    Custom Drive Mapping stopped working
    885
    • PropellerHat
      PropellerHat last edited by
      Hi
      I added yesterday a second extruder in my machine and suddenly things got really weird. Looks like the M584 line does not work anymore. Here is my config.g:
      M111 S0 ; Debugging off
      G21 ; Work in millimetres
      M208 X900 Y800 Z800 S0 ; Set axis maxima
      M574 X1 Y1 Z1 S1 ; Define active high microswitches
      M558 P0 X0 Y0 Z0 H5 F120 T6000 ; Set Z probe type to switch, the axes for which it is used and the probe + travel speeds
      ;G31 P600 X0 Y0 Z2.5 ; Set Z probe trigger value, offset and trigger height
      ;M557 X15:885 Y15:785 S20 ; Define mesh grid
      ; Drives (Tn for longer pulse)
      M569 P0 S0 ; Drive 0 goes forwards X
      M569 P1 S0 ; Drive 1 goes forwards Y
      M569 P4 S1 ; Drive 4 goes forwards
      M569 P5 S0 ; Drive 5 goes forwards Y
      M569 P6 S1 ; Drive 6 goes forwards
      M569 P7 S1 ; Drive 7 goes forwards
      M569 P8 S1 ; Drive 8 goes forwards
      M584 X0 Y1:5 Z6:7:8:9 E2:3:4 ; Apply custom drive mapping
      M350 X16 Y32 Z4 E16:16:16:16 I0 ; Configure microstepping without interpolation
      ;M92 X80.1 Y40.1 Z180.4 E570:570:570:570 ; Set steps per mm
      M92 X160 Y160 Z180 E570:570:570:570 STEPS PER MM
      M566 X1200 Y1000 Z5 E5000:5000:5000:5000:5000:5000 ; Set maximum instantaneous speed changes (mm/min) “JERK”
      M203 X18000 Y18000 Z250 E1200:1200:1200:1200:1200:1200 ; Set maximum speeds (mm/min) SPEED
      M201 X700 Y700 Z100 E250:250:250:250:250:250 ; Set accelerations (mm/s^2) “ACCELERATION”
      M906 X1900 Y1900 Z1900 E500 I30 ; Set motor currents (mA) and motor idle factor in per cent
      M84 S30 ; Set idle timeout
      M143 S280 ; Set maximum heater temperature
      M305 P1 T100000 B4138 C0 R4700 H-40 L-100 ; Set thermistor + ADC parameters for heater 1
      M307 H1 A528.3 C226.8 D5.3 B0 ; Autotune
      M143 H1 S300
      M305 P2 T100000 B4138 C0 R4700 H-40 L-100 ; Set thermistor + ADC parameters for heater 2
      M307 H2 A477.7 C209 D4 B0 ; Autotune
      M143 H2 S300
      M305 P3 T100000 B4138 C0 R4700 H-40 L-100 ; Set thermistor + ADC parameters for heater 3
      M307 H3 A491.8 C198.5 D5,1 B0 ; Autotune
      M143 H3 S300
      M305 P4 T100000 B4138 C0 R4700 H-40 L-100 ; Set thermistor + ADC parameters for heater 4
      M307 H4 A623.1 C198.6 D5 B0 ; Autotune
      M143 H4 S300
      M563 P0 D0 H1 ; Define tool 0
      M567 P0 E1
      ;G10 P0 X0 Y0 Z0 ; Set tool 0 axis offsets
      ;G10 P0 R0 S0 ; Set initial tool 0 active and standby temperatures to 0C
      M568 P0 S1 ; TURN MIXING RATIOS ON
      M563 P1 D0:1 H1:2 ; Define tool 1
      M567 P1 E1:1
      ;G10 P1 X0 Y0 Z0 ; Set tool 1 axis offsets
      ;G10 P1 R0 S0 ; Set initial tool 1 active and standby temperatures to 0C
      M568 P1 S1 ; TURN MIXING RATIOS ON
      M563 P2 D0:1:2 H1:2:3 ; Define tool 2
      M567 P2 E1:1:1
      ;G10 P2 X0 Y0 Z0 ; Set tool 2 axis offsets
      ;G10 P2 R0 S0 ; Set initial tool 2 active and standby temperatures to 0C
      M568 P2 S1 ; TURN MIXING RATIOS ON
      M563 P3 D0:1:2:3 H1:2:3:4 ; Define tool 3;
      M567 P3 E1:1:1:1 ; MIXING RATIO
      ;G10 P3 X0 Y0 Z0 ; Set tool 3 axis offsets
      ;G10 P3 R0 S0 ; Set initial tool 3 active and standby temperatures to 0C
      M568 P3 S1 ; TURN MIXING RATIOS ON
      M563 P4 D1 H2 ; Define tool 4
      M567 P4 E1
      ;G10 P4 X0 Y0 Z0 ; Set tool 0 axis offsets
      ;G10 P4 R0 S0 ; Set initial tool 0 active and standby temperatures to 0C
      M568 P4 S1 ; TURN MIXING RATIOS ON
      M563 P5 D0:2:3 H1:3:4 ; Define tool 5;
      M567 P5 E1:1:1 ; MIXING RATIO
      ;G10 P5 X0 Y0 Z0 ; Set tool 3 axis offsets
      ;G10 P5 R0 S0 ; Set initial tool 5 active and standby temperatures to 0C
      M568 P5 S1 ; TURN MIXING RATIOS ON
      M563 P6 D1:2:3 H2:3:4 ; Define tool 6;
