    Firmware 2.0RC1 and 1.21.1RC1 released
    Firmware installation
    10
    39
    4587
      I have put new release candidate firmware at https://github.com/dc42/RepRapFirmware/releases. For Duet 2 WiFi/Ethernet and Duet 2 Maestro users there is version 2.0RC1. For users of older Duets and other electronics there is 1.21.1RC1. Also included is Duet Web Control 1.21.1RC1 (thanks chrishamm).
      Don't forget to read the release notes! There shouldn't be many surprises this time.
      • BMMal
        BMMal last edited by BMMal
        I've run 2.0 for a while now without serious issues. Some things seem to work better than 1.21 did. The number of times I have to tell DWC to connect before a connection is established seems to have increased though.
        I did have a crash that restarted the controller. It happened right as I received the diagnostic info after pushing the button in DWC. I wanted to see the new Hiccup counter. I was not able to repeat this.
        This is the diagnostics after the machine recovered.
        https://pastebin.com/t4HKSqr0
        Duet Ethernet - Most likely the most recent Edge firmware
        Duet X5
        7" Panel Due V2
        Cartesian, 4 Nozzles with Flex3Drives, Heated Chamber, Simple Switch Filament Sensing
          dc42 administrators @BMMal last edited by
          @bmmal said in Firmware 2.0RC1 and 1.21.1RC1 released:
          Thanks for your report, it pinpointed a bug in the code that I introduced in 2.0beta3. I will fix it in the next RC.
          • ShadowX
            ShadowX last edited by
            It looks like the new Duet Web Control only shows "Tool Fan" instead of the Fan0, Fan1, Fan2. Was this by design or a bug?
              dc42 administrators @ShadowX last edited by
              @shadowx said in Firmware 2.0RC1 and 1.21.1RC1 released:
              The new DWC should show all fans that are not configured for thermostatic control.
              Christoph13524 1 Reply Last reply Reply Quote 0
                Has anybody else tried the 2.0/1.21.1 RC1 firmware? I am looking to release 2.0/1.21.1 imminently.
                MSquared 1 Reply Last reply Reply Quote 0
                • BMMal
                  I successfully completed a 17 hour build using two tools on 2.0.
                  I do have one issue that has persisted across several different firmware versions now. See: https://forum.duet3d.com/topic/3735/slowdown-issue/14
                  I had this happen in the middle of a print on 1.21 and it still happens after prints finish and sometimes as they are starting on 2.0. I thought ferrites fixed it but I will be getting another SSR to replace the mechanical relay which should give a better idea as to whether it is hardware or FW related.
                  The relay is not actuated during prints, only at the beginning and end. The mechanical relay runs an AC solenoid valve for compressed air supply to generate vacuum for the print bed. The machine also has a server grade double converting UPS so there should not be any droops in the AC power. DC power is a 24V 25 amp power supply that runs the motors and hot ends and should have plenty of headroom. The chamber is heated via AC power on an SSR.
                  Duet X5
                  7" Panel Due V2
                  • Christoph13524
                    Christoph13524 @dc42 last edited by
                    @dc42 said in Firmware 2.0RC1 and 1.21.1RC1 released:
                    I have configured all 3 fans for non thermostatic controlled but I also can only see 1 fan in DWC - the "Tool Fan".
                    And it would be nice if you can (re)name these fans in DWC.
                    Printing with an UMO+
                    Duet 2 WiFi 1.04
                    • MSquared
                      MSquared @dc42 last edited by
                      @dc42 I upgraded and used it over the weekend with no issues. Hardly a torture test but it seemed to be performing well...
                        dc42 administrators @Christoph13524 last edited by dc42
                        @christoph13524 said in Firmware 2.0RC1 and 1.21.1RC1 released:
                        It works for me. Please check that you are running firmware 2.0RC1.
                        Christoph13524 ShadowX 2 Replies Last reply Reply Quote 0
                        • Christoph13524
                          Christoph13524 @dc42 last edited by Christoph13524
                          I am...
                          I tried it in Safari and Chrome.
                          Duet 2 WiFi 1.04
                          • Christoph13524
                            I just tried something different:
                            I set up the position 0 fan for thermostatic controlled. Position 1 and 2 fans are still non thermostatic controlled.
                            Then DWC showed all 3 fans. See pictures below:
                            Then I set up all 3 fans again for non thermostatic controlled (as shown in my previous post) and DWC again showed me only the "Tool Fan".
                            Duet 2 WiFi 1.04
                              Strange, I've just set up my Kossel the same way, running exactly the same firmware and DWC versions, and it is showing Tool Fan plus fans 0, 1 and 2.
                              Try sending M106 commands in DWC and see what effect it has on which fans are displayed. It may take a few seconds to update. The firmware needs to see an I, F or H parameter for a fan before it considers that fan has been configured.
