DuetWifi CNC Control
I have a duetwifi and expansion header that I plan on using to drive a Openbuilds Mini Mill CNC machine
as a test platform. I will be loading the latest firmware currently available. 1.21RCGcode output from Fusion 360
I assume i just load gcode via the DWC on the DuetWifi.
Is there a way to communicate with the Duetwifi using Mach3/Mach4 or some other interface for manual control?
Definitely not Mach
Try CNCjs in Marlin mode. It mostly works. CNCjs is available as a stand-alone executable, or a split server/client pair. The server part, or the "all-in-one-desktop" part, interfaces with the USB on the Duet. No network support available at this time.
https://cnc.js.org/docs/desktop-app/
P.S. Rumor has it that a dedicated "Duet/RepRap" tab, including network, for CNCjs is on the way.
