    Is it possible to use a Dyze Sentinel with the DuetWifi?
    1279
    • cye604
      cye604 last edited by
      I am leaning towards using the DuetWifi for a couple of printers I am building, and I just saw this on Kickstarter: https://www.kickstarter.com/projects/2052721114/sentinel-3d-printer-filament-detector-and-cleaner/description. According to the page, it just needs an open digital pin (and I am assuming a 5v and ground pin). Would something like this work with the DuetWifi?
        Yes it should be compatible, see https://duet3d.com/wiki/Connecting_and_configuring_filament-out_sensors. That page is a bit sketchy at present.
        • Adamfilip
          Adamfilip last edited by
          I have connected a sentinel to the E1 endstop
          info on how to connect are here
          https://dyzedesign.com/support/filament-sentinel-technical-support/
          • Adamfilip
            I am adding a
            M581 E1 T1
            to the confuration to trigger a Pause when E1 endstop is triggered
            does this sound correct?
              That looks correct to me, assuming you want to trigger the pause when the input goes high.
              • Adamfilip
                How can I check status of E1 Endstop
                when I do M119 it doesnt show up.
                • Whitewolf
                  Whitewolf last edited by
                  you can also look in the control panel it shows the endstops with several others as well
                  Exploring the universe wherever the tech blows
                    It's in Settings/Machine Properties in Duet Web Control.
