    Volumetric extrusion not working
    • War44
      War44 last edited by
      I just installed my DuetWifi (firmware 1.16) on a delta with a diamond 3color mix head and I can not get volumetric extrusion to work (I get over extrusion more then 2x). I am using 'M404 N1.75' to enable volumetric extrusion in firmware. I also tried 1.17 same results.
      Prints great if I disable volumetric extrusion in the slicer and firmware (M404 N0), using linear extrusion. No other setting changed.
      I have a single driver for extruder #3 hooked to E2 outputs.
      Is there a additional command to enable volumetric extrusion? Anybody else have this problem?
        RepRapFirmware doesn't support volumetric extrusion. It would be easy enough to implement, but what advantage do you expect to gain from using it?
        • War44
          Not a problem, I was trying to print some previous gcode files. Thank you for your prompt response.
            I can see the value of being able to use previous gcode files by supporting volumetric extrusion, so I'll add it to the work list. I need to work out how it interacts with colour mixing before I implement it. It also interacts with use of relative or absolute extruder coordinates.
            EDIT: it also interacts with pause/restore, and extrusion commands in the web interface and PanelDue. There's a lot to think about. Does your slicer generate the M404 command itself?
