    GCodes: Attempt to read a GCode unsigned array that is too long
    • resamundefined
      resam
      I just noticed today that I get the following warning/error message on PanelDue console tab after I power-up/reset my DuetWifi:
      GCodes: Attempt to read a GCode unsigned array that is too long: M350 X16 Y16 Z16 E16:16 I1
      The weird thing is, I'm tracking my config.g with git since day-0 and this config line is unchanged since then. However, I've never seen this warning message before...
      I'm running 1.21 for a while now - is this a new message, or what is happening here?
      I guess the config line in question is obviously wrong I suppose, since I'm running a CoreXY with dual Z (one on the Z driver, and one on the E1 driver)...
      The only recent change was:
      M584 X0 Y1 Z2:4 ; Drive mapping: 0=A, 1=B, 2 and 4 are individual Z steppers
      got changed to:
      M584 X0 Y1 Z2:4 E3 ; Drive mapping: 0=A, 1=B, 2 and 4 are individual Z steppers, 3=Extruder
      I'm currently running a print, but once it's done, I will try to fix the M350. Do I need to specify Z microstepping as Z16:16 or does this get applied to both driver automatically?
      Dougal1957undefined 1 Reply Last reply Reply Quote -1
      • Dougal1957undefined
        Dougal1957 @resam
        @resam looks to me that you have a space between the colon and 16 on the E parameter section reckon that is your issue try removing it and no you don't need E16:16 if you dont have a second extruder
          It's because you have declared only one extruder in M584 but you have provided two M350 E values.
          • resamundefined
            resam
            Print completed - so I removed the :16 from M350. Now the error is gone.
            Thx!
