Problems with pause function M226
When I resum printing, the unretract is always executed first, no matter what order I try.
I can also change the feedrate and nothing happens.
[[language]] ; resume.g ; called before a print from SD card is resumed ; ; generated by RepRapFirmware Configuration Tool on Sat Mar 10 2018 12:05:11 GMT+0100 (Mitteleuropäische Zeit) M83 ; relative extruder moves G1 R1 Z5 F9000 ; go to 5mm above position of the last print move G1 R1 ; go back to the last print move M83 M400 G1 E10 F2400 ; extrude 10mm of filament
Firmware Version: 1.21RC4 (2018-03-11 build 1)
WiFi Server Version: 1.21RC4(08b3)
Web Interface Version: 1.21-RC4Please help
You need to add parameters X0 Y0 to your two G1 R1 commands.
Thanks for the right tip, with Z (+X;Y) it works as it should.
[[language]] G1 R1 X0 Y0 Z5 F9000 ; go to 5mm above position of the last print move G1 R1 X0 Y0 Z0; go back to the last print move
Have not read this anywhere.
Was created by "RepRapFirmware Configuration"!Thanks
Thanks, I'll have the configurator changed. The firmware was changed (in version 1.19 AFAIR - see the release notes) so that any axes not mentioned are not moved.
