    Can't Update or connect to Wifi with my DuetWifi
    • S1lencer
      S1lencer last edited by
      Hi there,
      im having my difficulties with the Wifi Module lateley.
      All worked fine with the the Firmware 2.0 beta 1-3.
      All on DuetWifiServer 1.21 und DuetWebControl 1.21.
      But suddenly my Duet won't connect to any wifi anymore. So i tried to send M552 S1 over my PanelDue, but all i was reciving was "Error: Failed to initialise WiFi module, code -10".
      So first idea was ok, back up to DuetCombinedFirmware 1.21.
      But this hadn't changed anything, so i tried to update the DuetWifiServer again to 1.21 maybe somthing was corrupted over time, who knows.
      But then the i was shocked, because my paneldue tried to connect to the Wifi Module but it coud not establis a COM connection.
      Oh by the way my Hardwareversion on the DuetWifi is 1.02
      What can i do now?
      What could be causing this problem?
      greetings
      Kai
        What is the error message you are getting when you try to install DuetWiFiserver ?
        • S1lencer
          S1lencer last edited by S1lencer
          "Error:Installation failed due to comm write error"
          But before that i tries to connect at all possible baud rates.
            If your Duet is under warranty, please make a warranty claim. The WiFi module needs to be replaced. See https://duet3d.com/warranty if you purchased it direct from Duet3D.
