    M587: Bad or missing parameter
    1.8k
    • RajaaKahelundefined
      RajaaKahel
      Hi, I just received my DuetWifi V1.03.
      I'm stuck with connecting the Wifi. I'm getting this error: M587: Bad or missing parameter.
      My wifi is not 5GH.
      Here's my network SSID and password:
      M587 S”Xiaomi5772” P”Kahel2000”.
      I tried many times and tried connecting the USB again and starting over. Even had a "_" in the SSID and removed it from the name.
      Here's the terminal texts I got:
      Last login: Thu May 17 13:16:45 on ttys000
      Rajaas-MacBook-Pro:~ RajaaKahel$ screen /dev/tty.usbmodem1421 115200
      RepRapFirmware for Duet 2 WiFi/Ethernet Version 1.21 dated 2018-03-21
        Executing config.g...Error: Bad command: FOR TESTING ONLY! USE https://configurator.reprapfirmware.org/ to generate configuration files for your printer!
        WiFi module is disabled
       Warning: Heater 0 appears to be over-powered. If left on at full power,FIRMWARE_NAME: RepRapFirmware for Duet 2 WiFi/Ethernet FIRMWARE_VERSION: 1.21 ELECTRONICS: Duet WiFi 1.02 or later FIRMWARE_DATE: 2018-03-21
                                                          ok
                                                            WiFi module is idle
        ok
                               ok
                                                               ok
      • wilrikerundefined
        wilriker @RajaaKahel
        @rajaakahel said in M587: Bad or missing parameter:
        Make sure that you are using regular straight double quotes " In the command you send to the Duet.
        Because the ones you have given above (”) are a different symbol.
        Try copy and pasting the following:
        M587 S"Xiaomi5772" P"Kahel2000"
        Manuel
        My Tool Collection
        RajaaKahelundefined 1 Reply Last reply Reply Quote 1
          RajaaKahel @wilriker
          @wilriker Awesome! It's connected now! Wow thanks for the quick answer!
          Strange they provided the wrong symbols!
          • wilrikerundefined
            @rajaakahel You are welcome.
            You are using a Mac - nothing coming from those strikes me as strange. 😂 (I confess to be a Linux fanboy 😁)
            Manuel
            My Tool Collection
            RajaaKahelundefined 1 Reply Last reply Reply Quote 0
              @wilriker Well I'm learning then 😄 Hopefully I'll be able to not get surprised 😄
