    How to print console to .txt & run loops in macros ?
    • schpongo
      schpongo last edited by
      Hey I'm not sure if this is a working feature, If so please do point me to a guide.
      But I would like to save the output of for example the G3 S-1 command to a text file so I can later evaluate the text file.
      By doing this I could take repeated measurements and get a good average.
      Another things that would be helpful in this context would be the ability to write loops in macros.
      Thanks for the help.
        You can't do loops in macros yet unfortunately. Maybe soon?
        But you can enable logging to a file.
        https://duet3d.dozuki.com/Wiki/Logging
        However, to do what you want with the G30 S-1 command to get an average of consecutive trigger height runs you can do something like I've done in a macro. It requires having gcodes echoes to the DWC gcode console and running the macro from the DWC (as opposed to from the panel due as then it doesn't seem to echo properly).
        ; Clear compensation map and Zprobe trigger height
        M291 P"Grid bed compensation map and ZProbe trigger height will be cleared. Ok or Cancel?" R"WARNING" S3 ; User must click OK or cancel.
        M561	; Disable any current bed compensation
        G29 S2	; Clear mesh bed compensation perameters
        G31 Z0	; Reset zprobe trigger height
        ; home all axis
        G28	; Home all axis
        G90	; Absolute positioning
        T0	; Activate first tool
        ; Set lower speeds for Z homing and lower Z motor current
        M566 Z10	; Set maximum instantaneous speed changes (mm/min) (Jerk)
        M203 Z400	; Set maximum speeds (mm/min)
        M201 Z100	; Set maximum accelerations (mm/s^2)
        M906 Z900	; Drop motor current to prevent damage in case of head crash
        ; Preheat to probing temps
        M291 P"Preheating to bed to 60 and nozzle to 210 for accurate probing"
        M104 S210	; Set nozzle to 210 and release
        M190 S60	; Set bed to 60 and wait
        M109 S210	; Set nozzle to 210 and wait
        ; Move nozzle to center of bed at z10
        M291 P"Nozzle will now move to center of bed to reset Z0 and calibrate probe" S3
        G1 Z1	; Drop bed for nozzle clearance
        G1 X150 Y110 Z2 F4000	; Move to bed center
        ; Reset z to 5 to allow jogging up to touch bed to nozzle
        G92 Z5
        ; Dialog to allow user to jog z to touch nozzle to bed gently and then move Z down 10
        M291 P"Jog the Z Axis until the bed and nozzle are touching and click OK" R"Setting Z=0" Z1 S3
        G92 Z0	; Set z = 0
        ; Move probe to center of bed and get probe trigger heights
        M291 P"Probe will now move to center of bed and measure trigger height 10 times" R"ZProbe Trigger Height Calibration" S3
        G1 X190 Y90 F4000 ; Move to bed center
        M291 P"Heights will be found in gcode console if logging successful gcode is enabled" R"Did you remember to enabled gcode logging?" S3
        ; G30 S-1 10 times
        ; 1
        G1 Z10
        G30 S-1
        ; 2
        G1 Z10
        G30 S-1
        ; 3
        G1 Z10
        G30 S-1
        ; 4
        G1 Z10
        G30 S-1
        ; 5
        G1 Z10
        G30 S-1
        ; 6
        G1 Z10
        G30 S-1
        ; 7
        G1 Z10
        G30 S-1
        ; 8
        G1 Z10
        G30 S-1
        ; 9
        G1 Z10
        G30 S-1
        ; 10
        G1 Z10
        G30 S-1
        M291 P"Probing complete. Turning off heaters and homing axis. Check log for trigger heights and enter into config.g" S2
        ; Turn off heaters
        M104 S0	; Set nozzle to 0 and release
        M140 S0	; Set bed to 0 and release
        M906 Z1500	; Return Z motor current to normal
        G28 XY	; Home XY
        ; Tone to get user attention
        M400	; Clear movement buffer so tones play reliably
        M300 S666 P500
        G4 P501
        M300 S1111 P300
        G4 P301
