    Start temperature at M116/M109
    • zerspaner_gerdundefined
      zerspaner_gerd
      Is there an adjustment possibility at which temperature deviation the pressure is continued?
      Currently I have only a deviation of ± 1C, I would like to increase this.
      Especially with the tool change is the time consuming to wait for accurate (±1C) temperature.
      greetings
      Board: Duet WiFi 1.03 | Firmware Version: 3.1.1 | WiFi Server Version: 1.23 | Web Interface Version: 3.1.1
        I guess we could add a parameter to M116 to specify the acceptable temperature difference from target. I'll add this to the firmware wishlist. I probably won't change M109 because that might create an incompatibility with other firmwares.
          zerspaner_gerd
          Thank you for your answer,
          For me it would be enough for M116.
            zerspaner_gerd
            I would like to come back to this.
            Where is this wishlist would it bring forward!
            I haven't found anything up to date!
              It's in my internal firmware work list.