                              • wilriker
                                wilriker Moderator last edited by
                                I am still in setup phase of my printer using the Duet Wifi but the few prints I have done so far have either succeeded or failed to to PEBKAC not the firmware. 😉
                                Aside from prints I have not encountered any other issues.
                                Manuel
                                My Tool Collection
                                • Christoph13524
                                  I've tried sending different M106 commands.
                                  I think I found the problem: If the config.g file is set up with 3 non thermostatic controlled fans then it only shows me the Tool Fan. Now if I send a M106 command in DWC to set a fan for non thermostatic controlled again, nothing happens. The fan is still not visible. I've tried that with all 3 positions several times.
                                  BUT if I send a M106 command to activate the thermostatic control for example the P0 fan, DWC suddenly makes P1 and P2 visible an it seems like now everything works.
                                  If I now set a fan thermostatic controlled in DWC using the 106 command then it isn't visible. If I disable thermostatic control then they are visible.
                                  So you have to set 1 fan for thermostatic controlled first and then everything works like it should.
                                  But the Tool Fan is always there. No matter if it's thermostatic controlled or not.
                                  Why does it even show me 4 fans? Tool fan = position 0 fan.
                                  Duet 2 WiFi 1.04
                                    1. I confirm that there seems to be a bug when all the fans are enabled in config.g as non-thermostatic fans.
                                    2. The tool fan can be mapped to any of the other fans, and the mapping can change depending on the tool you select. That's why it is shown independently of the fan numbers.
                                    • ShadowX
                                      ShadowX @dc42 last edited by ShadowX
                                      My settings all have the Thermostatic control turned off.
                                      Edit: It seems like you already confirmed that its a bug.
                                      I updated the firmware using the "upload file" function on the DWC, however, it still shows up as 1.21 after the "update". I uploaded with the older revision of DWC and also the RC1 version and it would not update the firmware. I don't know if others have the same issues with upgrading the firmware. I have the DuetWifi version 1.01 board and tried upgrade using the "Duet2CombinedFirmware.bin" file.
                                      Is there a different process to upload the RC1 file?
                                        If you are already running main firmware 1.21 and DWC 1.21 or later, then you should just be able to upload the new Duet2CombinedFirmware.bin file through the Settings/General page of DWC. DWC should then offer to install it.
                                        ShadowX 1 Reply Last reply Reply Quote 0
                                        • Printtome3d
                                          Printtome3d last edited by
                                          DWC
                                          Hello i have two Duet 3D WiFi and one after Install the new firmware the DWC have crash and reboot when i try to Connect to the board. Can you Help me.
                                            I'm sorry to here you are unable to run the new firmware. Suggestions:
                                            1. If you have a PanelDue connected, disconnect it and see if the Duet will start up.
                                            2. Remove the SD card, then power up the Duet and see if you can connect via USB.
                                            3. If either #1 or #2 lets you start the Duet, run M122 immediately and post the software reset data here.
                                            • Printtome3d
                                              ok i am going to do this and send to you the result of M112
                                              • Printtome3d
                                                this is the error when i try to Connect to the board with the DWC.
                                                SyntaxError: JSON Parse error: Unexpected identifier "nan"
                                                • Printtome3d
                                                  This is the result of M122 send on USB
                                                  < 20:00:39: ResponseBusy
                                                  < 20:00:39: Bad recv status size
                                                  < 20:00:39: WiFi: avail: 10
                                                  < 20:00:39: WiFi: used: 0
                                                  < 20:00:39: === Diagnostics ===
                                                  < 20:00:39: RepRapFirmware for Duet 2 WiFi/Ethernet version 2.0(RTOS)RC1 running on Duet WiFi 1.02 or later
                                                  < 20:00:39: Board ID: 08DDM-9FAM2-LW4S4-6JKF0-3S86J-TLSBX
                                                  < 20:00:39: Used output buffers: 1 of 20 (11 max)
                                                  < 20:00:39: === RTOS ===
                                                  < 20:00:39: Static ram: 28484
                                                  < 20:00:39: Dynamic ram: 96036 of whiWiFi: max: 0
                                                  < 20:00:39: ch 0 recycled
                                                  < 20:00:39: Exception stack ram used: 408
                                                  < 20:00:39: Never used ram: 6144
                                                  < 20:00:39: Task NETWORK ready, free stack 340
                                                  < 20:00:39: Task HEAT blocked, free stack 1260
                                                  < 20:00:39: Task MAIN running, free stack 3800
                                                  < 20:00:39: === Platform ===
