    Homing Z Speed
    1.2k
    • Adamfilipundefined
      Adamfilip
      I would like to increase the speed that Z homes when sent a G30 command
      what value will adjust Z speed with G30? where is this stored?
      in my homing script it just has G30
      • lignumaquaundefined
        lignumaqua
        G30 is for a Z Probe . You set the speed using the F parameter in the M558 command used to set up the probe.
        If you wanted to use a Z home which is done using G28 Z, then you would set the speed in the homez.g file.
