Connecting to wifi in windows environment
I can see the DuetWiFi on the secure wifi at the office it assigns it 2 IP address 10.54.24.171, in the process of connecting it keeps resetting the WiFi ,can anyone help me get this connected or point me in the right direction?
Please explain what you mean by "in the process of connecting it keeps resetting the WiFi".
Her is what it looks like it is assigning 2 IP address. When I put the 10.54.24.171 in the Firefox browser it just searches and never connects. I have Mac at home and have no problem connecting, not a windows fan but it is what we have at work. It has not done a reset so far however I cannot connect thru browser.
Attempting connection at \.\COM13…
Testing plaintext communication protocol...
READ: ok
Connected to machine!
SENT: T0
READ: ok
SENT: M105
READ: ok T:B:-273.1
SENT: M105
READ: ok T:B:-273.1
SENT: M552
READ: Network is enabled, configured IP address: 192.168.1.10, actual IP address: 10.54.24.171, HTTP port: 80
READ: ok
SENT: M105
READ: ok T:B:-273.1
SENT: M105
READ: ok T:B:-273.1SENT: M115
READ: FIRMWARE_NAME: RepRapFirmware for Duet WiFi FIRMWARE_VERSION: 1.15c ELECTRONICS: Duet WiFi 1.0 DATE: 2016-09-05
My guess is that your corporate router is blocking the connection. Can you ping the Duet WiFi?
Yes pinging the Duet is no problem: I have updated all and here is what is going on:
READ: DuetWiFiServer version 1.03 (ch fork)
READ: Flash size 4194304, free RAM 32840 bytes, WiFi Vcc 3.12V, host name: duetwifi, reset reason: Turned on by main processor
READ: WiFi server connected to access point TipperTie-Apex-Secure, IP=10.54.24.171, signal strength=-67dBm
READ: Flash size 4194304, free RAM 32840 bytes, WiFi Vcc 3.12V, host name: duetwifi, reset reason: Exception
READ: WiFi server connected to access point TipperTie-Apex-Secure, IP=10.54.24.171, signal strength=-68dBm
READ: WiFi server connected to access point TipperTie-Apex-Secure, IP=10.54.24.171, signal strength=-71dBm
READ: WiFi server connected to access point TipperTie-Apex-Secure, IP=10.54.24.171, signal strength=-69dBmREAD: FIRMWARE_NAME: RepRapFirmware for Duet WiFi FIRMWARE_VERSION: 1.16 ELECTRONICS: Duet WiFi 1.0 FIRMWARE_DATE: 2016-11-08
READ: ok
Here is the ping info
H:>C:
C:>ping 10.54.24.171
Pinging 10.54.24.171 with 32 bytes of data:
Reply from 10.54.24.171: bytes=32 time=5ms TTL=128
Reply from 10.54.24.171: bytes=32 time=4ms TTL=128
Reply from 10.54.24.171: bytes=32 time=3ms TTL=128Ping statistics for 10.54.24.171:
Packets: Sent = 4, Received = 4, Lost = 0 (0% loss),
Approximate round trip times in milli-seconds:
Minimum = 3ms, Maximum = 5ms, Average = 4msC:>
Can't you connect to 192.168.1.10?
So the Duet is responding to pings but apparently not to HTTP requests. Your corporate router may be blocking requests t named IP addresses as part if a corporate internet access policy. Does your company have an IT department you can ask?
Two things you can try:
1. Load the developer console in FireFox by pressing control-shift-J, and see if there are any error messages.
2. Use Wireshark on your PC to log the network traffic to/from the Duet's IP address - if you are allowed to install WireShark on the PC.
I have been working with my IT department. They are trying to figure out why the DuetWiFi keeps resetting itself. I have posted the logs from the S3D console above.
Sometimes the page loading will say DuetWiFi but even then it does not connect or bring up the web control page. I brought up the developer console but did not see any errors.
It would be nice to work for a company that just had MACS.
The other question is why is it configuring a 192 address and actual address 10.54.24.171?
READ: ok
The configured IP address is currently ignored by the Duet WiFi, it can only get its IP address via DHCP.
I understand now, the WiFi module keeps resetting itself because of an exception. Must be a bug in DuetWiFiServer. Try installing the previous DuetWiFiServer version 1.02 in case it makes any difference.
I installed the Version 1.02 and it still is resetting itself because of an exception.
