    Problem with dual z
    • dxmoneundefined
      dxmone
      Hi, i have a problem with my new duet board. When i connect one Z-motor to ZA with the jumpers still attached it works just as it should. But when i remove the jumpers and connect the second motor to ZB both motors stops working. They are making a buzzing sound and they try to move back and forth. But they are not spinning. https://imgur.com/a/IRHDlpV here is the wiring, it's hard to see the first connector but they are wired the same as ZB (notice the gray wire is the black one from the motor).
      My Drive config looks like this
      M92 X80 Y80 Z400 E420 ; Set steps per mm
      M203 X6000 Y6000 Z30 E1200 ; Set maximum speeds (mm/min)
      M201 X500 Y500 Z250 E250 ; Set accelerations (mm/s^2)
      M906 X800 Y800 Z800 E800 I30 ; Set motor currents (mA) and motor idle factor in per cent
      M84 S30 ; Set idle timeout
      What am I missing?
      • dxmoneundefined
        dxmone
        Forgot to post the firmware versions.
        Firmware Version: 1.21 (2018-03-21)
        WiFi Server Version: 1.21
        Web Interface Version: 1.20
          It may mean that you have high inductance motors that won't work in series unless you use 24V power. If that is the case then you should connect both motors in parallel to just one connector. Or, if you are not using the E1 motor output, you can connect one of them to that connector and add this line to config.g, before any M350 or M906 commands:
          M584 X0 G1 S2:4 E3
          If you can tell us the model number of your Z stepper motors, we can tell you if this is the reason for the problem.
