    Random issues first boot
    1810
    • Mysta
      Mysta last edited by Mysta
      So I finally booted up and I think I had 3 issues
      • ~~ Stallguard didn't seem to work when I tried homing,(all 3 motors went up but bounced off top - quickly stopped that).
        • I tried the stallguard example script but all it did was move the 3 carriages down slightly and then made motors hum?~~ Fix: Enable StallGuard M915 X Y Z S3 F1 R0; Change S up and down until it consistently triggers endstops when homing
      • Z probe didn't trigger in 5v mode or with 24v - green light flashed twice on bootup.
        • Wiring seems correct.
      • Couldn't figure out how to test extruder in web interface? Fix: Cold extrusion(M302 P1) and active Tool
        Interface
      I only spent a small amount of time looking at this stuff since I didn't have a lot of time but figured I would post with my config file in case something glaringly obvious stood out. On flip side temperature seemed to work and hotend heated up.
      G90                                                ; Send absolute coordinates...
      ;*** The homed height is deliberately set too high in the following - you will adjust it during calibration.
      M665 R259.1 L500 B225 H900                         ; Set delta radius, diagonal rod length, printable radius and homed height
      M666 X0 Y0 Z0                                      ; Put your endstop adjustments here, or let auto calibration find them
      ;networkstuff
      M586 P0 S1                                         ; Enable HTTP
      M586 P1 S0                                         ; Disable FTP
      M586 P2 S0                                         ; Disable Telnet
      M569 P0 S0                                         ; Drive 0 goes backwards
      M569 P1 S0                                         ; Drive 1 goes backwards
      M569 P2 S0                                         ; Drive 2 goes backwards
      M569 P3 S1                                         ; Drive 3 goes forwards
      M350 X16 Y16 Z16 E16 I1                            ; Configure microstepping with interpolation
      M92 X100 Y100 Z100 E415                            ; Set steps per mm
      M566 X1200 Y1200 Z1200 E1200                       ; Set maximum instantaneous speed changes (mm/min)
      M203 X30000 Y30000 Z30000 E1200                    ; Set maximum speeds (mm/min)
      M201 X3000 Y3000 Z3000 E500                        ; Set accelerations (mm/s^2)
      M906 X1050 Y1050 Z1050 E700 I30                    ; Set motor currents (mA) and motor idle factor in per cent
      M208 Z0 S1                                         ; Set minimum Z
      M574 X2 Y2 Z2 S3                                   ; Set endstops controlled by motor load detection
      M558 P5 R0.4 H5 F120 T6000                         ; Set Z probe type to effector and the dive height + speeds
      G31 P100 X0 Y0 Z-0.1                               ; Set Z probe trigger value, offset and trigger height
      M557 R225 S20                                      ; Define mesh grid
      M140 H-1                                           ; Disable heated bed
      M305 P1 X200                                       ; Configure thermocouple for heater 1
      M143 H1 S300                                       ; Set temperature limit for heater 1 to 300C
      M106 P0 S0.3 I0 F500 H-1                           ; Set fan 0 value, PWM signal inversion and frequency. Thermostatic control is turned off
      M106 P1 S1 I0 F500 H T45                           ; Set fan 1 value, PWM signal inversion and frequency. Thermostatic control is turned on
      M106 P2 S1 I0 F500 H T45                           ; Set fan 2 value, PWM signal inversion and frequency. Thermostatic control is turned on
      M563 P0 D0 H1                                      ; Define tool 0
      G10 P0 X0 Y0 Z0                                    ; Set tool 0 axis offsets
      G10 P0 R0 S0                                       ; Set initial tool 0 active and standby temperatures to 0C
      ; Automatic power saving
      M911 S10 R11 P"M913 X0 Y0 G91 M83 G1 Z3 E-5 F1000" ; Set voltage thresholds and actions to run on power loss
        Stall detection has to be configured to your motors. See https://duet3d.dozuki.com/Wiki/Stall_detection_and_sensorless_homing.
        Mysta 1 Reply Last reply Reply Quote 0
        • Mysta
          Mysta @dc42 last edited by
          @dc42 ahh, I was thinking the one line enabled it, through rrf auto config, but that makes sense. Any ideas on zprobe?
            What type of Z probe do you have? See the wili pages on connecting/ configuring a Z probe and on testing and calibrating a Z probe.
            To test an extruder you need to first select a tool that uses it, then either heat that tool to operating temperature or enable cold extrusion.
            • Mysta
              Mysta @dc42 last edited by Mysta
              @dc42 I'm using the Smart Effector - the green light flashes twice on bootup but tapping the nozzle does not trigger the light.
