Protecting the board from heater short
every heater cartridge has 2 little wires that can brake and touch the block or the user can accidentali touch them with a tool during nozzle replacement causing a short.Is it possible to protect the mosfet from burning by adding a fuse ?
With a 40W 24v heater element what fuse rating should I use ?
Fast blow or slow ?
thx
A 2A quick blow fuse would protect against fire, but would not necessarily protect the mosfet.
However, the nozzle should not be changed while the printer is powered up.
The nozzle should be changed while hot as long as i know, otherwise is very hard to unscrew.
I now we can heat the nozzle then turn off the heater and unscrew the nozzle but as you know some user may forget to turn the heater off
@paboman Than you not have the knowledge to change a nozzle.....
its like the electrician in you're house, when you change a fuse.
you know that you do something that is important
@mickey30m maybe...I do not know a lot of things
till now I have always heated the nozzle in order to be able to unscrew it without breaking the heatbreak (the E3D)
Do You change nozzle at room temp ?
@paboman when i need to change it.
I do 220 C hotend and extrude some filament And then remove my filament. Then i disconnect everything and losen my nozzle while i hold my heater block.
cant see any difference between our methods...you heat the hotend also and I also turn off the heater after reaching the temp.