Still have resetting issues, I have been working with IT. They sent me the wireshark info and I have added below. Hopefully someone can shed some light on the issue I am having
READ: ok
READ: DuetWiFiServer version 1.02
READ: Flash size 4194304, free RAM 31504 bytes, WiFi Vcc 3.37V, host name: duetwifi, reset reason: Exception
READ: WiFi server connected to access point TipperTie-Apex-Secure, IP=10.54.24.171, signal strength=-62dBm
READ: WiFi server connected to access point TipperTie-Apex-Secure, IP=10.54.24.171, signal strength=-63dBm
SENT: M552
READ: ok
SENT: M552
READ: ok
READ: Flash size 4194304, free RAM 31504 bytes, WiFi Vcc 3.37V, host name: duetwifi, reset reason: Software restart
READ: WiFi server connected to access point TipperTie-Apex-Secure, IP=10.54.24.171, signal strength=-62dBmNo. Time Source Destination Protocol Length Info
570 34.419180 10.54.22.74 10.54.24.171 TCP 66 52160→80 [SYN] Seq=0 Win=8192 Len=0 MSS=1460 WS=256 SACK_PERM=1Frame 570: 66 bytes on wire (528 bits), 66 bytes captured (528 bits) on interface 0
Ethernet II, Src: PacketFo_8c:51:28 (00:23:56:8c:51:28), Dst: CiscoInc_d1:2d:3f (88:5a:92:d1:2d:3f)
Internet Protocol Version 4, Src: 10.54.22.74, Dst: 10.54.24.171
Transmission Control Protocol, Src Port: 52160, Dst Port: 80, Seq: 0, Len: 0
Source Port: 52160
Destination Port: 80
[Stream index: 62]
[TCP Segment Len: 0]
Sequence number: 0 (relative sequence number)
Acknowledgment number: 0
Header Length: 32 bytes
Flags: 0x002 (SYN)
000. …. .... = Reserved: Not set
...0 .... .... = Nonce: Not set
.... 0... .... = Congestion Window Reduced (CWR): Not set
.... .0.. .... = ECN-Echo: Not set
.... ..0. .... = Urgent: Not set
.... ...0 .... = Acknowledgment: Not set
.... .... 0... = Push: Not set
.... .... .0.. = Reset: Not set
.... .... ..1. = Syn: Set
[Expert Info (Chat/Sequence): Connection establish request (SYN): server port 80]
…. .... ...0 = Fin: Not set
[TCP Flags: ··········S·]
Window size value: 8192
[Calculated window size: 8192]
Checksum: 0x4387 [unverified]
[Checksum Status: Unverified]
Urgent pointer: 0
Options: (12 bytes), Maximum segment size, No-Operation (NOP), Window scale, No-Operation (NOP), No-Operation (NOP), SACK permittedNo. Time Source Destination Protocol Length Info
572 34.424494 10.54.22.74 10.54.24.171 TCP 54 52160→80 [ACK] Seq=1 Ack=1 Win=65142 Len=0Frame 572: 54 bytes on wire (432 bits), 54 bytes captured (432 bits) on interface 0
Transmission Control Protocol, Src Port: 52160, Dst Port: 80, Seq: 1, Ack: 1, Len: 0
Source Port: 52160
[Stream index: 62]
Sequence number: 1 (relative sequence number)
Acknowledgment number: 1 (relative ack number)
Header Length: 20 bytes
Flags: 0x010 (ACK)
.... ...1 .... = Acknowledgment: Set
.... .... ..0. = Syn: Not set
.... .... ...0 = Fin: Not set
[TCP Flags: ·······A····]
Window size value: 65142
[Calculated window size: 65142]
[Window size scaling factor: -2 (no window scaling used)]
Checksum: 0x437b [unverified]
Urgent pointer: 0
[SEQ/ACK analysis]
[This is an ACK to the segment in frame: 571]
[The RTT to ACK the segment was: 0.000096000 seconds]
