    Z-Probe Problems
    • dezender
      dezender last edited by
      Ill tryed the Delta Autoclibration but ill Stuck.
      The Point for Trigger High ill dont understand.
      Ill Mount my Probe this here it has a high from 15mm untriggered Switch to Base.
      When ill doit like it written here https://duet3d.dozuki.com/Wiki/Calibrating_a_delta_printer Measuring the trigger height the Print in my case it 0.024.
      Now ill Run Auto Calibration, but the Switch never Touchs the Bed also when il do after a G29.
      After Calibration Z0 is far away from the Bed
      Whats wrong?
        If the switch never touches the bed during probing, do you get a message "Warning: Z probe was not triggered during probing move" on the GCode Console page of DWC? If so then try increasing the H parameter in the M558 command temporarily (e.g. to 40mm) until you have established the correct M665 parameters.
        • dezender
          No i got no Message, he goes around without Touching the Bed an gives me new M665 and M666 Values.Also the Highmap after there hes touching 2 points of 61
            Sounds like your Z probe is mis-configured, miswired or not working. See https://duet3d.dozuki.com/Wiki/Test_and_calibrate_the_Z_probe.
            • dezender
              Ok ill leave the Duet Outside,Now i can See that due DUet Regonized that the Switch will be triggered, but the DWC dont Show anything once a green 1000 maybe the Endstop is bad for Measering or anything else?
