    Problem of displacement with G1
    • lecman93undefined
      lecman93
      My name is Damien, I've been printing for over 2 years now.
      I embarked on the design and manufacture of a Core XY using X and Y rail, with a printing surface of 30x30x60.
      I am currently finishing the machine and since then I have some problems that I did not have before.
      Already I have 2 independent Z motor with each endstop at the bottom of the printer and a BLTouch sensor at the top.
      Until there can all worked well but since I received my hotend and I installed it, I encounter 2 problems.
      The first when I make a G1 Z-100 F2400 for example the bed will always go to the value 0, whatever the value indicated, The X and Y axis behaves normally.
      By cons if I use the movement of the panel due or the web interface I do not encounter the problem
      Second problem, when I make a move in Z thanks to the paneldue or the web interface, the value Z changes well but not my U value of my second Z axis, but physically it moves correctly.
      Config.g
      M111 S0 ; Debugging off
      G21 ; Work in millimetres
      M667 S1 ; Select CoreXY mode
      M584 X0 Y1 Z2:5 U5 E3:4 ; three Z motors connected to driver outputs 2, 5 and 6
      ;M671 X-39:359 Y151.07:151.07 ; leadscrews at leftand right
      M208 X0 Y0 Z0 U0 S1 ; Set axis minima
      M208 X320 Y310 Z628 U628 S0 ; Set axis maxima
      M564 H0 ; Limit axes
      ;Physical Drive conextion
      M569 P0 S0 ; Drive 0 goes forwards X
      M569 P1 S0 ; Drive 1 goes forwards Y
      M569 P2 S1 ; Drive 2 goes forwards Z gauche
      M569 P3 S1 ; Drive 3 goes forwards E0
      M569 P4 S1 ; Drive 4 goes forwards E1
      M569 P5 S1 ; Drive 5 goes forwards Z droite
      M569 P6 S1 ; Drive 6 goes forwards vide
      M574 X1 Y1 S1 ; Set active low endstops
      M574 Z2 U2 S1 ; Set active high endstops
      ;Bltouch
      M307 H4 A-1 C-1 D-1
      M558 P9 H5 F200 T5000 A2 ; Set Z probe type to switch and the dive height + speeds
      G31 P25 X22.75 Y17.3 Z1.1188 U1.1188 ; Set Z probe trigger value, offset and trigger height
      M557 X5:295 Y5:295 S40 ; Define mesh grid
      ; Configure Drives
      M350 X16 Y16 Z16 U16 E16:16 I1 ; Configure microstepping with interpolation
      M92 X80 Y80 Z400 U400 E2750:2750 ; Set steps per mm
      M566 X900 Y900 Z12 U12 E40:40 ; Set maximum instantaneous speed changes (mm/min)
      M203 X18000 Y18000 Z2400 U2400 E1800:1800 ; Set maximum speeds (mm/min)
      M201 X1000 Y1000 Z250 U250 E120:120 ; Set accelerations (mm/s^2)
      M906 X1300 Y1300 Z1300 U1300 E1300:1300 I30 ; Set motor currents (mA) and motor idle factor in per cent
      M84 S30 ; Set idle timeout
      M143 H0 S150 ; Set temperature limit for heater 0 to 150C
      M305 P1 T100000 B4388 C7.060000e-8 R4700 ; Set thermistor + ADC parameters for heater 1
      M143 H1 S285 ; Set temperature limit for heater 1 to 300C
      M305 P2 T100000 B4388 C7.060000e-8 R4700 ; Set thermistor + ADC parameters for heater 2
      M143 H2 S285 ; Set temperature limit for heater 2 to 300C
      M563 P0 D0 H1 ; Define tool 0
      G10 P0 X9 Y0 Z0 U0 ; Set tool 0 axis offsets
      M563 P1 D1 H2 ; Define tool 1
      G10 P1 X-9 Y0 Z0 U0 ; Set tool 1 axis offsets
      G10 P1 R0 S0 ; Set initial tool 1 active and standby temperatures to 0C
      ;Save print low current
      M911 S10 R11 P"M913 X0 Y0 G91 M83 G1 Z3 U3 E-5 F1000"
      M550 PUltraCube ; Set machine name
      M552 S1 ; Enable network
      ;*** Access point is configured manually via M587 by the user
      M586 P0 S1 ; Enable HTTP
      M586 P1 S1 ; Enable FTP
      M586 P2 S1 ; Enable Telnet
      M106 P0 S0 ; Set fan 0 value, PWM signal inversion and frequency. Thermostatic control is turned off
      M106 P1 S1 I0 F500 H1:2 T45 ; Set fan 1 value, PWM signal inversion and frequency. Thermostatic control is turned on
      M106 P2 S0 ; Set fan 2 value, LED. Thermostatic control is turned off
      Bed.g
      M561 ; clear any existing bed transform
      G1 Z-628 F2400
      G4 P500
      G29 S2
      G29
      G1 S0 X0 Y0 F5000 ; move the head to the corner (optional)
      HomeZ.g
      G91 ; relative positioning
      M584 Z2 U5
      G1 Z1 U1 F6000 ; lift Z relative to current position
      G1 S1 Z631 U631 F2400 ; move Z up until the switch triggers
      G1 Z-10 U-10 F2400 ; go back a few mm
      G1 S1 Z631 U631 F360 ; move slowly to Z axis endstop once more (second pass)
      M584 Z2:5 U5
      G90
      HomeAll.g
      G1 Z5 U5 F6000 ; lift Z relative to current position
      G1 S1 X-325 Y-315 F3000 ; move quickly to X or Y endstop and stop there (first pass)
      G1 S1 X-325 ; home X axis
      G1 S1 Y-315 ; home Y axis
      G1 X5 Y5 F3000 ; go back a few mm
      G1 S1 X-325 F360 ; move slowly to X axis endstop once more (second pass)
      G1 S1 Y-315 F360 ; then move slowly to Y axis endstop
      G1 S1 Z630 U630 F1800 ; move Z up stopping at the endstop (first pass)
      G1 Z-5 U-5 F2400 ; go back a few mm
      G1 S1 Z630 U630 F360 ; move slowly to Z axis endstop once more (second pass)
      G90 ; absolute positioning
      Thank you for your help because it's been several days that I look without finding the problem
        1. Ordinary G1 movements (with no S parameter) are limited to the axis limits set in M208. You have set the lower Z axis limit to 0, therefore if you ask to go to -100 you will be limited to 0.
        Did you mean to go to Z=100 instead? Bear in mind that Z is the distance between the bed and the nozzle. So on a printer in which the bed moves in the Z direction, increasing Z makes the bed go down, and decreasing Z makes the bed go up.
        2. The U axis doesn't really exist except during homing, so I suggest you hide the U axis except during homing. To do this, add parameter P4 to your M584 Z2 U5 commands in homez.g, and add parameter P3 to the M584 Z2:5 U5 command in homez.g and to the M584 command in config.g.
        3. The Z homing section of your homeall.g file is incorrect. It should contain the same M584 commands as homez.g.
        HTH David
        • lecman93undefined
          lecman93
          thank you very much, I did not understand at all that the command G1 worked in a sense.
          It works well as it takes.
          For HomeAll.g I made the change thanks again.
          So for the U axis that does not change value, this is normal I do not have to worry?
            @lecman93:
            That's right; but if you use the P3 parameter when you use M584 to assign the second motor back to Z after homing, then the U axis won't be displayed anyway except during homing.
            • lecman93undefined
              lecman93
              thank you very much it's good everything works
