    Max File Size?
    • Mysta
      Mysta last edited by
      Tried to upload a 300Mb file from Simplify3d and it killed the Duet, is there a better way to upload it?
        Copy it straight to the SD card on a PC?
        • klcjr89
          klcjr89 last edited by klcjr89
          Copying to an SD card manually defeats the purpose of having onboard WiFi/Ethernet on the controller.
            I thnk the issue you are having is probably this one https://duet3d.dozuki.com/Wiki/Network_disconnections_after_uploading_large_files. If you are already using 64kb cluster size, or if reformatting to 64kb doesn't help, try the 2.0beta2 firmware release.
            Mysta 1 Reply Last reply Reply Quote 0
            • Mysta
              Mysta @dc42 last edited by
              @dc42 said in Max File Size?:
              After I rebooted I deleted the partial upload and tried again and it worked, will keep those in mind in the future though.
