    Reverse proxy: CSS not loading?
    • Nxt-1
      Nxt-1 last edited by
      I am currently experimenting with making the DWC accessible from outside my LAN. The setup currently working like this:
      • Dyndns configuration to translate to my public network address.
      • Portforward from port 5080 to my_pc's_networkaddress:5080.
      • Windows (10) firewall rule to accept TCP connections for a specific program (Apache)
      • An Apache webserver listening on port 5080 with a reverse proxy to "http://my_printer's_networkaddress/"
      I can acces the DWC just fine but none of the css styling seems to load. Any advice on how to fix this is much appreciated. (From what I can Google, I think the issue is related to handeling relative url's.)
      • Nxt-1
        Bump, anyone?
          The reprap.htm file includes these lines. Near the start:
          <link href="css/dwc.css" rel="stylesheet">
          Near the end:
          <script src="js/dwc.js"></script>
          So you could try editing that file, putting a leading "/" at the start of each path.
          HTH David
          • resam
            resam last edited by resam
            I'm running an nginx reverse proxy - without editing DWC files.
            I think you can play with adding a final / to your Apache ProxyPass config.
            edit:
            This is my nginx snippet:
                            location /my_printer/dwc/ {
                                    proxy_pass http://10.0.0.42/;
            Nxt-1 1 Reply Last reply Reply Quote 0
            • Nxt-1
              Nxt-1 @resam last edited by
              @resam said in Reverse proxy: CSS not loading?:
              edit:
              That did it, thank you very much.
              • wilriker
                wilriker Moderator last edited by
                Interesting. I also run a reverse proxy with nginx but I do not need this trailing slash - but it may be due to me using a subdomain.
                Therefore my relevant part looks like
                server {
                    server_name duet.<domain>;
                    location / {
                        proxy_pass http://192.168.3.4;