              • T3P3Tony
                @Mysta I assume you are following these instructions:
                https://duet3d.dozuki.com/Wiki/Smart_effector_and_carriage_adapters_for_delta_printer#Section_Commissioning
                Try with a higher sensitivity to see if that does trigger the light (you will get 3 flashes on startup with a non standard sensitivity).
                www.duet3d.com
                • Mysta
                  Mysta @T3P3Tony last edited by Mysta
                  @t3p3tony What's P (threshold) exactly? I found sensitivity guide here for anyone who finds this thread - was jumping between different articles and never making it this far down https://duet3d.dozuki.com/Wiki/Smart_effector_and_carriage_adapters_for_delta_printer#Section_Programming_the_sensitivity
                  Also on my stallguard my S is 3 - is that reasonable?
                  • Mysta
                    Additionally - this may be a dumb question but I saw in the sensor-less homing guide to make a separate macro and at the end it does/says:
                    M574 X2 Y2 Z2 S1            ; set endstops back to normal so that homedelta.g works
                    Does this mean you shouldn't change homedelta.g? Or is that okay once you're done testing? I imagine you want G28 to eventually be what you tested in the 'test' macro file, right? And if one tower hits first and triggers all the S is too low right?
                    • T3P3Tony
                      Lets split the two issues (sensorless homing and smart effector)
                      First on the smart effector the P value is the trigger threshold between 0 and 1000 for an analog input. The recommendation for the smart effector is to set it to P100 because the smart effector has a microcontroller on it that handles the analog action of the effector strain for us. How much strain is required to trigger is set using :
                      M672 S105:aaa:bbb
                      Where the default sensitivity out of 255 is 50. lower numbers means more sensitive
                      So if the smart effector does not trigger (green LED flash) when you give it a sharp tap then try a lower sensitivity.
                      www.duet3d.com
                      • Mysta
                        @t3p3tony Yep using that second link I provided(the lower section on that page) I was able to get the probe working.
                        • T3P3Tony
                          T3P3Tony administrators @Mysta last edited by
                          @mysta ok great! I have not used sensorless homing myself however you are correct - if you have no endstops on the towers and are using sensorless homing you will not want to set it back to S1.
                          www.duet3d.com
                          • Mysta
                            @t3p3tony Any idea on the independent motors? If the head is not centered and it homes it stops at the first motor to be triggered and the other two do as well regardless of where they are. Is that a matter of sensitivity?
                            • T3P3Tony
                              @Mysta i am afraid i don't. It might be sensitivity or something else.
                              I migth be able to try this a delta tomorrow if i can finish a couple of urgent tasks. Otherwise @dc42 probably knows the answer!
                              www.duet3d.com
                              • Mysta
                                @t3p3tony
                                For what it's worth these are my motors for the towers:
                                https://www.automationtechnologiesinc.com/products-page/3d-printer/nema17-stepper-motor-3/
                                Noticed they have 4.2V which is slightly higher than the 4V max in the guide?
                                So after reading through the sensorless homing guide - does the S2(default) threshold mean 200 full steps a second?(and 3 = 300?) Trying to kinda do calculations based on this.
                                • Mysta
                                  @DjDemonD What motors do you use on your build?
                                  • DjDemonD
                                    DjDemonD last edited by DjDemonD
                                    On the cylinder delta which uses sensorless homing I'm using the motors I had left over from my old I3 rework I started off 3D printing with about 3 years ago. They are 17HS8401 motors please see here http://forums.reprap.org/read.php?178,802910,803287#msg-803287 that machine uses leadscrews so its running 400 (micro)steps/mm.
                                    www.precisionpiezo.co.uk
                                    • Mysta
                                      Mysta @DjDemonD last edited by
                                      @djdemond said in Random issues first boot:
                                      Ahh then it's a little different since I use belts.
                                      • DjDemonD
                                        Yes, If anything I'd say the lack of any real elasticity in the leadscrew driven system, with antibacklash nuts, and the carriages coming to rest against fairly hard stops, makes the stall detect work fairly well. My Z accel is just 50 and jerk 10 which was mainly to do with getting the piezo probe working within what is mechanically a noisy machine, but this does seem to help.
                                        I haven't tried it on a belt driven delta yet, as I have endstops already on my other machines, and cannot see a good case to remove them. I will try it if I build a new machine, I just won't bother with endstops.
                                          On the wiki page on configuring sensorless homing, I give an example of a macro file that I used to test sensorless homing on my Kossel. I suggest you start with that file. Once you have it working, you can simplify it and move the remaining commands into homedelta.g.
                                          • Mysta
                                            @dc42 said in Random issues first boot:
                                            Yeah That's what I was using, couldn't get consistent results. It either triggered too early(only 1 axis) or wouldn't move. I think my motors may just be not good for this case, as linked above.
                                            Here's my first print though, 100mm/s pla.
                                              If it triggers too early or immediately (doesn't move), increase the stall detection threshold. That's the S parameter in the M915 command.
