    Sensorless Homing oddness
    3.3k
    • klcjr89undefined
      klcjr89 @mhackney
      @mhackney True, but I do not see that as a shortcoming if you're designing a printer from scratch. I got a chinese clone speed demon and did a 10,000 cycle gcode test that was approximately 12 miles of movement, they wore out and there was surface rust and grit falling off the rails. The centerline of the three bearings weren't even in the same plane; poor quality!
      I did the same gcode cycle test on a genuine LM76 one and there was zero wear!
      This was the smallest version and the 3 roller block with one eccentric.
