Error after upgrade to 1.21
  • I upgraded my 3 printers to 1.21 and all work perfectly except the DuetWiFi on my duplicator 6. Ever since the upgrade and I try to home X, Y, or all I get an error:
    "G28 X
    Error: G0/G1: insufficient axes homed:"
    Now I get this error when I try home X. I was able to determine the problem has to do with the Z-Axis as my macro for homex essentially lowers the bed by 5 homes x and then raises z again. I believe I left it the waG91 ; relative positioning
    [[language]]
    G1 Z5 F6000      ; lift Z relative to current position
    G1 S1 Y-205 F1800 ; move quickly to Y axis endstop and stop there (first pass)
    G1 Y5 F6000     ; go back a few mm
    G1 S1 Y-205 F360  ; move slowly to Y axis endstop once more (second pass)
    G1 Z-5 F6000     ; lower Z again
    G90              ; absolute positioningy the configurator created.  Anyways, when I comment out the Z-Axis commands it works fine.
  • You need to add S2 parameter to lines where Z axis are moved. That should fix the problem 🙂
    [[language]]
    G1 Z5 F6000 S2     ; lift Z relative to current position
    ```and
    [[language]]
    G1 Z-5 F6000 S2 ; lower Z again
  • Yup, that did it. Thanks!
Locked
