Panel 7i + pt100
HELLO I HAVE A CONSULTATION, IF I CONNECT THE PT100 THERMISTOR, I WILL NOT FUNCTION CORRECTLY THE CONTROL PANEL 7i SD ?, How can I make the SD of the LCD panel work since I have to load the .gcode files
Are you saying that the PT100 doesn't function when the PanelDue ribbon cable is connected?
