Auto-Cal?
  • Hi,
    Perhaps this is a mute question, however, does the Smart Effector (& DUET3D-E combo) require Z-probe calibration, even though the Z-Probe height auto-calibration function seems to be working?
    In other words, should the Z-Probe height calibration procedure be done first...to set some flash stored parameter(s), prior to bed auto-calibration?
    What's next? Print tweaking?
    Thanks in advance
    3mm
    Yes, the trigger height should be calibrated. It's normally around -0.1mm but the exact value will depend on whether you have a hard or soft bed material.