      M567 P6 E1:1:1 ; MIXING RATIO
      ;G10 P6 X0 Y0 Z0 ; Set tool 3 axis offsets
      ;G10 P6 R0 S0 ; Set initial tool 3 active and standby temperatures to 0C
      M568 P6 S1 ; TURN MIXING RATIOS ON
      M563 P7 D1:3 H2:4 ; Define tool 7;
      M567 P7 E1:1 ; MIXING RATIO
      ;G10 P7 X0 Y0 Z0 ; Set tool 3 axis offsets
      ;G10 P7 R0 S0 ; Set initial tool 3 active and standby temperatures to 0C
      M568 P7 S1 ; TURN MIXING RATIOS ON
      M563 P8 D2:3 H2:3 ; Define tool 8;
      M567 P8 E1:1 ; MIXING RATIO
      ;G10 P8 X0 Y0 Z0 ; Set tool 3 axis offsets
      ;G10 P8 R0 S0 ; Set initial tool 3 active and standby temperatures to 0C
      ;M568 P8 S1 ; TURN MIXING RATIOS ON
      M550 PLSBP Mk4 ; Set machine name
      M540 PBE:EF:DE:AD:FE:ED ; Set MAC address
      M552 P0.0.0.0 S1 ; Enable network and acquire dynamic address via DHCP
      M586 P0 S1 ; Enable HTTP
      M586 P1 S0 ; Disable FTP
      M586 P2 S0 ; Disable Telnet
      M106 P0 S1 I0 F500 H-1 ; Set fan 0 value, PWM signal inversion and frequency. Thermostatic control is turned off
      M106 P1 S1 I0 F500 H-1 ; Set fan 1 value, PWM signal inversion and frequency. Thermostatic control is turned off
      M106 P2 S1 I0 F500 H-1 ; Set fan 2 value, PWM signal inversion and frequency. Thermostatic control is turned off
      I have tried for hours to make it work but now I don't know what to try anymore. Only one side of my dual motor Y is moving (the one connected on drive 1) and trying to move Z has moved the extruder motor connected on driver 2. X works since it is in drive 0.
      If somebody sees the problem it would really make my day!
      thanks!
      PropellerHat 1 Reply Last reply Reply Quote 0
      • PropellerHat
        PropellerHat @PropellerHat last edited by
        @propellerhat Oh yes, I tried also putting the custom mapping in the macros and commanding it separately after the startup. No effect.
        • PropellerHat
          @propellerhat Also tried without the tool configurating and with only the tools that were working configurated in the config.g before the changes. No help.
          • PropellerHat
            I also moved the M208 next to movement lines but no help.
            • Catalin_RO
              Catalin_RO last edited by
              Just wondering.... M584 defines 3 extruders, for drives 2, 3 and 4. In many places the E parameter is followed by 4 values, like the M350 and M92 codes. Have you tried insuring that you don't have more than 3 values for any E parameter present in the file?
              • PropellerHat
                PropellerHat @Catalin_RO last edited by
                Removed now all the extra E parameters from M566,M203 and M201. Also the tools are cleaned from everything else than T8.
                Still same behaviour 😞
                • PropellerHat
                  Now updated the firmware to 1.21. It has been a while since updating it. After the successfull in-app update from the SD card nothing moves.
                  • PropellerHat
                    Now when trying to move the axes I get this in the console: "G0/G1: insufficient axes homed"
                    • Catalin_RO
                      Firmware 1.21 requires all axis to be homed before allowing movements in order to properly enforce actual machine area. There are workarounds, just search the forum.
                      • PropellerHat
                        M564 H0 got the things in movement, pity that exactly the same problem remains as before updating.
                        Drive custom mapping doing nothing.
                          If you run M584 from the command line, what does it report?
                          • PropellerHat
                            Oh heck... Just found the flat between Duet and Duex being a tad loose. Stuff making a lot more sense now after pushing that corner in.
