Your browser does not seem to support JavaScript. As a result, your viewing experience will be diminished, and you may not be able to execute some actions.
Please download a browser that supports JavaScript, or enable it if it's disabled (i.e. NoScript).
Is there a setting to change the temperature range chart within the Duet Web Control?
I have a high-temperature hot end that exceeds 400'c
nevermind By setting the max temp using M143 is the solution
