Running macros in response to conditions?
Thanks, David. In the arrangement I have now, the only movement command in config.g is G28. The others are all in the macros.
Understood on heating the bed first - I generally do G32 again after getting the bed and nozzle to temperature. The first G32 is only intended to make sure I at least do one before printing even if it is approximate - without it I used to forget and ended up carving notches in the print surface!
Richard
If you really want to run your trigger followed by G28 you could set up trigger 3 to do the G28, using a spare endstop input that is always high (e.g. on the expansion connector or on CONN_LCD). The triggers will be run in trigger number order.
As you only want to run each trigger macro once, for safety I suggest you end each macro with a M581 command to disable the trigger.
I'm missing something, David, I'm sorry but I don't understand.
At the moment I only run a blocking message and a G28 (last line) in the config.g. This is on a large delta and it homes to max Z. Do you recommend not putting the G28 in the config.g?
The hold message reminds me to run the delta_start macro that will call the trigger function. After reading your note above I will move the M581 command from the config.g to this macro so that it is only called when I run that macro. I will also use the S-1 notation to disable it afterwards.
Thanks for your help.
Richard
I was suggesting a way in which you can make your macro run automatically and defer the G28 until after the macro has run.
Oh, OK, thanks for clarifying.
I'm very happy with where this ended up - when the printer starts up it displays a message telling me to run the Delta_Start macro.
This sets the trigger (M581), checks which Smart Effector is installed, then homes the printer, runs delta config and then disables the trigger condition.
It works great and I won't get caught out with the Volcano installed and think I have the shorter v6!
Richard