[iRTT: 0.005314000 seconds]No. Time Source Destination Protocol Length Info
573 34.424618 10.54.22.74 10.54.24.171 HTTP 371 GET / HTTP/1.1Frame 573: 371 bytes on wire (2968 bits), 371 bytes captured (2968 bits) on interface 0
Transmission Control Protocol, Src Port: 52160, Dst Port: 80, Seq: 1, Ack: 1, Len: 317
Source Port: 52160
[Stream index: 62]
[TCP Segment Len: 317]
[Next sequence number: 318 (relative sequence number)]
Flags: 0x018 (PSH, ACK)
.... .... 1... = Push: Set
[TCP Flags: ·······AP···]
Checksum: 0x44b8 [unverified]
Urgent pointer: 0
[SEQ/ACK analysis]
[Bytes in flight: 317]
[Bytes sent since last PSH flag: 317]
Hypertext Transfer Protocol
GET / HTTP/1.1\r\n
[Expert Info (Chat/Sequence): GET / HTTP/1.1\r\n]
Request Method: GET
Request URI: /
Request Version: HTTP/1.1
Host: 10.54.24.171\r\n
User-Agent: Mozilla/5.0 (Windows NT 10.0; WOW64; rv:49.0) Gecko/20100101 Firefox/49.0\r\n
Accept: text/html,application/xhtml+xml,application/xml;q=0.9,/;q=0.8\r\n
Accept-Language: en-US,en;q=0.5\r\n
Accept-Encoding: gzip, deflate\r\n
Connection: keep-alive\r\n
Upgrade-Insecure-Requests: 1\r\n
\r\n
[Full request URI: [url]http://10.54.24.171/]
[HTTP request 1/1]No. Time Source Destination Protocol Length Info
999 44.531723 10.54.22.74 10.54.24.171 TCP 55 [TCP Keep-Alive] 52160→80 [ACK] Seq=317 Ack=1 Win=65142 Len=1Frame 999: 55 bytes on wire (440 bits), 55 bytes captured (440 bits) on interface 0
Transmission Control Protocol, Src Port: 52160, Dst Port: 80, Seq: 317, Ack: 1, Len: 1
Source Port: 52160
[Stream index: 62]
[TCP Segment Len: 1]
Sequence number: 317 (relative sequence number)
Flags: 0x010 (ACK)
Checksum: 0x437c [unverified]
Urgent pointer: 0
[SEQ/ACK analysis]
[Bytes in flight: 1]
[Bytes sent since last PSH flag: 1]
[TCP Analysis Flags]
[Expert Info (Note/Sequence): TCP keep-alive segment]
Data (1 byte)0000 00 .
1001 44.539106 10.54.22.74 10.54.24.171 TCP 54 [TCP Dup ACK 572#1] 52160→80 [ACK] Seq=318 Ack=1 Win=65142 Len=0Frame 1001: 54 bytes on wire (432 bits), 54 bytes captured (432 bits) on interface 0
Transmission Control Protocol, Src Port: 52160, Dst Port: 80, Seq: 318, Ack: 1, Len: 0
Source Port: 52160
[Stream index: 62]
Sequence number: 318 (relative sequence number)
Flags: 0x010 (ACK)
Urgent pointer: 0
[SEQ/ACK analysis]
[This is a TCP duplicate ack]
[Duplicate ACK #: 1]
[Duplicate to the ACK in frame: 572]
[Expert Info (Note/Sequence): Duplicate ACK (#1)]No. Time Source Destination Protocol Length Info
1024 45.532290 10.54.22.74 10.54.24.171 TCP 55 [TCP Keep-Alive] 52160→80 [ACK] Seq=317 Ack=1 Win=65142 Len=1Frame 1024: 55 bytes on wire (440 bits), 55 bytes captured (440 bits) on interface 0
Source Port: 52160
[Stream index: 62]
Flags: 0x010 (ACK)
Urgent pointer: 0
[SEQ/ACK analysis]
[Bytes sent since last PSH flag: 2]
1041 46.532352 10.54.22.74 10.54.24.171 TCP 55 [TCP Keep-Alive] 52160→80 [ACK] Seq=317 Ack=1 Win=65142 Len=1Frame 1041: 55 bytes on wire (440 bits), 55 bytes captured (440 bits) on interface 0
Source Port: 52160
[Stream index: 62]
Flags: 0x010 (ACK)
Urgent pointer: 0
