    Duet WiFi fan confusion
    • Asdasd1234
      Asdasd1234 last edited by
      Hi all,
      I'm trying to get a fan working to go into the housing for the Wifi board. but I only need it running at half speed if that (its a pretty beefy fan for its job)
      It's a 4 wire 12v fan.
      I've connected just the Vin and ground to the FAN1 connector on the board.
      I can only make it turn on with this command "M106 P1 I1" The I1 part is needed or it doesn't work. And S0.1-1 or S50/S100/S255 have no affect on speed.
      How do I slow down this fan?
      All help appreciated!
      Many Thanks
        Connect the red and black wires to an always on fan connector, and the PWM wire to the FAN- pin of your chosen fan connector. Use parameter I1 innthe M106 command to invert the polarity.
        • Asdasd1234
          I'll try that and report back, cheers!
          • biscuitlad
            biscuitlad last edited by
            Isn't P1 defined to be a thermostatically controlled by default? You need to disable it first:
            M106 P1 H-1
            Then send your variable rate.
