    How to connect integrated servo motors
    6.9k
      dc42 administrators @dk
      @dk said in How to connect integrated servo motors:
      No result with M569.
      To break the task into 2 steps I replaced the servo motors with Steppers. First, I Want to achieve, the hand moved as expected. Then I will deal with the connection of the Clearpath servo instead of Steppers.
      My scar arm even easier than Robotdigg SCARA printer which you took apart in your blog. I don't need the z-axis. And homing allso, not need, I physically move the arm in the position from which it must start moving.
      If it is possible, Please send me settings for this configuration.
      PS link to the setup files at the end of your article does not work (https://miscsolutions.files.wordpress.com/2017/08/robotdigg-scara-duet-config2.odt)
      I will correct the link. Please post your config.g file.
      To "home" the printer, after placing the arm in the correct position use the G92 command to tell the firmware what the X and Y coordinates are.
      • dkundefined
        dk
        This is my settings
        M550 PScara ; Set machine name
        M552 S1 ; Enable network
        M586 P0 S1 ; Enable HTTP
        M586 P1 S0 ; Disable FTP
        M586 P2 S0 ; Disable Telnet
        M584 X6 Y7 ; remap drive to extension board E3 and E4
        M569 P5 R1 T1:1:25:1 ; from Clearpath manual
        M350 X16 Y16 I1 ; Configure microstepping with interpolation
        M92 X266.66 Y266.66 ; Set steps per mm (30:1 gearbox) OR use 66.66 (800 step per revolution for Clearpath motor
        M669 K4 P600 D600 A-90:90 B-120:120 C0:0:0 ; 600mm both arms
        M566 X1800 Y1800 ; Set maximum instantaneous speed changes (mm/min)
        M203 X6000 Y6000 ; Set maximum speeds (mm/min)
        M201 X600 Y600 ; Set accelerations (mm/s^2)
        M906 X1200 Y1200 I30 ; Set motor currents (mA) and motor idle factor in per cent
        M84 S30 ; Set idle timeout
        G92 ; set start point
        M140 H-1 ; Disable heated bed
        • dkundefined
          dk
          from Clearpath manual:
            The setup time is 25ns not 25us, so instead of 1:1:25:1 I suggest 1:1:0.5:0 in the M569 T parameter. My suggestion to use 0.5us setup time is to allow for possible skew in the opto isolators.
              PS - as per the wiki docs, when remapping axis drivers with M584 you must also re-specify the extruder driver numbers.
              • dkundefined
                dk
                But I do not have extruder and Z-axis (this is simple drawing arm). Do I still need to include them in config.g?
                  Yes, so that any commands you issue that relate to extruders (e.g. M350) don't also affect the motors you have remapped. You can add e.g. E10 if you have no extruders.
                  • Edkirkundefined
                    Edkirk @JaredC
                    @jaredc Yes I am running my CoreXY with Clearpath motors on X,Y and Z. Although I have to make a confession, I purchased a Duet WiFi months ago to replace the Rambo 2 board but got interested in using the Delta Smart Effector and built a Delta instead, works great and I really like it.
                    Anyway to make sure the the Clearpath motors work with the Duet WiFi I installed a Duet WiFi today, did a rough setup with RepRap Configurator, installed the Duet Expansion Header Breakout board and connected the Cleatpath motors turned it on and tested, The Clearpath motors work just like they are supposed to. About 4 hours to replace the board. Next step is tune everything for the Duet WiFi.
                    Ed
                    • dkundefined
                      dk
                      Ed, can you please share your settings? I get stuck with config.g Clearpath did not want to move
                      Edkirkundefined 1 Reply Last reply Reply Quote 0
                      • Edkirkundefined
                        Edkirk
                        I do not know how to copy things to this forum, try the attached config.g file. If it doesn't work I will create a text file and sent it. I used the RepRap Configurator, if I could I would sent the entire sys folder.
                        Ed
                        0_1523625874032_config.g
                        • Edkirkundefined
                          Edkirk @dk
                          @dk
                          The config.g file I used is from my back-up folder, sorry about that. Try this file. It opens Repetier and then use the "Edit G-Code"
                          0_1523627082930_config.g
