    Enclosure Heater and Duet
    • Jpmc86undefined
      Jpmc86
      Hi all! any ideas how I can wire this guys to control it via the Duet3d web interface?
      https://www.omega.com/pptst/HVL031_SERIES.html
      I was gifted it and I could put it to good use for a heated chamber.
      I'd appreciate any help I could receive.
      Thank you!
      • GeekStreetSolutionsundefined
        GeekStreetSolutions
        You could possibly use a DC-AC SSR with the control terminals connected between +5V and PS_ON.
        Quoting this page:
        "Please note the 5v pin next to the PS_ON is an input and as it is has a diode in series with it will not output 5v. If you need 5v to power a relay of some sort you need to use the expansion connector pin 1 or the 5v pin on the vfan jumper."
          You could use a DC-AC SSR with the control input connected between a spare heater output on the expansion connector and +3.3V. Configure it using M141.