[SEQ/ACK analysis]
[Bytes sent since last PSH flag: 3]
1055 47.532789 10.54.22.74 10.54.24.171 TCP 55 [TCP Keep-Alive] 52160→80 [ACK] Seq=317 Ack=1 Win=65142 Len=1Frame 1055: 55 bytes on wire (440 bits), 55 bytes captured (440 bits) on interface 0
Source Port: 52160
[Stream index: 62]
Flags: 0x010 (ACK)
Urgent pointer: 0
[SEQ/ACK analysis]
[Bytes sent since last PSH flag: 4]
1060 48.533501 10.54.22.74 10.54.24.171 TCP 55 [TCP Keep-Alive] 52160→80 [ACK] Seq=317 Ack=1 Win=65142 Len=1Frame 1060: 55 bytes on wire (440 bits), 55 bytes captured (440 bits) on interface 0
Source Port: 52160
[Stream index: 62]
Flags: 0x010 (ACK)
Urgent pointer: 0
[SEQ/ACK analysis]
[Bytes sent since last PSH flag: 5]
1128 49.534717 10.54.22.74 10.54.24.171 TCP 55 [TCP Keep-Alive] 52160→80 [ACK] Seq=317 Ack=1 Win=65142 Len=1Frame 1128: 55 bytes on wire (440 bits), 55 bytes captured (440 bits) on interface 0
Source Port: 52160
[Stream index: 62]
Flags: 0x010 (ACK)
Urgent pointer: 0
[SEQ/ACK analysis]
[Bytes sent since last PSH flag: 6]
1140 50.535052 10.54.22.74 10.54.24.171 TCP 55 [TCP Keep-Alive] 52160→80 [ACK] Seq=317 Ack=1 Win=65142 Len=1Frame 1140: 55 bytes on wire (440 bits), 55 bytes captured (440 bits) on interface 0
Source Port: 52160
[Stream index: 62]
Flags: 0x010 (ACK)
Urgent pointer: 0
[SEQ/ACK analysis]
[Bytes sent since last PSH flag: 7]
1199 51.534834 10.54.22.74 10.54.24.171 TCP 55 [TCP Keep-Alive] 52160→80 [ACK] Seq=317 Ack=1 Win=65142 Len=1Frame 1199: 55 bytes on wire (440 bits), 55 bytes captured (440 bits) on interface 0
Source Port: 52160
[Stream index: 62]
Flags: 0x010 (ACK)
Urgent pointer: 0
[SEQ/ACK analysis]
[Bytes sent since last PSH flag: 8]
1206 52.535115 10.54.22.74 10.54.24.171 TCP 55 [TCP Keep-Alive] 52160→80 [ACK] Seq=317 Ack=1 Win=65142 Len=1Frame 1206: 55 bytes on wire (440 bits), 55 bytes captured (440 bits) on interface 0
Source Port: 52160
[Stream index: 62]
Flags: 0x010 (ACK)
Urgent pointer: 0
[SEQ/ACK analysis]
[Bytes sent since last PSH flag: 9]
1223 53.535150 10.54.22.74 10.54.24.171 TCP 55 [TCP Keep-Alive] 52160→80 [ACK] Seq=317 Ack=1 Win=65142 Len=1Frame 1223: 55 bytes on wire (440 bits), 55 bytes captured (440 bits) on interface 0
Source Port: 52160
[Stream index: 62]
Flags: 0x010 (ACK)
Urgent pointer: 0
[SEQ/ACK analysis]
[Bytes sent since last PSH flag: 10]
1233 54.535420 10.54.22.74 10.54.24.171 TCP 54 52160→80 [RST, ACK] Seq=318 Ack=1 Win=0 Len=0Frame 1233: 54 bytes on wire (432 bits), 54 bytes captured (432 bits) on interface 0
Source Port: 52160
[Stream index: 62]
Flags: 0x014 (RST, ACK)
.... .... .1.. = Reset: Set
[Expert Info (Warning/Sequence): Connection reset (RST)]
…. .... ..0. = Syn: Not set
[TCP Flags: ·······A·R··]
Window size value: 0
[Calculated window size: 0]
Urgent pointer: 0No. Time Source Destination Protocol Length Info
1234 54.536699 10.54.22.74 10.54.24.171 TCP 66 52164→80 [SYN] Seq=0 Win=8192 Len=0 MSS=1460 WS=256 SACK_PERM=1Frame 1234: 66 bytes on wire (528 bits), 66 bytes captured (528 bits) on interface 0
Transmission Control Protocol, Src Port: 52164, Dst Port: 80, Seq: 0, Len: 0
