    Z Probe Offset and Mesh Leveling Confusion
    2.7k
    • Trixxterundefined
      Trixxter
      Hello all together,
      i have a hard time getting to good first layers. Right now im very confised about Z Offset in combination with mesh level.
      I Home Z, bring the nozzel down, Zero Z, Let IR `probe five times, thake the result as Zero Offset. Works perfect until i start mesh leveling.
      After that my offset is completly wrong and i have to start this prozess again.... and again....
      What am i doing wrong?
      Thank you all!
        @trixxter said in Z Probe Offset and Mesh Leveling Confusion:
        I Home Z
        How are you homing Z: with an endstop switch or with the IR probe?
        Do you mean you drop the nozzle to the bed and send G92 Z0, or something else?
        Let IR `probe five times, take the result as Zero Offset.
        Please explain what you mean by "take the result as Zero Offset".
        • Trixxterundefined
          Trixxter
          Hi dc42,
          im homing with IR Probe.
          Exactly, I use thermopaper to drop the nozzle and set G92 Z0.
          After that i repeat
          G1 Z5
          G30 S-1
          at least five times - the average value i use to offset z. in G31.
          This works fine ( on that local spot) until i use mesh leveling.
            OK, so what happens when you try to use mesh bed compensation by sending G29 S0?
            • Trixxterundefined
              Trixxter
              Then it runs the mesh probes - and shows and me my hightmap.
              When i Home Z again and check the nozzle hight, it would dig into the bed by about 0.5mm@ Z0 after that.
                Try this before running the G29
                ; Clear current mesh compensation map and disable compensation.
                M561			; Disable any current bed compensation
                G29 S2			; Clear mesh bed compensation parameters
                G28			; Home all
                G29      ; run mesh compensation probe routine
                  dc42 administrators @Trixxter
                  How does the height map look?
                  • Trixxterundefined
                    Trixxter
                    Ok i try to describe what i have just done with results. Thank you for helping me even with my bad english 😕
                    1. Heated up everything
                    2. Homed all axis
                    3. G32 to see if my bed is still where it belogs
                    G32
                    Manual corrections required: 0.00 turn up (0.00mm) 0.01 turn down (0.00mm) 0.03 turn down (0.01mm) 0.01 turn down (0.00mm)
                    1. Put the nozzel down, probed with thermopaper
                    2. Ran my IR Makro:
                    Stopped at height 2.350 mm 21:52:11
                    Stopped at height 2.350 mm21:52:08
                    Stopped at height 2.345 mm21:52:05
                    Stopped at height 2.348 mm21:52:02
                    M98 P"0:/macros/Z -IR kalibrieren"
                    Put 2.348 as Z Offset ( G31 P500 X 28 Y 10 Z 2.348) in config.g
                    1. Restarted Checked the Z Offset again, fine.
                    2. M561 ; Disable any current bed compensation
                      G28 ; Home all
                      G29
                    as discribed above by Phaedrux Result:
                    36 points probed, mean error -0.024, deviation 0.014
                    Height map saved to file heightmap.csv
                    1. Homed Z again an try to test the offset. - nozzle would have digged (this time slighly) into the bed.
                    2. IR Makro:
                      Stopped at height 2.388 mm
                      Stopped at height 2.385 mm
                      Stopped at height 2.382 mm
                    3. M561
                      G29 S2
                    4. IR Makro:
                      Stopped at height 2.340 mm
                    After disabling the MBL Offset Offset it what it supposed to be again...
                    Is this the way it works?
                    What is a good reproducable way to level the bed for a good first layer hight?
                      Phaedrux Moderator @Trixxter
                      @trixxter I think your map looks pretty good. It's far flatter than mine! 😁
                      Is there a specific problem that is happening?
                      Is the compensation being applied when you move the head around the bed? Do you see movement of the Z axis?
                      If you tell the printer to go to Z0 slowly does it end with the nozzle touching the bed? Or is it going too far? It looks like you are calibrating the trigger height correctly.
                      If you do a test print, does the first layer go as expected?
                      I use this set of macros to go through a bed leveling routine so that each time it's exactly the same. https://www.dropbox.com/sh/f0zp6hxrnt6yr1p/AAAuEKOsHR03w4ITug_ksFVCa?dl=0
                      First getting the probe trigger height and measuring it's offset. Then mechanically moving the nozzle to the 3 leveling screws and adjusting those with paper. And then running a mesh grid compensation.
                      • Trixxterundefined
                        Trixxter
                        With activated MBL the nose would dig into the bed.
                        As you can see in Pos. 8 there is about 0.05 added to the Z Value.
                        The first layer gets too thin and print fails.
                        After I deactivate MBL the Z values are lower again.
                        • Trixxterundefined
                          Trixxter
                          Still cant get it to work fne. I guess im completely missunderstanding this concept.
                          After MBL, where (X/Y) does the duet expect to be Z 0?
                            Z0 should be the nozzle just touching the bed.
                            Did you get a chance to look at the macros I linked above? There must be something missing or just a little off somewhere.
                            Are you probing with a heater bed or cold? Are you measuring nozzle height hot or cold?
