    CORE XY D-BOT sensorless homing problem
    • KnutK
      KnutK last edited by
      I'm setting up a sensorless homing on my D-BOT, but it seems like I am doing something wrong in my config files.
      Here are my present config.g and homing files:
      ; generated by RepRapFirmware Configuration Tool on Mon Mar 26 2018 16:38:56 GMT+0200 (W. Europe Daylight Time)
      M667 S1 ; Select CoreXY mode
      M550 PMy printer ; Set machine name
      M552 S1 ; Enable network
      M569 P4 S1 ; Drive 4 goes forwards
      M92 X99 Y99 Z400 E416.35 ; Set steps per mm
      M203 X6000 Y6000 Z180 E1200 ; Set maximum speeds (mm/min)
      M201 X500 Y20 Z250 E250 ; Set accelerations (mm/s^2)
      M906 X800 Y800 Z800 E800 I30 ; Set motor currents (mA) and motor idle factor in per cent
      M84 S30 ; Set idle timeout
      M208 X295 Y295 Z300 S0 ; Set axis maxima
      ;Individual Z motors
      M584 X0 Y1 Z2:5:6
      M671 X10:140:290 Y95:10:95 S1 ; leadscrews at left, middle and right
      ;M574 X1 Y2 S0 ; Set active low endstops
      M574 X1 Y2 S3 ; Set active sensorless homing endstops
      M558 P5 H5 F120 T6000 ; Set Z probe type to unmodulated and the dive height + speeds
      G31 P500 X-10 Y75 Z1.32 ; Set Z probe trigger value, offset and trigger height
      M557 X10:290 Y55:290 S35 ; Define mesh grid
      M307 H7 A-1 C-1 D-1 ; Disable 7th Heater
      M563 P0 D0 H1 ; Define tool 0
      ; homeall.g
      ; called to home all axes
      M400 ;make sure everything has stopped before we make changes
      M913 X50 Y50 ;Drop current to 50%
      G91 ; relative positioning
      G1 Z5 F1000 S2 ; lift Z relative to current position
      G1 S1 X-290 Y290 F4000 ; move quickly to X or Y endstop and stop there (first pass)
      G1 S1 X-290 ; home X axis
      G1 S1 Y290 ; home Y axis
      G1 X4 Y4 F6000 ; go back a few mm
      G1 S1 X-290 F360 ; move slowly to X axis endstop once more (second pass)
      G1 S1 Y290 ; then move slowly to Y axis endstop
      G90 ; absolute positioning
      G1 X150 Y150 F600 ; go to first bed probe point and home Z
      M400 ;make sure everything has stopped before we resett the motor currents
      M913 X100 Y100 ; motor current back to 100
      ;G1 Z5 F100 S2 ; uncomment this line to lift the nozzle after homing
      ; homey.g
      ; called to home the y axis
      M400 ; make sure everything has stopped before we make changes
      M913 Y50 ; drop motor currents to 50%
      M915 X Y S3 R0 ; set sensitivity to +3 unfiltered
      G91 ; use relative positioning
      G1 Z5 F6000 S2 ; Lift Z
      G1 S1 Y295 F1800 ; move Y all the way left and stop at end
      G1 Y-5 F1800 ; move to edge of glass
      G1 Z-5 F6000 S2 ; lower Z again
      ; homex.g
      ; called to home the X axis
      M913 X50 ; drop motor currents to 50%
      G1 S1 X-295 F1800 ; move X all the way left and stop at end
        What isn't working? Have you tuned the stall detection threshold?
