    Slicer Interfacing - Like OctoPrint's API
    Duet Web Control wishlist
    1389
    • ElmoC
      ElmoC last edited by
      One thing I miss with using the Duet is the OctoPrint's API option that allows me to send a model from the slicer to the controller. I would love to see this option added to Duet if possible. Not sure if this is implemented in the web control or in firmware though.
      • AlexLin
        AlexLin last edited by
        for slic3r look here
        post send to printer
        • AlexLin
          for cura there was a plug-in
          cura print
          • T3P3Tony
            So if you use Cura there is this:
            https://github.com/Kriechi/Cura-DuetRRFPlugin
            www.duet3d.com
            • T3P3Tony
              T3P3Tony administrators last edited by T3P3Tony
              Haha ,beat me to it
              www.duet3d.com
              • resam
                resam last edited by
                Hi - I'm the developer of the Cura plugin mentioned above. Let me know if you have any feature requests! Or just open a new issue on the GitHub page!
                • ElmoC
                  You are missing the point of the API. While sending a file from a slicer is what it will probably be used for the most, it can also be used for other application. There is an Android app called Printoid that uses this interface to monitor the printer.
                  • AlexLin
                    your question was "..that allows me to send a model from the slicer to the controller". And yes that there is.............
                    But yes, I do agree that even though the duet is open source, it doesn't seem to have a plug-in /API like Octopirint. And I do use octoprint/printoid on my other printer and would like to see duet going towards the direction of a kind of plug-in support.But I guess that lies in the future long after 2.0........But maybe the Duet guys could publish a kind of roadmap
                    • T3P3Tony
                      T3P3Tony administrators @ElmoC last edited by
                      @elmoc the webserver accepts http requests from any source, so any application can send them. The DWC github documents this:
                      https://github.com/chrishamm/DuetWebControl/blob/master/README.md
                      www.duet3d.com
                      • AlexLin
                        AlexLin last edited by AlexLin
                        seen it before but never got to do something with it. Used Telnet up til now.Might try tonight to implement something on my node-red, as I have with my Octoprint. Maybe switch of the TV when a print is finished;-)
                        • Danal
                          Danal last edited by
                          Here is another interface to the DUET web service api. This one is designed to monitor multiple printers, and provide a few simple controls.
                          https://github.com/DanalEstes/MultiDuetWebMonitor