                                                  < 20:00:39: Last reset 20:29:50 ago, cause: power up
                                                  < 20:00:39: Last software reset at 2018-05-08 00:36, reason: User, spinning module GCodes, WiFi: err: 0
                                                  < 20:00:39: available RAM 3848 bytes (slot 2)
                                                  < 20:00:39: Software reset code 0x0003 HFSR 0x00000000, CFSR 0x00000000, ICSR 0x0041f000, BFAR 0xe000ed38, SP 0xffffffff
                                                  < 20:00:39: Error status: 0
                                                  < 20:00:39: Free file entries: 10
                                                  < 20:00:39: SD card 0 detected, inteWiFi:
                                                  < 20:00:39: rface speed: 20.0MBytes/sec
                                                  < 20:00:39: SD card longest block write time: 0.0ms
                                                  < 20:00:39: MCU temperature: min 34.1, WiFi: avail: 4
                                                  < 20:00:39: current 34.3, max 38.8
                                                  < 20:00:39: Supply voltage: min 0.2, current 0.4, max 12.9, under voltage events: 1, over voltage events: 0
                                                  < 20:00:39: Driver 0: standstill, SG min/max not availWiFi: used: 0
                                                  < 20:00:39: able
                                                  < 20:00:39: Driver 1: standstill, SG min/max not available
                                                  < 20:00:39: Driver 2: standstill, SG min/max not available
                                                  < 20:00:39: Driver 3: standstill, SG min/maWiFi: max: 0
                                                  < 20:00:39: x not available
                                                  < 20:00:39: Driver 4: standstill, SG min/max not available
                                                  < 20:00:39: Date/time: 2018-05-09 20:00:35
                                                  < 20:00:39: Slowest main loop (seconds): 0.0WiFi: err: 0
                                                  < 20:00:39: 12307; fastest: 0.000065
                                                  < 20:00:39: === Move ===
                                                  < 20:00:39: Hiccups: 0, StepErrors: 0, LaErrors: 0, FreeDm: 240, MinFreeDm 236, MaxWait: 2696479971ms, Underruns: 0, 0
                                                  < 20:00:39: Scheduled moves: 9, completed moves: 9
                                                  < 20:00:39: Bed compensation in use: none
                                                  < 20:00:39: Bed probe heights: 0.000 0.000 0.000 0.000 0.000
                                                  < 20:00:39: === Heat ===
                                                  < 20:00:39: Bed heaters = 0 -1 -1 -1, chamberHeaters = -1 -1
                                                  < 20:00:39: === GCodes ===
                                                  < 20:00:39: Segments left: 0
                                                  < 20:00:39: Stack records: 2 allocated, 0 in use
                                                  < 20:00:39: Movement lock held by null
                                                  < 20:00:39: http is idle in state(s) 0
                                                  < 20:00:39: telnet is idle in state(s) 0
                                                  < 20:00:39: file is idle in state(s) 0
                                                  < 20:00:39: serial is ready with "M122 " in state(s) 0
                                                  < 20:00:39: aux is idle in state(s) 0
                                                  < 20:00:39: daemon is idle in state(s) 0
                                                  < 20:00:39: queue is idle in state(s) 0
                                                  < 20:00:39: autopause is idle in state(s) 0
                                                  < 20:00:39: Code queue is empty.
                                                  < 20:00:39: === Network ===
                                                  < 20:00:39: Responder states: HTTP(0) HTTP(0) HTTP(0) HTTP(0) FTP(0) Telnet(0) Telnet(0)
                                                  < 20:00:39: HTTP sessions: 0 of 8
                                                  < 20:00:39: - WiFi -
                                                  < 20:00:39: Network state is running
                                                  < 20:00:39: WiFi module is connected to access point
                                                  < 20:00:39: Failed messages: pending 0, notready 0, noresp 0
                                                  < 20:00:39: WiFi firmware version 1.21
                                                  < 20:00:39: WiFi MAC address 60:01:94:34:38:80
                                                  < 20:00:39: WiFi Vcc 3.32, reset reason Turned on by main processor
                                                  < 20:00:39: WiFi flash size 4194304, free heap 15912
                                                  < 20:00:39: WiFi IP address 192.168.1.76
                                                  < 20:00:39: WiFi signal strength -62dBm, reconnections 0, sleep mode modem
                                                  < 20:00:39: Socket states: 0 0 0 0 0 0 0 0
                                                  < 20:00:39: === Expansion ===
                                                  • Printtome3d
                                                    ok i try test the DWC on Google Chrome and is Connect to the board but when i click on the settings the DWC disconnect and give me the error SyntaxError: Unexpected token a in JSON at position 216
                                                    • AS-3D Druck
                                                      AS-3D Druck last edited by
                                                      First print was successful 2. print in Progress.
                                                      The new Firmware works fine for. 👍
                                                      Best regards
                                                      AS-3D Druck / Andre
