Problems with the Endstop Offset-Configuration
Hi!
I'm trying to set up my new DuetWifi. As I come from Marlin, I am a little confused and hope, you can help me
I use 2 endstops at the "high-end" (CoreXY): X2, Y2.
Both endstops have a different offsets to the heated bed.But where do I configure this offset? In the config.g I set the axis limits. But where do I configure the "travel limits" so that the printhead is only allowed to move outside the boundary of the heating bed while homeing
Configure the axis position when the endstop triggers in the M208 commands in config.g. For high end switches, adjust the M208 S0 command. For low end switches, adjust the M201 S1 command.
