Syntax Error: unexpected token in a json at position 91
having a issue setting up my duet wifi, everytime i try to home my x,y or z my steppers act normally for about 30 seconds or so, then i get this error and if they hit my end stops they also activate sparringly and its never the same axis, im sort of at a loss here
Have you set high microstepping using the M350 command in config.g? If so, set it back to x16 with interpolation for now. Homing the printer with high microstepping can cause the network to disconnect, because the processor is too busy generating step pulses and checking endstops to handle the network traffic quickly enough.