Source Port: 52164
[Stream index: 69]
Flags: 0x002 (SYN)
Urgent pointer: 0
1237 54.538901 10.54.22.74 10.54.24.171 TCP 54 52164→80 [ACK] Seq=1 Ack=1 Win=65142 Len=0Frame 1237: 54 bytes on wire (432 bits), 54 bytes captured (432 bits) on interface 0
Transmission Control Protocol, Src Port: 52164, Dst Port: 80, Seq: 1, Ack: 1, Len: 0
Source Port: 52164
[Stream index: 69]
Flags: 0x010 (ACK)
Urgent pointer: 0
[SEQ/ACK analysis]
[This is an ACK to the segment in frame: 1236]
[The RTT to ACK the segment was: 0.000112000 seconds]
[iRTT: 0.002202000 seconds]No. Time Source Destination Protocol Length Info
1238 54.539171 10.54.22.74 10.54.24.171 HTTP 371 GET / HTTP/1.1Frame 1238: 371 bytes on wire (2968 bits), 371 bytes captured (2968 bits) on interface 0
Transmission Control Protocol, Src Port: 52164, Dst Port: 80, Seq: 1, Ack: 1, Len: 317
Source Port: 52164
[Stream index: 69]
Urgent pointer: 0
[SEQ/ACK analysis]
GET / HTTP/1.1\r\n
Request Method: GET
Request URI: /
\r\n
1309 64.625354 10.54.22.74 10.54.24.171 TCP 55 [TCP Keep-Alive] 52164→80 [ACK] Seq=317 Ack=1 Win=65142 Len=1Frame 1309: 55 bytes on wire (440 bits), 55 bytes captured (440 bits) on interface 0
Transmission Control Protocol, Src Port: 52164, Dst Port: 80, Seq: 317, Ack: 1, Len: 1
Source Port: 52164
[Stream index: 69]
Flags: 0x010 (ACK)
Urgent pointer: 0
[SEQ/ACK analysis]
1379 74.721393 10.54.22.74 10.54.24.171 TCP 55 [TCP Keep-Alive] 52164→80 [ACK] Seq=317 Ack=1 Win=65142 Len=1Frame 1379: 55 bytes on wire (440 bits), 55 bytes captured (440 bits) on interface 0
Source Port: 52164
[Stream index: 69]
Flags: 0x010 (ACK)
Urgent pointer: 0
[SEQ/ACK analysis]
1465 84.757394 10.54.22.74 10.54.24.171 TCP 55 [TCP Keep-Alive] 52164→80 [ACK] Seq=317 Ack=1 Win=65142 Len=1Frame 1465: 55 bytes on wire (440 bits), 55 bytes captured (440 bits) on interface 0
Source Port: 52164
[Stream index: 69]
Flags: 0x010 (ACK)
Urgent pointer: 0
[SEQ/ACK analysis]
1643 94.792610 10.54.22.74 10.54.24.171 TCP 55 [TCP Keep-Alive] 52164→80 [ACK] Seq=317 Ack=1 Win=65142 Len=1Frame 1643: 55 bytes on wire (440 bits), 55 bytes captured (440 bits) on interface 0
Source Port: 52164
[Stream index: 69]
Flags: 0x010 (ACK)
Urgent pointer: 0
[SEQ/ACK analysis]
2098 104.828219 10.54.22.74 10.54.24.171 TCP 55 [TCP Keep-Alive] 52164→80 [ACK] Seq=317 Ack=1 Win=65142 Len=1Frame 2098: 55 bytes on wire (440 bits), 55 bytes captured (440 bits) on interface 0
Source Port: 52164
[Stream index: 69]
Flags: 0x010 (ACK)
Urgent pointer: 0
[SEQ/ACK analysis]
2179 114.861845 10.54.22.74 10.54.24.171 TCP 55 [TCP Keep-Alive] 52164→80 [ACK] Seq=317 Ack=1 Win=65142 Len=1Frame 2179: 55 bytes on wire (440 bits), 55 bytes captured (440 bits) on interface 0
Source Port: 52164
[Stream index: 69]
Flags: 0x010 (ACK)
Urgent pointer: 0
[SEQ/ACK analysis]
2241 124.896686 10.54.22.74 10.54.24.171 TCP 55 [TCP Keep-Alive] 52164→80 [ACK] Seq=317 Ack=1 Win=65142 Len=1Frame 2241: 55 bytes on wire (440 bits), 55 bytes captured (440 bits) on interface 0
Source Port: 52164
[Stream index: 69]
Flags: 0x010 (ACK)
Urgent pointer: 0
[SEQ/ACK analysis]
