    Setup For A SeeMeCnC Rostock Max V2 with laser cut trucks etc
    Example setups and prints
    • DannyCurran
      DannyCurran last edited by
      Folks looking for a quick steer.
      I have Max V2 where I have added a second extruder but kept the original arms and delta hardware.
      Where I am currently is I have all the drives running correctly eg I can home axis , drive the extruders and have the heaters running and PID tuned.
      I gave the original Rambo source code and references to it but at the moment have struggled to apply it to duo settings.
      eg on the Rambo you could drive the Z axis down till you reached the table and set the Z axis limit but I haven't seen how to do it on a duet yet.
      If you can help out I would be grateful
      Thanks
      Danny
        Does your printer have a Z probe, or not?
        • DannyCurran
          It will do
          One of yours ( But its not connected up yet )
            Until you have a Z probe, you can set the Z probe type to 0 in the M558 command (M558 P0). Then you can run delta calibration as normal (see https://duet3d.dozuki.com/Wiki/Calibrating_a_delta_printer)) and the web interface will prompt you. If you just want to establish an accurate Z=0 height before printing, position the nozzle over the centre of the bed and send G30.
            HTH David
