached links to the pics of the screenshots.
                                screenshots:
                                https://drive.google.com/file/d/1OJot52kcPcI_lhu6eXJbHUt2grTq9hHb/view?usp=sharing
                                https://drive.google.com/file/d/1MJ1EgVX3GVRuyfEY9jKrvdYvZwxhH1is/view?usp=sharing
                                • Guyaros
                                  Guyaros last edited by
                                  DuetRRF Cura plugin doesn't work with Cura 3.3 or 3.3.1
                                  I followed the exact installation instruction, on 2 different computers, but still no luck.
                                  any solutions?
                                  Thanks,
                                  • resam
                                    @Guyaros do you get any error messages or does it simply not show up?
                                    I'm running the Cura 3.3 beta without issues.
                                    Make sure to use the latest DuetRRF-Cura plugin from GitHub!
                                    Guyaros 1 Reply Last reply Reply Quote 0
                                    • Guyaros
                                      Guyaros @resam last edited by
                                      @resam said in DuetRFF Cura plugin - not working/recognizing in cura?:
                                      DuetRRF-Cura plugin
                                      Thanks for your reply.
                                      it simply not show up in Cura.
                                      I've downloaded Cura-DuetRRFPlugin-0.0.16.zip from this link:
                                      link text
                                      resam 1 Reply Last reply Reply Quote 0
                                      • resam
                                        resam @Guyaros last edited by
                                        @guyaros and where did you extract it?
                                        can you please show me the folder structure of your Cura config directory?
                                        • Guyaros
                                          @resam
                                          • resam
                                            Ok, this looks right.
                                            Can you please start Cura and then check your Cura log file for any lines with Cura-DuetRRFPlugin? The log file should be in ....\AppData\Roaming\cura\3.3\cura.log.
                                            You only need to check near the end of the file, as it is probably quite long.
                                            • Guyaros
                                              Guyaros last edited by Guyaros
                                              @resam
                                              • resam
                                                Remove the -.0.0.16 from the Cura-DuetRRFPlugin folder name - then it should work!
                                                • Guyaros
                                                  Thank you very much!
                                                  now it's working. 👍
