    Heat Map shows below bed plane
    • chandersundefined
      chanders
      Why does my heat map show so far below the plane even though I have my Z offset for my Z probe setup in config.g?
      https://imgur.com/gallery/heUQf
        Have you just run the bed compensation routine?
        When was the last time you leveled the bed manually and calibrated your probe trigger height?
        Have you had a head crash since the last calibration?
        https://duet3d.dozuki.com/Wiki/Using_mesh_bed_compensation
