    No Chamber heater in web interface
    • dexteria01
      dexteria01 last edited by dexteria01
      Hi All,
      I am trying to set up a chamber heater on my FDM with control via an SSR to 230v heaters. I would like to use the bed heater/themistor connections. I haven't hooked the AC up yet as I cant seem to be able to monitor the temperature via the web interface ( I have a Panel Due but the chamber heater is not supported on that at the moment). If I configure the chamber heater to use E2 heater and thermistor then this is displayed as chamber heater 3 as expected (I have 2 hot ends) in the web interface. Is there a way to use the bed heater/thermistor and also view the chamber heater temperature in the web interface?
      Many thanks
      Mark
      PS I am using the online firmware configurator tool.
        Before configuring the chamber heater to be Heater 0, did you disable the bed heater using M140 H-1 ?
        • dexteria01
          ah, no I didn't.
          Will try that.
          Many thanks
          Mark
