    5V Inductive Z-Probe Signal to Z-Probe_IN Pin?
    • t0bias
      t0bias last edited by
      Hello everybody,
      I have a Prusa PINDA-Probe-like 5V Inductive Sensor on my Printer. I don't want do use it as a Z-Endstop (I already have a Microswitch in place for that), but for Bed-Leveling/-Level-Correction. Is it safe to wire the Z-Probe Signal Pin to the Z-Probe_IN Pin on the Duet Wifi (I've fed the probe with +5V from the Expansion-Header (P1)) or do I need to have a 5V-3V3-Level-Converter in between?
      If so, can someone maybe recommend a certain type?
      Thanks!
        In theory you should use a diode between the probe output and the Z probe input. In practice, applying 5V to the Z probe input is most unlikely to damage it.
        • t0bias
          Thanks for your reply. I ended up wiring it like this in case someone else comes across this issue:
                            Prusa PINDA Probe
                 BLACK            BLUE             BROWN
               (SIGNAL)           (GND)            (+5V)
          4.7kΩ  | R |              |                |
                   |     / Z \      |                |
                   |    /  D  \     |                |
                   |   /  3.3V \    |                |
                   |                V                V
                   V            +------------------------+
                                  Duet3D Expansion Header
           Duet3D Z_Probe_IN       Pins 2 & 1 (GND, +5V)
          (in different setups another resistor might be more suitable!)
          • speeli
            speeli last edited by
            i have the same probe,5V pinda probe.
            i testet it on a raspberry pi with the 3,3V output and it worked.
            is it save to use the z probe input for it?
