    M80 automatically when setting temperature via web interface?
    • Qdeathstarundefined
      Qdeathstar
      As the title states, is it possible to edit the firmware so that when you type in a temperature into the web interface, but the PSU is turned off, that it automatically turns on so that the printer will warm up? Now, if i make a change to the firmware and the duet resets, but i want to turn the heat back on i have to do the extra step of turning on the 12v…. would be nice to have that happen once i set the temperature.
      Thanks!
        IMO that would be best implemented in Duet Web Control so that it is optional. So please raise it in the DWC Wishlist section. One thing that the firmware could do to help is to return a "Powered down" status to DWC so that it knows when the Duet doesn't have VIN power.
