Sound plays on web-interface when temp is reached
I would be nice to have a BING to let you know when the heatbed is heated up or when the hotend is ready.. It takes about 15-20minutes for my heater to get up to snuff and I get distracted browsing for
pornresearch material, but if there was some sorta chime to let me know the printer is ready to go that would be neat
Have you try using M300 after M190?
http://reprap.org/wiki/G-code#M300:_Play_beep_sound
i don't have a peizzo attached to my printer, but i was talking about the duet web interface…
From the wiki
If an LCD device is attached to RepRapFirmware, a sound is played via the add-on touch screen control panel. Else the web interface will play a beep sound.
Oh.
So, how would I add that to the set temperature interface in the duet webpage?
I suggest you set up a macro that sets the bed temperature using M140, waits for it to stabilise using M116, then uses M300 and G4 commands to play a tune.
