    First layer issues.
    • pineapplesystems
      pineapplesystems last edited by
      I can't get my first layer to stick and it seems like the nozzle is too high. Using baby steps doesn't really help me. I am going well beyond -4mm. Can anyone help? I am suspecting that the bed compensation doesnt get read or something.
      I am trying to set up my z probe. I am converting the Prusa MK2 to the duet. I am running into an issue with my z height. First I will start with how I have it hooked up. It requires 5v so I hooked it up to the expansion slot 5v pin, the ground to the E0 limit switch ground and the signal to the E0 limit switch signal.
      The probe is set up to trigger around 4mm, and it does. Mesh bed leveling gives me a pretty skewed plane, but nothing that can't be handled. I have a spring steel base with a PEI sheet bonded to it. The top of the surface is about 1mm away from the metal plate.
      When I call G29, it does 9 points around the bed just like the MK2 does. Then I home it.
      This is my Z-Probe set up
      M574 Z2 S2 ; Set endstops controlled by probe
      M558 P4 H5 F240 T7200 I0 A3 ; Set Z probe type
      G31 P1000 X0 Y0 Z0.00 ; Set Z probe trigger value, offset and trigger height
      M557 X12:238 Y4:206 S100 ; Define mesh grid
      This is my start g-code script:
      M83 ; extruder relative mode
      M104 S215 ; set extruder temp
      M140 S60 ; set bed temp
      M190 S60 ; wait for bed temp
      M109 S215 ; wait for extruder temp
      M561 ;forget previous meshes
      G28 ;home
      G29 ; home and mesh bed leveling
      G29 S1
      G1 Y-3.0 X4 F3000.0 ; go outside print area
      G92 E0.0
      G1 Z0.2 ;Go down to surface
      G1 X60.0 E9.5 F1000.0 ; intro line
      G1 X100.0 E12.5 F1000.0 ; intro line
      G92 E0.0
        @pineapplesystems said in First layer issues.:
        In this line:
        You have the probe X and Y offsets set to zero, and the trigger height also set to zero. I suggest you set the X and Y offsets to the correct values, then calibrate the trigger height as described at https://duet3d.dozuki.com/Wiki/Test_and_calibrate_the_Z_probe.
        pineapplesystems 2 Replies Last reply Reply Quote 1
        • pineapplesystems
          Hi!
          Thanks for the reply. I calibrated this and set the z height as well. I set it to X23 Y9 Z0. The 0 i got from that z probe calibration with the g92 z0 command. Still no luck though. Going to try to print something with a large bed surface area now. See what's happening.
          • pineapplesystems
            pineapplesystems @dc42 last edited by
            @dc42 No luck. I followed the whole process. I put on something with a big surface area, I am doing the baby stepping yet nothing is changing. This is my updated z probe definition:
            M558 P4 H5 F240 T7200 I0 ; Set Z probe type
            G31 P1000 X23 Y9 Z0 ; Set Z probe trigger value, offset and trigger height
            M557 X28:225 Y10:208 S90 ; Define mesh grid
            Any other ideas? I explored my extruder steps per mm value as well and got that calibrated too.
            • pineapplesystems
              @dc42 This is my entire config file:
              M569 P0 S0 ; Drive 0 goes backwards
              M569 P3 S1 ; Drive 3 goes backwards
              M92 X100 Y100 Z400 E161.3 ; Set steps per mm
              M566 X600 Y600 Z12 E150 ; Set maximum instantaneous speed changes (mm/min)
              M203 X30000 Y30000 Z720 E7200 ; Set maximum speeds (mm/min)
              M201 X9000 Y9000 Z500 E10000 ; Set accelerations (mm/s^2)
              M906 X800 Y800 Z800 E800 I30 ; Set motor currents (mA) and motor idle factor in per cent
              M84 S30 ; Set idle timeout
              M208 X0 Y-2.2 Z0 S1 ; Set axis minima
              M208 X250 Y210 Z200 S0 ; Set axis maxima
              M574 X1 Y1 S1 ; Set active high endstops
              ;M574 Z2 S2 ; Set endstops controlled by probe
              M558 P4 H5 F240 T7200 I0 ; Set Z probe type to ultrasonic and the dive height + speeds
              ;M558 P1 Z1 F500 T7200 H5 I0
              M563 P0 D0 H1 ; Define tool 0
              • 3dTony
                3dTony last edited by 3dTony
                I feel like you're missing a step in the calibration. I would think your Z offset should be something other than zero. If you are doing all of the steps, then zero should be your nozzle touching the bed.
